Re: Deliver no source files in p2 site [message #668728 is a reply to message #668379] |
Fri, 06 May 2011 20:53 |
Please try quoting. This is apparently on Windows and some windows cmd shells will actually split on '='.
- thomas
On 2011-05-05 15:29, Johannes Utzig wrote:
> Am 05.05.2011 15:17, schrieb Henrik Lindberg:
>> All your other -D settings have " " around them... could that be it?
> Hmm, no, that should work since there is no spaces or anything in that property.
> To me it looks like a buckminster bug unless the cbi.include.source is not valid as a system property and HAS to be in a
> properties file (but you said that didn't work either?)
Re: Deliver no source files in p2 site [message #670254 is a reply to message #669996] |
Fri, 13 May 2011 08:55 |
Lukas L. Messages: 13 Registered: May 2011 |
Hi Daniel,
Yes, I am sure that buckminster creates new source bundles with every new build. Before every new build I delete manually my old builds in order to exclude exactly this case.
I also tried this alternative:
perform -D cbi.include.source=false ...#site.p2.zip
However, without success.
Over again: I have this problem only building via Jenkins (Buckminster is installed automatically via Jenkins). Building manually via Buckminster from my Eclipse Environment works as expected - The sources are not included.
One remark: Roughly in a week I will migrate my Jenkins configuration from my local Windows System to a Mac OS System. Maybe this will solve the problem.
However, it is still a strange behaviour.
Lukas
[Updated on: Fri, 13 May 2011 08:58] Report message to a moderator
FUDForum. Page generated in 0.03086 seconds
