Home » Language IDEs » Java Development Tools (JDT) » How to install JDT on platform manually
How to install JDT on platform manually [message #667621] Fri, 29 April 2011 22:19 Go to next message
I have downloaded eclipse platform runtime binary(eclipse-platform-3.7M7-win32.zip) and JDT runtime binary(org.eclipse.jdt-I20110428-0848.zip).
How can I install JDT on eclipse platform locally?
Re: How to install JDT on platform manually [message #667835 is a reply to message #667621] Mon, 02 May 2011 08:14 Go to previous messageGo to next message
Try Help>Install New Software, and add a local archive site pointing at
the jdt zip.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: How to install JDT on platform manually [message #668024 is a reply to message #667835] Tue, 03 May 2011 08:41 Go to previous messageGo to next message
Thank you, Paul. I tried your advice. It may work, but when my eclipse appears the window which tell you to review the installed plugins, I click next button but it can not go to next page. Eclipse seems want to download artifacts.xml but failed.
I downloaded eclipse-platform-N20110502-2000-win32.zip and org.eclipse.jdt-N20110502-2000.zip. I extracted features and plugins folder of JDT zip into eclipse's dropins folder and extract file in binary folder of JDT zip into eclipse\p2\org.eclipse. equinox.p2.core\cache\binary. Then JDT was successfully installed. Smile
Re: How to install JDT on platform manually [message #1754970 is a reply to message #668024] Fri, 24 February 2017 12:38 Go to previous message
I don't know if you found a solution to this, but if you download a jdt zip then you can extract & copy the "plugins" and "features" directories to the corresponding directories in your installed eclipse platform path (eg. like ~/.eclipse/org.eclipse.platform_4.4.1_1473617060_linux_gtk_x86_64/ on my linux install).
Previous Topic:Guidance on how to utilize bug fix 401015
Next Topic:Eclipse DEBUG Logs
Current Time: Wed Oct 22 12:58:59 EDT 2025
Powered by FUDForum. Page generated in 0.28724 seconds
