[Xtend/UML2] Resolving elements of a UML Profile. [message #667499] |
Fri, 29 April 2011 08:12 |
Rainer Alföldi Messages: 1 Registered: April 2011 Location: Bern, Switzerland |
Hi all,
I'm having real problems resolving imported elements of a UML Profile. primitiveTypes and steroTypes defined in the UML Model itself resolve perfectly. If imported from a UML Profile, it fails.
@Christian Dietrich: I've seen your answer to [Xpand] Issues setting up project to generate text from UML2 profile metamodel
from January 2011. My workflow file seems to match your working example.
module workflow
Workflow {
bean = org.eclipse.emf.mwe.utils.StandaloneSetup {
platformUri = ".."
bean = org.eclipse.xtend.typesystem.uml2.Setup {
standardUML2Setup = true
component = org.eclipse.emf.mwe.utils.Reader {
id = "reader"
uri = "uml/ch.alfoeldi.uml"
modelSlot = "model"
component = org.eclipse.emf.mwe.utils.DirectoryCleaner {
directory = "src-gen"
component = org.eclipse.xpand2.Generator {
id = "generator"
expand = "templates::Root::Root FOR model"
metaModel = org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel {}
metaModel = org.eclipse.xtend.typesystem.emf.EmfMetaModel {
metaModelPackage = "org.eclipse.emf.ecore.EcorePackage"
metaModel = org.eclipse.xtend.typesystem.uml2.profile.ProfileMetaModel {
profile = "platform:/resource/UML%20Generator/uml/primitiveTypes.profile.uml"
metaModel = org.eclipse.xtend.typesystem.uml2.UML2MetaModel {}
outlet = {
fileEncoding = "UTF-8"
path = "src-gen"
postprocessor = org.eclipse.xpand2.output.JavaBeautifier {}
resourceManager = org.eclipse.xtend.expression.ResourceManagerDefaultImpl {
Tracing into ProfileMetaModel reveals that the profile file is read - including all components.
Nevertheless when accessing type in an xpand template type.name returns null.
The generated result looks like this (Javadocs display type.toString()):
/* org.eclipse.uml2.uml.internal.impl.PrimitiveTypeImpl@59c8b5 (eProxyURI: primitiveTypes.profile.uml#_iRiagHHCEeCLNP92l7dxhw)*/
private null _primitivAttribute;
/* org.eclipse.uml2.uml.internal.impl.StereotypeImpl@1a40247 (eProxyURI: primitiveTypes.profile.uml#_bdmbYHIsEeCcdecZAFuVOg)*/
private null _stereoTypeAttribute;
/* org.eclipse.uml2.uml.internal.impl.PrimitiveTypeImpl@1e6978d (name: LocalPrimitiveType, visibility: <unset>) (isLeaf: false, isAbstract: false)*/
private LocalPrimitiveTyp _localPrimitiveAttribute;
I'm obviously doing something wrong. The question is what?
And while I'm at it: ProfileMetaModel seems to only pay attention to StereoTypes and Enumerations, ignoring primitiveTypes.
if (o instanceof Stereotype) {
final Stereotype st = (Stereotype) o;
final String typeName = getFullName(st);
final Type t = new StereotypeType(getTypeSystem(), typeName, st);
stereoTypes.put(typeName, t);
else if (o instanceof Enumeration) {
final Enumeration en = (Enumeration) o;
final String typeName = getFullName(en);
final Type t = new EnumType(getTypeSystem(), typeName, en);
Would this have any effect on resolving primitiveTypes - once I get the UML Profile working?
Greeting from Bern
Rainer
Re: [Xtend/UML2] Resolving elements of a UML Profile. [message #912899 is a reply to message #912894] |
Fri, 14 September 2012 11:22 |
Eclipse Indigo says the following when reading the model
3191 ERROR VisitorCreator - java.lang.RuntimeException: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Value 'org.eclipse.uml2.uml.internal.impl.EnumerationImpl@3436fffc (name: treeStructureEnumeration, visibility: <unset>) (isLeaf: false, isAbstract: false, isFinalSpecialization: false)' is not legal. (platform:/resource/my.uml.example/src/UML_Standard_Profile.MagicDraw_Profile.profile.uml, 4107, 17)
java.lang.RuntimeException: java.lang.RuntimeException: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Value 'org.eclipse.uml2.uml.internal.impl.EnumerationImpl@3436fffc (name: treeStructureEnumeration, visibility: <unset>) (isLeaf: false, isAbstract: false, isFinalSpecialization: false)' is not legal. (platform:/resource/my.uml.example/src/UML_Standard_Profile.MagicDraw_Profile.profile.uml, 4107, 17)
at org.eclipse.emf.mwe.internal.core.ast.util.InjectorSimple.setValue(InjectorSimple.java:35)
at org.eclipse.emf.mwe.internal.core.ast.util.VisitorCreator.visitSimpleParamAST(VisitorCreator.java:201)
at org.eclipse.emf.mwe.internal.core.ast.util.VisitorBase.visit(VisitorBase.java:49)
at org.eclipse.emf.mwe.internal.core.ast.AbstractASTBase.accept(AbstractASTBase.java:44)
at org.eclipse.emf.mwe.internal.core.ast.util.VisitorCreator.createBean(VisitorCreator.java:155)
at org.eclipse.emf.mwe.internal.core.ast.util.VisitorCreator.visitComponentAST(VisitorCreator.java:116)
at org.eclipse.emf.mwe.internal.core.ast.util.VisitorBase.visit(VisitorBase.java:37)
at org.eclipse.emf.mwe.internal.core.ast.util.WorkflowFactory.parseInitAndCreate(WorkflowFactory.java:71)
at org.eclipse.emf.mwe.internal.core.ast.util.WorkflowFactory.parseInitAndCreate(WorkflowFactory.java:50)
at org.eclipse.emf.mwe.core.WorkflowEngine.prepare(WorkflowEngine.java:92)
at org.eclipse.emf.mwe.core.WorkflowEngine.run(WorkflowEngine.java:50)
at org.eclipse.emf.mwe.core.WorkflowRunner.doRun(WorkflowRunner.java:174)
at org.eclipse.emf.mwe.core.WorkflowRunner.main(WorkflowRunner.java:70)
Caused by: java.lang.RuntimeException: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Value 'org.eclipse.uml2.uml.internal.impl.EnumerationImpl@3436fffc (name: treeStructureEnumeration, visibility: <unset>) (isLeaf: false, isAbstract: false, isFinalSpecialization: false)' is not legal. (platform:/resource/my.uml.example/src/UML_Standard_Profile.MagicDraw_Profile.profile.uml, 4107, 17)
at org.eclipse.xtend.typesystem.uml2.UML2Util2.loadProfile(UML2Util2.java:48)
at org.eclipse.xtend.typesystem.uml2.UML2Util2.loadProfile(UML2Util2.java:38)
at org.eclipse.xtend.typesystem.uml2.profile.ProfileMetaModel.addProfile(ProfileMetaModel.java:152)
at org.eclipse.emf.mwe.internal.core.ast.util.InjectorSimple.setValue(InjectorSimple.java:33)
... 21 more
Caused by: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Value 'org.eclipse.uml2.uml.internal.impl.EnumerationImpl@3436fffc (name: treeStructureEnumeration, visibility: <unset>) (isLeaf: false, isAbstract: false, isFinalSpecialization: false)' is not legal. (platform:/resource/my.uml.example/src/UML_Standard_Profile.MagicDraw_Profile.profile.uml, 4107, 17)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLLoadImpl.java:77)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:185)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:240)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1505)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1284)
at org.eclipse.xtend.typesystem.uml2.UML2Util2.loadProfile(UML2Util2.java:46)
... 28 more
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.uml2.uml.internal.impl.EnumerationImpl@3436fffc (name: treeStructureEnumeration, visibility: <unset>) (isLeaf: false, isAbstract: false, isFinalSpecialization: false)' is not legal. (platform:/resource/my.uml.example/src/UML_Standard_Profile.MagicDraw_Profile.profile.uml, 4107, 17)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2657)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardReferences(XMLHandler.java:1143)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardReferences(XMLHandler.java:1024)
at org.eclipse.uml2.uml.internal.resource.UMLHandler.endElement(UMLHandler.java:47)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanEndElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
... 32 more
Twitter : @chrdietrich
FUDForum. Page generated in 0.03917 seconds
