headless not logging!? [message #667489] |
Fri, 29 April 2011 02:06  |
I'm having big issues logging data while running scenario's in headless. I'm currently using v1.2 RC5 64bit for OS X, but have also tried RC5 plus the slightly older weekly builds on a linux machine.
I can launch STEM -headless fine and scenarios execute like expected. However, even though I provide the -log parameter, the .csv files are generated but they never get populated with any data. I've tried several projects, including one that was created following exact instructions on the STEM wiki.
(also to note: I've validated all project-files inside the GUI so they should be error-free)
There are several weird parts to this issue. First of all, all scenarios I attempt to run headless-ly runs fine in the GUI, and if I turn .csv logger on while simulation in the GUI it also logs correctly to the .csv-files. There seems to be an issue with logging in -headless !?!
The other weird part of this problem is that I've downloaded the UsaMexico project and run it in -headless mode. It actually *does* log output BUT it only starts doing so at exactly 40% (why is that?). Basically it writes out a huge 10.5MB chunk of data at 40% and then another 10MB or so in the final %.
I need to get headless up and running ASAP with the logging. Any pointers?
FUDForum. Page generated in 0.04305 seconds
