Home » Newcomers » Newcomers » setting up eclipse(setting up eclipse)
setting up eclipse [message #666955] Mon, 25 April 2011 00:48 Go to next message
hi,
I have windows 7, 64 bit. I downloaded the appropriate eclipse version for php and also downloaded the JRE that is needed...
But when I click on the eclipse.exe file it says that the JRE is not found on my machine...?
I am not sure how to fix this. Any suggestions?
please let me know if you need any additional info to help help
thank you,
Re: setting up eclipse [message #666996 is a reply to message #666955] Mon, 25 April 2011 08:23 Go to previous messageGo to next message
On 2011.04.24 22:48, rebm@optonline.net wrote:
> hi,
> thank you,
http://wiki.eclipse.org/Eclipse.ini
Re: setting up eclipse [message #667066 is a reply to message #666996] Mon, 25 April 2011 16:19 Go to previous message
>> hi,
>> thank you,
Also make sure that you downloaded matching versions of Eclipse and the
JRE/JDK: they must be either both 32-bit or both 64-bit - can't
mix-and-match the "bit-ness."
Eric
Previous Topic:Eclipse won't unzip
Next Topic:even after setting the classpath got java.lang.NoClassDefFoundError: org/ini4j/Ini
Current Time: Sun Aug 03 19:50:09 EDT 2025
Powered by FUDForum. Page generated in 0.09569 seconds
