Home » Modeling » EMF » Problem with Creating Children You Didn't Know Existed
Problem with Creating Children You Didn't Know Existed [message #666543] Wed, 20 April 2011 16:09 Go to next message
Originally posted by: jconlon.apache.org
Building a model based on the OpenGIS KML with Google's kml extensions.
This requires 4 schema definitions that I have annotated for Ecore.
The (OpenGIS) Kml schema extends an AuthorLink schema and it also
extends a XAL schema. The (Google extensions) Kml22gx extends the Kml
schema.
All seem to work fine, except for the editor and adding children. I
would like to be able to see 'Children that Kml elements didn't know
existed (Kml22gx child) elements show up in new Child menus of the
editor for KML elements.
So in following the 'Creating Children You Didn't Know Existed' tip, I
set the genModel to 'Child Creation Extenders'=false & 'Extensible
Provider Factory'=true for XAL, AuthorLink, and Kml schemas and for
the Kml22gx I set 'Child Creation Extenders'=true & 'Extensible Provider
Factory'=false.
But when I try to generate the edit code for the kml22gx I get a NPE.
eclipse.buildId=M20100909-0800
java.version=1.6.0_20
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.modeling.product
Command-line arguments: -os linux -ws gtk -arch x86 -product
org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl.g etExtendedChildCreationData(GenPackageImpl.java:4576)
org.eclipse.emf.codegen.ecore.genmodel.generator.GenPackageG eneratorAdapter.countCreateChildIcons(GenPackageGeneratorAda pter.java:730)
org.eclipse.emf.codegen.ecore.genmodel.generator.GenPackageG eneratorAdapter.generateEdit(GenPackageGeneratorAdapter.java :687)
org.eclipse.emf.codegen.ecore.genmodel.generator.GenBaseGene ratorAdapter.doGenerate(GenBaseGeneratorAdapter.java:225)
org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAda pter.generate(AbstractGeneratorAdapter.java:290)
org.eclipse.emf.codegen.ecore.generator.Generator.generate(G enerator.java:617)
org.eclipse.emf.codegen.ecore.genmodel.presentation.Generato rUIUtil$GeneratorOperation.execute(GeneratorUIUtil.java:167)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:106)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1975)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:118)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
any ideas what I may be doing wrong?
thanks for any help,
John
Re: Problem with Creating Children You Didn't Know Existed [message #666640 is a reply to message #666543] Thu, 21 April 2011 08:17 Go to previous messageGo to next message
John,
I don't see anything obvious to explain the NPE...
> extensions. This requires 4 schema definitions that I have annotated
> for Ecore.
> schema.
> Provider Factory'=false.
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> John
Re: Problem with Creating Children You Didn't Know Existed [message #666689 is a reply to message #666640] Thu, 21 April 2011 11:58 Go to previous messageGo to next message
Hi Ed,
Any suggestions how I could troubleshoot this? Would like to see what
this would look like in a debugger, but at a loss on how to do it.
thanks,
John
Ed Merks wrote:
> John,
>> for Ecore.
>> schema.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> John
Re: Problem with Creating Children You Didn't Know Existed [message #666698 is a reply to message #666689] Thu, 21 April 2011 12:43 Go to previous message
John,
Assuming you have the Eclipse SDK installed, if you started a new
Eclipse under debug control you could find the source for this line and
see that's going on. You could import your projects into that workspace
and reproduce the problem...
Ed
> Hi Ed,
> thanks,
> John
> Ed Merks wrote:
>> John,
>>> for Ecore.
>>> Kml schema.
>>> I set the genModel to 'Child Creation Extenders'=false & 'Extensible
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> John
Previous Topic:Optimize menu entries
Next Topic:[Teneo] Containment in superclass causes foreign key issues using TABLE_PER_CLASS
Current Time: Wed Jul 02 08:22:54 EDT 2025
Powered by FUDForum. Page generated in 0.13768 seconds
