Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Copy all non conflicting changes ... emf compare(Using emf compare from code)
Copy all non conflicting changes ... emf compare [message #666185] Tue, 19 April 2011 08:32 Go to next message
I am experimenting with using emf compare from code based on this example:
http://dev.eclipse.org/viewcvs/viewvc.cgi/org.eclipse.emf/or g.eclipse.emf.compare/examples/org.eclipse.emf.compare.examp les.standalone/src/org/eclipse/emf/compare/examples/standalo ne/ExampleLauncher.java?view=co&root=Modeling_Project
I create to sample models that only differs slightly but how do I trigger the "Copy all non conflicting changes from right to left" from code (which updates the content of the model to the left)?
I have tried to store the two sample models to corresponding .xmi files and use emf compare through eclipse to compare and update the left file which works fine.
But I cannot find any documentation that describes how this is done from code. Any suggestions?
Re: Copy all non conflicting changes ... emf compare [message #667796 is a reply to message #666185] Mon, 02 May 2011 05:26 Go to previous message
The merging API of EMF Compare can be called through the "MergeService" facade (in the example you mentionned, it's the "MergeService.merge(differences, true);" line). The boolean passed as a parameter of this method determines the direction of the merge.
Is that not what you are seeking?
Laurent Goubet
Obeo
Previous Topic:MXF Creation Review results
Next Topic:[EMF Compare] and supertypes
Current Time: Sun Sep 21 03:41:52 EDT 2025
Powered by FUDForum. Page generated in 0.03805 seconds
