@AttributeOverrides gives me exception [message #665600] |
Fri, 15 April 2011 08:40 |
rudibravo Messages: 17 Registered: December 2010 |
Hello
I'm in the process of updating my JPA libraries, and I'm getting a new error.
I have the following scenario (I tried to simplify it to the best)
@Entity
@DiscriminatorValue(value="0")
public class B extends A
private C otherInstance = new C();
public B() {}
@Embedded
@AttributeOverrides({
@AttributeOverride(name="field1", column=@Column(name="B_FIELD_1")),
@AttributeOverride(name="field2", column=@Column(name="B_FIELD_2"))
public C getOtherInstance()
return otherInstance;
public void setOtherInstance(C otherInstance)
this.otherInstance = otherInstance;
@Entity
@Inheritance(strategy= InheritanceType.SINGLE_TABLE)
@DiscriminatorColumn(name="TYPE",
discriminatorType=DiscriminatorType.INTEGER, length=1)
@Table(name="MY_TABLE")
public abstract class A implements Serializable
private C cInstance = new C();
@Embedded
@AttributeOverride(name="field1", column=@Column(name="A_FIELD_1")),
@AttributeOverride(name="field2", column=@Column(name="A_FIELD_2"))
public C getCInstance()
return cInstance;
public void setCInstance(C cInstance)
this.cInstance = cInstance;
@Embeddable
public class C
private int field1;
private int field2;
public C() {}
public int getField1()
return field1;
public void setField1(int field1)
this.field1 = field1;
public int getField2()
return field2;
public void setField2(int field2)
this.field2 = field2;
But when I try to do a simple query I get the following exception
#|2011-04-15T09:43:22.224+0200|WARNING|glassfish3.1|org.ecli pse.persistence.session.file:/F:/glassfish3/glassfish/domain s/domain1/applications/Application_jar|_ThreadID=30;_ThreadN ame=Thread-1;|
Local Exception Stack:
Exception [EclipseLink-27] (Eclipse Persistence Services - 2.2.0.v20110202-r8913): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: Trying to invoke the method [getField1] on the object [B]. The number of actual and formal parameters differs, or an unwrapping conversion has failed.
Internal Exception: java.lang.IllegalArgumentException: object is not an instance of declaring class
Mapping: org.eclipse.persistence.mappings.DirectToFieldMapping[field1-->MY_TABLE.B_FIELD_1]
Descriptor: RelationalDescriptor(my.package.C --> [DatabaseTable(MY_TABLE)])
at org.eclipse.persistence.exceptions.DescriptorException.illeg alArgumentWhileGettingValueThruMethodAccessor(DescriptorExce ption.java:654)
at org.eclipse.persistence.internal.descriptors.MethodAttribute Accessor.getAttributeValueFromObject(MethodAttributeAccessor .java:85)
at org.eclipse.persistence.internal.descriptors.MethodAttribute Accessor.getAttributeValueFromObject(MethodAttributeAccessor .java:61)
at org.eclipse.persistence.mappings.DatabaseMapping.getAttribut eValueFromObject(DatabaseMapping.java:523)
at org.eclipse.persistence.mappings.foundation.AbstractDirectMa pping.valueFromRow(AbstractDirectMapping.java:1273)
at org.eclipse.persistence.mappings.DatabaseMapping.readFromRow IntoObject(DatabaseMapping.java:1325)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildAttributesIntoObject(ObjectBuilder.java:344)
at org.eclipse.persistence.mappings.AggregateObjectMapping.buil dAggregateFromRow(AggregateObjectMapping.java:362)
at org.eclipse.persistence.mappings.AggregateObjectMapping.read FromRowIntoObject(AggregateObjectMapping.java:1415)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildProtectedObject(ObjectBuilder.java:821)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildObject(ObjectBuilder.java:657)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildWorkingCopyCloneNormally(ObjectBuilder.java:612)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildObjectInUnitOfWork(ObjectBuilder.java:565)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildObject(ObjectBuilder.java:497)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildObject(ObjectBuilder.java:456)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.buildOb ject(ObjectLevelReadQuery.java:723)
at org.eclipse.persistence.queries.ReadAllQuery.registerResultI nUnitOfWork(ReadAllQuery.java:742)
at org.eclipse.persistence.queries.ReadAllQuery.executeObjectLe velReadQuery(ReadAllQuery.java:423)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute DatabaseQuery(ObjectLevelReadQuery.java:1080)
at org.eclipse.persistence.queries.DatabaseQuery.execute(Databa seQuery.java:808)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute (ObjectLevelReadQuery.java:1040)
at org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAll Query.java:383)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute InUnitOfWork(ObjectLevelReadQuery.java:1126)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.int ernalExecuteQuery(UnitOfWorkImpl.java:2842)
at org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1521)
at org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1503)
at org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1477)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.executeRea dQuery(EJBQueryImpl.java:484)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.getResultL ist(EJBQueryImpl.java:741)
at com.sun.enterprise.container.common.impl.QueryWrapper.getRes ultList(QueryWrapper.java:195)
Caused by: java.lang.IllegalArgumentException: object is not an instance of declaring class
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.persistence.internal.descriptors.MethodAttribute Accessor.getAttributeValueFromObject(MethodAttributeAccessor .java:82)
... 141 more
Any ideas? It was working on previous versions (2.0.1.v20100213-r6600)
Re: @AttributeOverrides gives me exception [message #665982 is a reply to message #665600] |
Mon, 18 April 2011 13:13 |
Seems to be a bug in the new protected cache in 2.2.
Please log this bug and vote for it. The issue is that aggregates are not being supported correctly, the parent cache key is used.
Normally the protected cache is not used however, definitely should not be used on anything that was support in 2.0, so this is odd.
The protected cache should only be used if you have enabled caching on some objects, and disabled it on others, have you done this? What cache settings have you set?
James : Wiki : Book : Blog : Twitter
Re: @AttributeOverrides gives me exception [message #666656 is a reply to message #665994] |
Thu, 21 April 2011 13:24 |
I assume that one of these objects has a reference to an object that you have disabled the cache on (or a reference to a reference). If you avoid having cached objects with references to non-cached objects, this should solve the issue.
You could try with all caching disabled, or all caching enabled to verify this is the cause of the error.
FUDForum. Page generated in 0.03187 seconds
