Home » Eclipse Projects » Plugin Development Environment (PDE) » init() method in Wizard not getting called(Problem in creating Wizard)
| init() method in Wizard not getting called [message #664860] |
Tue, 12 April 2011 06:31  |
I am trying to create a Wizard, My Wizard class looks like:
public class DocumentBasicView extends Wizard implements INewWizard {
I've defined some intialisation code for my Wizard Page in my "init()" method (overriding the IWorkbenchWizard class's init() method), like this:
public void init(IWorkbench workbench, IStructuredSelection selection) {
fpage = new BasicViewPage(workbench, selection);
After which, I add it in the "addPages()" method.
But, my init() method never gets called !! (as specified in the API)
Because of this, my Page remains uninitialized, and it throws a NullPointerException.
I absolutely require the init() method to be called, as my Page's initialisation requires the workbench and selection variables.
Can anybody help me out? Why isn't the init() method getting called?
I am using Eclipse version 3.6.2
I can post the full code, if anyone can help !!
| Re: init() method in Wizard not getting called [message #664869 is a reply to message #664860] |
Tue, 12 April 2011 06:40   |
> @Override
The init() method is called by the framework, if your wizard is
configured by extension point. I won't be automatically called, if you
start the wizard programmatically. So, if the method is not called, my
assumption is that you open the wizard by code instead. In this case it
is your responsibility to invoke init() at the right point in time,
because you have decided to define the life-cycle.
HTH & Greetings from Bremen,
Daniel Krügler
| Re: init() method in Wizard not getting called [message #664874 is a reply to message #664869] |
Tue, 12 April 2011 07:07   |
Thanks a lot for replying...
In that case, can you please guide me how should I use the Extension Point here? I tried it first, but failed.
I am designing a simple RCP actually, and just need a "File" menu (which I created using PDE via Extension Points) . In the File Menu, I want to add Commands, which can run my wizards. A structure like:
File
---Create New X Document
---Create New Y Document
---Exit
I created the Exit button, with the help of Online Tutorials.
I have written codes for Wizards X and Y. But just not getting the options in PDE to add a Wizard to the File Menu.
I'll be grateful if you tell me how can I do so.
Saurabh Srivastava,
IIT Kanpur, India
| Re: init() method in Wizard not getting called [message #664885 is a reply to message #664874] |
Tue, 12 April 2011 08:16   |
As described in the Eclipse help,
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/dialogs_wizards_newWizards.htm
the NewWizard extension point can be used, if you want to participate as
part of the File>New menu.
> File
> ---Exit
If you want to reuse the provided service for new-wizards, you should
try to follow the description given in the help quoted above, otherwise
you need to construct the dialog manually, including the invocation of
the init() function, if you really need it.
Daniel Krügler
Current Time: Sun Nov 09 12:38:03 EST 2025
Powered by FUDForum. Page generated in 0.10650 seconds
