Re: [EMF compare] [message #664951 is a reply to message #664383] |
Tue, 12 April 2011 15:06 |
You have to create your own implementation of an org.eclipse.emf.compare.diff.engine.GenericDiffEngine (simply extend the Generic one), and override its "getAttributeChecker' so that it returns your own implementation of the org.eclipse.emf.compare.diff.engine.check.AttributesCheck class, where you will override the "shouldBeIgnored(EAttribute)" method.
After that, override the "org.eclipse.emf.compare.diff.engine" extension point and provide your own engine to EMF Compare.
Laurent Goubet
Obeo
Re: [EMF compare] [message #665589 is a reply to message #664383] |
Fri, 15 April 2011 07:59 |
You do not call shouldBeIgnored. The EMF Compare core will call this method. You only override it and return either or for the EAttribute you are provided.
Laurent Goubet
Obeo
FUDForum. Page generated in 0.03114 seconds
