Home » Archived » BIRT » Nested tables/groups(Nested tables/groups with single xml source subdivided into data sets)
Nested tables/groups [message #663811] |
Wed, 06 April 2011 14:47 |
TerryWyatt01 Messages: 6 Registered: April 2011 |
I am pretty new to Birt and have been unable to find the solution to my problem yet.
I need nested tables that display a heirarchy like the following (see xml dataset at the bottom)
1) Table of Cases, each case containing
A) Table of CaseUsers, each case user containing
a) Table of Travel
B) Table of Actions, each Action containing
a) Table of Punishments
Is there an easy to maintain (hopefully drag and drop) way to read in a nested xml document (like the provided example) as a data source, and then map sub-portions of it as individual data sets? The goal is to implement grouping for each subset (Case, Action, CaseUser, Travel,
Punishment, etc.) to represent in nested tables.
I have been able to create the layout by adding the same data source several times, but this results in exponentially longer run times with each nested table, as Birt tries to retrieve the dataset for each and every xml tag (19 retrievals of the datasource for the provided xml sample).
The structure of this document will, in reality, be much more complex than the sample and currently (even at a more simple implementation) is unusable as the report runs for more than 30 minutes.
This type of XML representation is common, and it seems that this type of grouping should be easily available, but I am unable to get it to work properly. I have begun building scripted datasets, but that solution is not easily maintainable and I am hoping that I am just (currently) ignorant of a more elegant solution.
Any help would be appreciated.
<RowSet actionType="Action1">
<Case caseId="38930" dateClosed="10-Feb-2011" clientId="643412" clientName="Jake Foolish">
<Action actionCaseId="38930" dateServed="11-Nov-2010" adverseActionId="30" allegations="" actionTypeId="114" actionType="Action1">
<Punishment pAdverseActionId="30" pParagraph="Write I'm Sorry"/>
<Punishment pAdverseActionId="30" pParagraph="Another punishment"/>
<Punishment pAdverseActionId="30" pParagraph="50 Push-ups"/>
</Action>
</Case>
<Case caseId="80002" dateClosed="" clientId="99424" clientName="John Doe">
<CaseUser cuCaseId="80002" cuUserId="999242" cuDateAssigned="20-Oct-2010" cuDateRemoved="29-Oct-2010" cuNameFormatted="[Lawyer] Mrs. Hard Nose">
<Travel travelId="1234" location="Washington DC" purpose="Witness interview"/>
<Travel travelId="1372" location="Miami" purpose="Witness interview"/>
<Travel travelId="2366" location="Los Angeles" purpose="Consultation"/>
</CaseUser>
<CaseUser cuCaseId="80002" cuUserId="194263" cuDateAssigned="25-Oct-2010" cuDateRemoved="29-Oct-2010" cuNameFormatted="[Lawyer] Mr. Bleeding Heart">
</CaseUser>
<CaseUser cuCaseId="80002" cuUserId="224011" cuDateAssigned="01-Nov-2010" cuDateRemoved="01-Nov-2010" cuNameFormatted="[Paralegal] Goldie">
</CaseUser>
<Action actionCaseId="80002" dateServed="02-Nov-2010" adverseActionId="25" allegations="" actionTypeId="115" actionType="Action1">
<Punishment pAdverseActionId="25" pParagraph="Lots of Sit-ups."/>
<Punishment pAdverseActionId="25" pParagraph="30 lashes"/>
</Action>
<Action actionCaseId="80002" dateServed="01-Nov-2010" adverseActionId="26" allegations="" actionTypeId="114" actionType="Action1">
<Punishment pAdverseActionId="26" pParagraph="Imprisonment"/>
<Punishment pAdverseActionId="26" pParagraph="Solitary Confinement"/>
</Action>
</Case>
</RowSet>
Re: Nested tables/groups [message #663990 is a reply to message #663811] |
Thu, 07 April 2011 06:23 |
Terry
You should be able to do this using xml dataset parameters. Take a look
at the attached example. I used your data to write it. I have two
datasets one for cases and one for actions. The action dataset uses an
xml parameter to to retrieve the actions for a given case. In the
binding tab of the inner table I bind this parameter to the outer tables
caseid.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.6.2.r262_v20110209 Build <2.6.2.v20110214-1523></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.datatools.enablement.oda.xml" name="Data
Source" id="7">
<property name="FILELIST">C:\work\styles\cases.xml</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.datatools.enablement.oda.xml.dataSet "
name="cases" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">actionType</property>
<text-property
name="heading">actionType</text-property>
</structure>
<structure>
<property name="columnName">caseId</property>
<text-property name="heading">caseId</text-property>
</structure>
<structure>
<property name="columnName">clientId</property>
<text-property name="heading">clientId</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">actionType</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">caseId</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">clientId</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">actionType</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">caseId</property>
</structure>
<structure>
<property name="nativeName">clientId</property>
</structure>
</list-property>
<xml-property
name="queryText">< ![CDATA[table0#-TNAME-#table0#:#[/RowSet/Case]#:#{actionType ;STRING;../@actionType},{caseId;STRING;/@caseId},{clientId;S TRING;/@clientId}]] ></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>2.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:identifier>
<design:name>actionType</design:name>
<design:position>1</design:position>
</design:identifier>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>-1</design:precision>
<design:scale>-1</design:scale>
<design:nullability>Unknown</design:nullability>
</design:attributes>
<design:usageHints>
<design:label>actionType</design:label>
<design:formattingHints/>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:identifier>
<design:name>caseId</design:name>
<design:position>2</design:position>
<design:usageHints>
<design:label>caseId</design:label>
<design:attributes>
<design:identifier>
<design:name>clientId</design:name>
<design:position>3</design:position>
<design:usageHints>
<design:label>clientId</design:label>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
<list-property name="privateDriverProperties">
<ex-property>
<name>MAX_ROW</name>
<value>-1</value>
</ex-property>
<ex-property>
<name>XML_FILE</name>
</ex-property>
</list-property>
</oda-data-set>
<oda-data-set
name="actions" id="9">
<structure>
<property name="columnName">actionCaseId</property>
<text-property
name="heading">actionCaseId</text-property>
</structure>
<structure>
<property name="columnName">dateServed</property>
<text-property
name="heading">dateServed</text-property>
</structure>
<structure>
<property name="columnName">adverseActionId</property>
<text-property
name="heading">adverseActionId</text-property>
</structure>
</list-property>
<list-property name="parameters">
<structure>
<property name="name">p1</property>
<property name="nativeName">p1</property>
<property name="dataType">integer</property>
<expression name="defaultValue"
type="javascript">80002</expression>
<property name="isOptional">false</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
</list-property>
<structure>
<property name="name">actionCaseId</property>
</structure>
<structure>
<property name="name">dateServed</property>
</structure>
<structure>
<property name="name">adverseActionId</property>
</structure>
</list-property>
</structure>
<structure>
<property name="nativeName">actionCaseId</property>
</structure>
<structure>
<property name="nativeName">dateServed</property>
</structure>
<structure>
<property name="nativeName">adverseActionId</property>
</structure>
</list-property>
<xml-property
name="queryText">< ![CDATA[table0#-TNAME-#table0#:#[/RowSet/Case/Action[@action CaseId= "{?p1?}" ]]#:#{actionCaseId;STRING;/@actionCaseId},{dateServed;STRING ;/@dateServed},{adverseActionId;STRING;/@adverseActionId}]] ></xml-property>
<model:DesignValues
<DataSetParameters>
<parameter>
<design:ParameterDefinition>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
<design:identifier>
<design:name>p1</design:name>
<design:inputAttributes>
<design:elementAttributes>
<design:defaultValues>
<design:values>CustomData value: 80002, displayValue:
null</design:values>
</design:defaultValues>
</design:elementAttributes>
</design:inputAttributes>
</design:ParameterDefinition>
</parameter>
</DataSetParameters>
<design:attributes>
<design:identifier>
<design:name>actionCaseId</design:name>
<design:usageHints>
<design:label>actionCaseId</design:label>
<design:attributes>
<design:identifier>
<design:name>dateServed</design:name>
<design:usageHints>
<design:label>dateServed</design:label>
<design:attributes>
<design:identifier>
<design:name>adverseActionId</design:name>
<design:usageHints>
<design:label>adverseActionId</design:label>
<design:criteria/>
<ex-property>
<value>-1</value>
</ex-property>
<ex-property>
</ex-property>
</list-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
<style name="table-header" id="80">
<property name="backgroundColor">#6078BF</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">small</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
<property name="paddingTop">0px</property>
<property name="paddingLeft">0px</property>
<property name="paddingBottom">0px</property>
<property name="paddingRight">0px</property>
</style>
<style name="table-footer" id="81">
</style>
<style name="table-detail" id="82">
<property name="backgroundColor">#E6ECFF</property>
<property name="fontSize">x-small</property>
<property name="color">#000080</property>
</style>
<style name="table-group-header-1" id="83">
<property name="backgroundColor">#809FFF</property>
</style>
<style name="table-group-footer-1" id="84">
<property name="backgroundColor">#C0C0C0</property>
</style>
<style name="special-header" id="85">
<property name="fontSize">medium</property>
</style>
<style name="crosstab-detail" id="86">
</style>
<style name="crosstab-header" id="87">
</style>
<style name="mydata" id="88">
<property name="color">orange</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="10">
<property name="width">7.947916666666667in</property>
<property name="dataSet">cases</property>
<list-property name="boundDataColumns">
<structure>
<text-property
name="displayName">actionType</text-property>
<expression name="expression"
type="javascript">dataSetRow["actionType"]</expression>
</structure>
<structure>
<text-property
name="displayName">caseId</text-property>
type="javascript">dataSetRow["caseId"]</expression>
</structure>
<structure>
<text-property
name="displayName">clientId</text-property>
type="javascript">dataSetRow["clientId"]</expression>
</structure>
</list-property>
<column id="29">
<property name="width">1.2291666666666667in</property>
</column>
<column id="30">
<property name="width">1in</property>
</column>
<column id="31">
<property name="width">1.1875in</property>
</column>
<column id="35">
<property name="width">4.53125in</property>
</column>
<header>
<row id="11">
<cell id="12">
<label id="13">
<text-property
name="text">actionType</text-property>
</label>
</cell>
<cell id="14">
<label id="15">
<text-property
name="text">caseId</text-property>
</label>
</cell>
<cell id="16">
<label id="17">
<text-property
name="text">clientId</text-property>
</label>
</cell>
<cell id="32"/>
</row>
</header>
<detail>
<row id="18">
<cell id="19">
<data id="20">
<property name="whiteSpace">nowrap</property>
<property
name="resultSetColumn">actionType</property>
</data>
</cell>
<cell id="21">
<data id="22">
<property
name="resultSetColumn">caseId</property>
</data>
</cell>
<cell id="23">
<data id="24">
<property
name="resultSetColumn">clientId</property>
</data>
</cell>
<cell id="33">
<table id="58">
<property name="dataSet">actions</property>
<list-property name="paramBindings">
<structure>
<property
name="paramName">p1</property>
<simple-property-list
name="expression">
<value
type="javascript">row["caseId"]</value>
</simple-property-list>
</structure>
</list-property>
<structure>
<property
<text-property
name="displayName">actionCaseId</text-property>
type="javascript">dataSetRow["actionCaseId"]</expression >
<property
</structure>
<structure>
<property
<text-property
name="displayName">dateServed</text-property>
type="javascript">dataSetRow["dateServed"]</expression>
<property
</structure>
<structure>
<property
<text-property
name="displayName">adverseActionId</text-property>
type="javascript">dataSetRow["adverseActionId"]</expression >
<property
</structure>
</list-property>
<column id="77"/>
<column id="78"/>
<column id="79"/>
<header>
<row id="59">
<cell id="60">
<label id="61">
<text-property
name="text">actionCaseId</text-property>
</label>
</cell>
<cell id="62">
<label id="63">
<text-property
name="text">dateServed</text-property>
</label>
</cell>
<cell id="64">
<label id="65">
<text-property
name="text">adverseActionId</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="66">
<cell id="67">
<data id="68">
<property
<property
name="resultSetColumn">actionCaseId</property>
</data>
</cell>
<cell id="69">
<data id="70">
<property
<property
name="resultSetColumn">dateServed</property>
</data>
</cell>
<cell id="71">
<data id="72">
<property
<property
name="resultSetColumn">adverseActionId</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="73">
<cell id="74"/>
<cell id="75"/>
<cell id="76"/>
</row>
</footer>
</table>
</cell>
</row>
</detail>
<footer>
<row id="25">
<cell id="26"/>
<cell id="27"/>
<cell id="28"/>
<cell id="34"/>
</row>
</footer>
</table>
</body>
</report>
> problem yet.
> a) Table of Travel
> sample).
> </Action>
> </Case>
> interview"/>
> </CaseUser>
> </CaseUser>
> </CaseUser>
> </Action>
> </Action>
> </Case>
> </RowSet>
Re: Nested tables/groups [message #664123 is a reply to message #663990] |
Thu, 07 April 2011 14:38 |
Jason,
Thank you for the quick response.
While your proposed solution does structure the nested tables properly, it still accesses the data source once for each case (plus this initial read).
If this is a static file, it is not too noticeable, but this XML document is output from a database stored procedure that takes about 2-3 seconds to run. When you start multiplying that access time for each row in each nested table, the execution time quickly climbs to where the report will not come back.
When testing this on live data, I get 14 separate URL requests for one execution of the Birt report that contains 11 cases, for a total run time of about 30 seconds. This is only a small subset of what will be hit when it goes to production, and it is currently only nested one level deep to the Actions level. I'll need this to go maybe 4 or 5 levels deep for several times as many rows.
What I need to do is define the Data Source of the ActionDataSet as the /Action xpath of the Case Data Set (which should translate to /RowSet/Case/Action). The desired result would be that Birt should only access the XML page URL once and will then parse the document into separate Data Sets that I can use for separate tables. It doesn't matter if I get all actions as I can bind to keys in outer tables to filter the results out, as long as it does not try to retrieve the Data Source again.
I hope that explains my problem more clearly.
Re: Nested tables/groups [message #664276 is a reply to message #664123] |
Fri, 08 April 2011 08:33 |
Terry,
I revised the report to not use parameters but a filter on the inner
table. Can you test this approach?
Jason
id="1">
<data-sources>
<oda-data-source
Source" id="7">
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
<text-property
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<xml-property
<model:DesignValues
<design:attributes>
<design:identifier>
<design:usageHints>
<design:attributes>
<design:identifier>
<design:usageHints>
<design:attributes>
<design:identifier>
<design:usageHints>
<design:criteria/>
<ex-property>
<value>-1</value>
</ex-property>
<ex-property>
</ex-property>
</list-property>
</oda-data-set>
<oda-data-set
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<xml-property
name="queryText">< ![CDATA[table0#-TNAME-#table0#:#[/RowSet/Case/Action]#:#{act ionCaseId;STRING;/@actionCaseId},{dateServed;STRING;/@dateSe rved},{adverseActionId;STRING;/@adverseActionId}]] ></xml-property>
<model:DesignValues
<design:attributes>
<design:identifier>
<design:usageHints>
<design:attributes>
<design:identifier>
<design:usageHints>
<design:attributes>
<design:identifier>
<design:usageHints>
<design:criteria/>
<ex-property>
<value>-1</value>
</ex-property>
<ex-property>
</ex-property>
</list-property>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<table id="10">
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<column id="29">
</column>
<column id="30">
</column>
<column id="31">
</column>
<column id="35">
</column>
<header>
<row id="11">
<cell id="12">
<label id="13">
<text-property
</label>
</cell>
<cell id="14">
<label id="15">
<text-property
</label>
</cell>
<cell id="16">
<label id="17">
<text-property
</label>
</cell>
<cell id="32"/>
</row>
</header>
<detail>
<row id="18">
<cell id="19">
<data id="20">
<property
</data>
</cell>
<cell id="21">
<data id="22">
<property
</data>
</cell>
<cell id="23">
<data id="24">
<property
</data>
</cell>
<cell id="33">
<table id="58">
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
</list-property>
<list-property name="filter">
<structure>
<property name="operator">eq</property>
<expression name="expr"
type="javascript">row["actionCaseId"]</expression>
<simple-property-list name="value1">
<value>row._outer["caseId"]</value>
</structure>
</list-property>
<column id="77"/>
<column id="78"/>
<column id="79"/>
<header>
<row id="59">
<cell id="60">
<label id="61">
<text-property
</label>
</cell>
<cell id="62">
<label id="63">
<text-property
</label>
</cell>
<cell id="64">
<label id="65">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="66">
<cell id="67">
<data id="68">
<property
<property
</data>
</cell>
<cell id="69">
<data id="70">
<property
<property
</data>
</cell>
<cell id="71">
<data id="72">
<property
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="73">
<cell id="74"/>
<cell id="75"/>
<cell id="76"/>
</row>
</footer>
</table>
</cell>
</row>
</detail>
<footer>
<row id="25">
<cell id="26"/>
<cell id="27"/>
<cell id="28"/>
<cell id="34"/>
</row>
</footer>
</table>
</body>
</report>
On 4/7/2011 10:38 AM, Terry wrote:
> Jason,
> read).
Re: Nested tables/groups [message #664847 is a reply to message #664741] |
Tue, 12 April 2011 09:22 |
Terry,
Can you try one more. Take a look at the attached report. For the
nested actions table I placed it at the top of the report which should
cause it to only run once and cache the data. I then filter an instance
of the data in the nested table for each row of the outer table. If you
look at the binding tab of the inner table I have bound it to the table
at the top of the report. The table at the top of the report I named
and turned off the visibility for it.
Jason
id="1">
<data-sources>
<oda-data-source
Source" id="7">
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
<text-property
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<xml-property
<model:DesignValues
<design:attributes>
<design:identifier>
<design:usageHints>
<design:attributes>
<design:identifier>
<design:usageHints>
<design:attributes>
<design:identifier>
<design:usageHints>
<design:criteria/>
<ex-property>
<value>-1</value>
</ex-property>
<ex-property>
</ex-property>
</list-property>
</oda-data-set>
<oda-data-set
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<method name="beforeOpen"><![CDATA[importPackage(
Packages.java.io );
out = new PrintWriter( new FileWriter( "c:/test/xmldsevents.txt", true ) );
out.println( "beforeopen");
out.close();]]></method>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<xml-property
<model:DesignValues
<design:attributes>
<design:identifier>
<design:usageHints>
<design:attributes>
<design:identifier>
<design:usageHints>
<design:attributes>
<design:identifier>
<design:usageHints>
<design:criteria/>
<ex-property>
<value>-1</value>
</ex-property>
<ex-property>
</ex-property>
</list-property>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<table id="111">
<list-property name="visibility">
<structure>
<property name="format">all</property>
<expression name="valueExpr"
type="javascript">true</expression>
</structure>
</list-property>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<column id="130"/>
<column id="131"/>
<column id="132"/>
<header>
<row id="112">
<cell id="113">
<label id="114">
<text-property
</label>
</cell>
<cell id="115">
<label id="116">
<text-property
</label>
</cell>
<cell id="117">
<label id="118">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="119">
<cell id="120">
<data id="121">
<property
</data>
</cell>
<cell id="122">
<data id="123">
<property
</data>
</cell>
<cell id="124">
<data id="125">
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="126">
<cell id="127"/>
<cell id="128"/>
<cell id="129"/>
</row>
</footer>
</table>
<table id="10">
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<column id="29">
</column>
<column id="30">
</column>
<column id="31">
</column>
<column id="35">
</column>
<header>
<row id="11">
<cell id="12">
<label id="13">
<text-property
</label>
</cell>
<cell id="14">
<label id="15">
<text-property
</label>
</cell>
<cell id="16">
<label id="17">
<text-property
</label>
</cell>
<cell id="32"/>
</row>
</header>
<detail>
<row id="18">
<cell id="19">
<data id="20">
<property
</data>
</cell>
<cell id="21">
<data id="22">
<property
</data>
</cell>
<cell id="23">
<data id="24">
<property
</data>
</cell>
<cell id="33">
<table id="58">
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
</list-property>
<structure>
</structure>
</list-property>
<column id="77"/>
<column id="78"/>
<column id="79"/>
<header>
<row id="59">
<cell id="60">
<label id="61">
<text-property
</label>
</cell>
<cell id="62">
<label id="63">
<text-property
</label>
</cell>
<cell id="64">
<label id="65">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="66">
<cell id="67">
<data id="68">
<property
<property
</data>
</cell>
<cell id="69">
<data id="70">
<property
<property
</data>
</cell>
<cell id="71">
<data id="72">
<property
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="73">
<cell id="74"/>
<cell id="75"/>
<cell id="76"/>
</row>
</footer>
</table>
</cell>
</row>
</detail>
<footer>
<row id="25">
<cell id="26"/>
<cell id="27"/>
<cell id="28"/>
<cell id="34"/>
</row>
</footer>
</table>
</body>
</report>
On 4/11/2011 3:12 PM, Terry wrote:
> The following are the Apache logs (some login info edited) from my
> execution of your report:
> 192.168.xx.xxx - myUserId [11/Apr/2011:13:58:07 -0500] "GET
> /appFolder/CASE_LIST?CaseDateType=C&StartDate=01-Jan-200
> 9&EndDate=31-Dec-2010&ActionTypeId=110044 HTTP/1.1" 200 36111
> 192.168.xx.xxx - myUserId [11/Apr/2011:13:58:21 -0500] "GET
> 192.168.xx.xxx - myUserId [11/Apr/2011:13:58:24 -0500] "GET
> 192.168.xx.xxx - myUserId [11/Apr/2011:13:58:26 -0500] "GET
> 192.168.xx.xxx - myUserId [11/Apr/2011:13:58:28 -0500] "GET
> 192.168.xx.xxx - myUserId [11/Apr/2011:13:58:30 -0500] "GET
> 192.168.xx.xxx - myUserId [11/Apr/2011:13:58:32 -0500] "GET
> 192.168.xx.xxx - myUserId [11/Apr/2011:13:58:34 -0500] "GET
> 192.168.xx.xxx - myUserId [11/Apr/2011:13:58:35 -0500] "GET
> 192.168.xx.xxx - myUserId [11/Apr/2011:13:58:38 -0500] "GET
> 192.168.xx.xxx - myUserId [11/Apr/2011:13:58:40 -0500] "GET
> 192.168.xx.xxx - myUserId [11/Apr/2011:13:58:42 -0500] "GET
> 192.168.xx.xxx - myUserId [11/Apr/2011:13:58:43 -0500] "GET
> 192.168.xx.xxx - myUserId [11/Apr/2011:13:58:45 -0500] "GET
> 192.168.xx.xxx - myUserId [11/Apr/2011:13:58:46 -0500] "GET
> The goal is only one hit on the server, but to still be able to break
> out the resulting XML document into multiple data sets for ease of use.
> Thanks in advance,
> Terry
Re: Nested tables/groups [message #665395 is a reply to message #664925] |
Thu, 14 April 2011 14:02 |
Can you open a bugzilla entry for this?
Jason
On 4/12/2011 10:00 AM, Terry wrote:
> That actually seems to be about twice as bad (27 hits vs. 15).
> Log below:
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:44:50 -0500] "GET
> 9&EndDate=31-Dec-2010&ActionTypeId=144 HTTP/1.1" 200 13953
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:44:53 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:44:54 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:44:56 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:44:58 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:44:59 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:01 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:02 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:06 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:08 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:10 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:12 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:13 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:16 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:18 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:20 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:22 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:24 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:26 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:27 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:29 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:31 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:33 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:35 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:38 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:41 -0500] "GET
> 192.168.xx.xxx - myUserId [12/Apr/2011:08:45:43 -0500] "GET
> It would be ideal (maybe a future enhancement idea) to be able to choose
> another data set as the data source of another data set.
> You would then be able to define an XPath relative to the content of the
> referenced (dataSet as dataSource).
Current Time: Fri Apr 26 05:23:23 GMT 2024
Powered by FUDForum. Page generated in 0.04952 seconds
