Feature Request - Atomic Checkins across Eclipse Projects [message #663406] |
Mon, 04 April 2011 21:31 |
Steve Cohen Messages: 46 Registered: July 2009 |
Member |
When checking in files across multiple Eclipse projects with subversive, the checkins of each project get different revision numbers. I used to use subclipse and although I prefer subversive in general, this was one area where subclipse stood out - it offers this feature and if memory serves, this was explained to me as a subclipse extra not supported in SVN itself. I was noticing that over the past year, about the time frame when I made the switch, I am burning through revision numbers much more rapidly than I used to. Not that that matters - revision numbers are, of course, free - what matters is the ability to have commits made in the same action have the same version number. Without that, the commits are not truly atomic.
This is a frequent use case for me. Atomic commits should not care which project they live in. And in my case even the justification that SVN doesn't natively support checkins across projects doesn't hold water. My scheme is multiple eclipse/maven projects all under one SVN uber-project in which each eclipse project is represented in SVN as a subdirectory of the uber-project.
But whether one uses an SVN uber-project or not, being able to commit across projects with a single revision number is a nice feature to have and a legitimate feature request.
Or am I just missing a setting somewhere?
[Updated on: Mon, 04 April 2011 21:34] Report message to a moderator
Re: Feature Request - Atomic Checkins across Eclipse Projects [message #753922 is a reply to message #753827] |
Sun, 30 October 2011 15:44 |
dan carter Messages: 3 Registered: October 2011 |
olly2 wrote on Fri, 28 October 2011 23:26Well,
Comming back to the problem: you must understand the basic working principles of SVN - and this includes "one commit per WC".
Yes i understand this, and my complaint is that subversive with JavaHL does not allow this.
SVN is perfectly capable of committing two sub directories in the same WC in one commit, but where those two subdirectories are eclipse projects, opened as projects in the eclipse workspace, subversive is not able to follow this fundamental SVN principle.
From my subversive checkout, i can edit files in eclipse, then use tortoise or svn on the eclipse workspace to commit attomically. But if you use subversive to commit you get one commit per project.
I have uninstalled subversive, and installed subclipse. From the same workspace/checkout, subclipse is able to commit atomically using JavaHL.
I've raised an enhancement request, but for now subclipse does everything i need.
bugzilla 362182
FUDForum. Page generated in 0.04488 seconds
