Re: [EMF COMPARE] [message #665083 is a reply to message #663304] |
Wed, 13 April 2011 08:38 |
The extension point that allows you to contribute your own diff engine allows you to specify a priority; though this priority will only be used if there are more than one engine available for the models you're trying to compare.
Alternately, you could go to Window > Preferences > EMF Compare and tick "comparison engine selection". This will make EMF Compare display a dialog when you compare the models so that you can select the diff engine yourself. If it does not appear on the dialog's list, then that particular engine is not available for these models; and you probably made an error in the plugin.xml when you filled in the extension point's description .
Laurent Goubet
Obeo
FUDForum. Page generated in 0.03353 seconds
