Home » Eclipse Projects » Rich Client Platform (RCP) » Eclipse and Java FX
Eclipse and Java FX [message #662996] Fri, 01 April 2011 16:50 Go to next message
Hi guys, i am university student and i'll build a application with Java
FX for my teacher,
i have this problem
i see this web page for intall Eclipse and the Eclipse plugin for JavaFX
http://download.oracle.com/javafx/1.2/gettingstarted/eclipse -plugin/index.html#downloadinfo
but when i create a sample project i have this error (i do this: open
Eclipse, New->JavaFX->JavaFX Project)
"A valid JavaFX SDK was not detected in the JAVAFX_HOME location. press
OK to the setup now, or cancel to ingnore this massage permanently
reason:
a valid JavaFx SDK was not Detected"
i put this path
C:/Program Files (x86)/JavaFX/javafx-sdk1.3/bin
but don't work,
if i go in prompt i do c:\>javafx -version
this command work well (it's write javafx 1.3.1_b101)
this is my path
C:\Program Files (x86)\JavaFX\javafx-sdk1.3\bin;C:\Program Files
(x86)\JavaFX\javafx-sdk1.3\emulator\bin;C:\Program Files (x86)\PC
Connectivity
Solution\;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\Sy stem32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C: \Program
Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files
(x86)\Common Files\Roxio Shared\9.0\DLLShared\;C:\Program Files
(x86)\Toshiba\Bluetooth Toshiba Stack\sys\;C:\Program Files
(x86)\Toshiba\Bluetooth Toshiba Stack\sys\x64\;C:\Program Files
(x86)\QuickTime\QTSystem\
I use windows 7 (64 bit);
Eclipse Java EE IDE for Web Developers.
Version: Helios Service Release 2
Build id: 20110218-0911
thx for all people
Best regads
Antonio
Re: Eclipse and Java FX [message #663240 is a reply to message #662996] Mon, 04 April 2011 08:14 Go to previous message
> FX for my teacher,
> i have this problem
> reason:
Your message seems to imply that you needed to set JAVAFX_HOME in your
env before you launch eclipse.
If that's the case, hopefully the javafx plugin installation and getting
started should mention it.
If not, please ask in the javafx plugin forum/mailing list.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Fold view
Next Topic:Views placement in one perspective
Current Time: Sun Nov 09 09:08:13 EST 2025
Powered by FUDForum. Page generated in 0.03999 seconds
