[Debugging Ecore model loading] code execution hangs in debug mode [message #662396] |
Wed, 30 March 2011 14:29 |
leonard.krpan Messages: 20 Registered: March 2011 |
I have two Ecore models that I'm loading before further processing. These models are quite similar (they latter one is an evolved version of the former one, hence the structure is slightly different and it's possibly somewhat larger). When I execute the code they load just fine, however when I debug the code (actually I'm trying to debug the processing part but got stuck before it was even reached) the first model takes up to a minute to load, whereas the other one didn't load in over 10 minutes and just keeps hanging. I've come as far as parser.parse(inputSource, handler) call on line 181 in the XMLLoadImpl class.
Also, when I try to debug the previous version model of the former model from above and the former model from above, they both load promptly.
I have never encountered a problem like this before and I'm totally clueles...???
EDIT: seems to be working again. During one "hanging" session, I tried pausing and moving on by hand (by pressing step over) and that seems to have woken it up...
[Updated on: Wed, 30 March 2011 15:17] Report message to a moderator
Re: [Debugging Ecore model loading] code execution hangs in debug mode [message #662449 is a reply to message #662396] |
Wed, 30 March 2011 17:05 |
Ed Merks Messages: 33142 Registered: July 2009 |
Note that your EMF questions about the core framework should really be
directed to the eclipse.tools.emf newsgroup/forum. More comments below.
lk_muc wrote:
> Hello,
> XMLLoadImpl class.
I've never seen an Ecore model that's so big it takes that long to
load. Perhaps you've set a bunch of breakpoints with complex conditions
that never end up being true...
> promptly.
> clueles...???
You know you can let the debugger run and then pause. At that point you
can see what all the different threads are doing to get a sense of where
it's spending all the time.
Ed Merks
FUDForum. Page generated in 0.02716 seconds
