Home » Archived » Tycho » config.ini - osgi.splashPath
config.ini - osgi.splashPath [message #662297] Wed, 30 March 2011 03:37 Go to next message
I build an RCP application with Tycho. I originally use Tycho 1.10.0, and the eclipse-application packaging.
All is working well... except the splash screen which is not shown. The issue is that the osgi.splashPath property in the config.ini generated by tycho is incorrect !
It is :
osgi.splashPath=platform\:/base/plugins/com
Instead of :
osgi.splashPath=platform\:/base/plugins/com.my.plugin
It seams to be a known bug, as a 'split' is done on the first dot instead of the last one.
However, I've tried to use Tycho 1.11.0 but this doesn't correct this issue !
Thus, what can I do ? Is the packaging eclipse-application deprecated ? I've found some topics about the eclipse-repository packaging, but I'm not sure that it corresponds to my need. Any info ?
Re: config.ini - osgi.splashPath [message #662311 is a reply to message #662297] Wed, 30 March 2011 04:28 Go to previous message
eclipse-application will be overhauled for the next release [1]
for now you should try eclipse-repository.
See an example with working splash screen [2] screen from our EclipseCon
tutorial [3].
Jan
[1]
https://docs.sonatype.org/display/TYCHO/Discussion+on+eclips e-repository+packaging+type+clean-up
[2]
https://github.com/jsievers/tycho-demo/tree/master/exercises /Exercise_05_Solution
[3] http://www.eclipsecon.org/2011/sessions/?page=sessions&i d=2049
"jod" <jod@all4tec.net> wrote in message
news:imum6d$ivd$1@news.eclipse.org...
> It is :
> Instead of :
> of the last one.
> issue !
Previous Topic:EMF code-generation in maven builds?
Next Topic:Build with specific folders
Current Time: Sat Nov 08 13:05:09 EST 2025
Powered by FUDForum. Page generated in 0.03355 seconds
