[CDO] SQL query results [message #662162] |
Tue, 29 March 2011 11:00  |
I would like to run SQL queries on the CDO store and return several columns from the database. Unfortunately the CDOQuery returns only the first column when running the query.
Is there a reason why the SQLQueryHandler returns only the first column as a result of an SQL query even if not a CDO object query is run (SQLQueryHandler.CDO_OBJECT_QUERY is set to false)?
The code that returns the result in SQLQueryHandler.executeQuery() is the following:
if (objectQuery)
CDOID result = idHandler.getCDOID(resultSet, 1);
context.addResult(result);
else
Object result = resultSet.getObject(1);
Would it make sense to change it to something like this?
if (objectQuery)
else
int columnCount = resultSet.getMetaData().getColumnCount();
if (columnCount == 1)
else
Object[] results = new Object[columnCount];
for (int i = 0; i < columnCount; i++)
results[i] = resultSet.getObject(i+1);
context.addResult(results);
If the query is not a CDOObject query, the client is probably interested in all of the queried fields.
Szabolcs
FUDForum. Page generated in 0.03235 seconds
