ERROR Resource '/.buckminster/tp' is not local. [message #662122] |
Tue, 29 March 2011 12:51 |
The first buckminster import in a fresh hudson workspace always ends in error: ERROR Resource '/.buckminster/tp' is not local.
Subsequent builds run fine. I want to start from a clean workspace because the build job needs to do imports based on a parameter.
I am using the latest jenkins with the 1.0.8 buckminster plugin and buckminster 3.6.
Please see [1] for a discussion with the same problem (2009) [2] for the error and [3] for the contents of commands.txt
Thanks for helping
Wim Jongman
[1] http://www.eclipse.org/forums/index.php?t=msg&S=b40201be b1a115ea7927e4b509014596&th=206630&goto=661584#msg_6 61584
[2]
[workspace] $ /home/gravity/.hudson/tools/java6.24/bin/java -Dbuckminster.output.root=/home/gravity/.hudson/jobs/Gravity _Update_Site/workspace/buckminster.output -Dbuckminster.temp.root=/home/gravity/.hudson/jobs/Gravity_U pdate_Site/workspace/buckminster.temp -Xmx512m -Declipse.p2.mirrors=false -jar /home/gravity/.hudson/tools/bucky36/buckminster/plugins/org. eclipse.equinox.launcher_1.1.0.v20100507.jar -application org.eclipse.buckminster.cmdline.headless -data /home/gravity/.hudson/jobs/Gravity_Update_Site/workspace --loglevel error -S /home/gravity/.hudson/jobs/Gravity_Update_Site/workspace/com mands.txt
[3]
import /home/gravity/.hudson/jobs/Gravity_Update_Site/workspace/rel eng/com.remainsoftware.gravity.site.feature/gravity.cquery
Re: ERROR Resource '/.buckminster/tp' is not local. [message #662129 is a reply to message #662122] |
Tue, 29 March 2011 13:02 |
Hi Wim,
This bug has been addressed and pushed to our repositories fairly recently (on March 23). See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=310850
So your Jenkins is probably not using the latest Buckminster 3.6.
Thomas Hallgren
On 2011-03-29 14:51, Wim Jongman wrote:
> local.
> parameter.
> Thanks for helping
> Wim Jongman
> [2]
> [3]
FUDForum. Page generated in 0.03088 seconds
