Home » Eclipse Projects » Eclipse 4 » Some questions about logging
Some questions about logging [message #662013] Mon, 28 March 2011 17:17 Go to next message
I apologize for re-posting this in the right forum. I accidentally posted it in an inappropriate forum before.
In e4 there are two ways to log something:
  • The org.eclipse.e4.core.services.log.Logger
  • The org.osgi.service.log.LogService
As far as I understand it, these two things seem to be related in the sense that the first uses the second, i.e. the org.eclipse.e4.core.services.log.Logger uses the org.osgi.service.log.LogService. Is this correct?
I observed at least the following: If an RCP application uses some pure OSGi bundles that do not know anything but the OSGi specification and, thus, use the LogService, the messages end up in the same log file as the messages generated with the Logger. Is this part of the eclipse "API", i.e. will this always be the case, or is this a mere "accident"?
If this behaviour is intended, I do not understand why the OSGi specification is not strictly implemented: The LogService has two kinds of logging methods, e.g.
// first way
fLogService.log(LogService.LOG_ERROR, "This is my first log message");
//second way
fLogService.log(serviceReference, LogService.LOG_ERROR, "This is my first log message");
If I did not make a(nother) mistake, the LogEntry in the log file does not contain any service reference. I am no OSGi expert, but wouldn't this be a violation of the OSGi specification? Someone could get the log entries via org.osgi.service.log.LogReaderService.getLog(). This should return the log entries from the log file. The OSGi specification does not require this method to return all log entries. But I would expect that the log entries it does return are "complete".
Another point is that log entries created with the LogService correctly show the originating bundle while log entries created with the Logger all seem to show the bundle org.eclipse.e4.ui.workbench. This should be a bug or shouldn't it?
Or am I all wrong about this logging?
Re: Some questions about logging [message #662027 is a reply to message #662013] Mon, 28 March 2011 18:54 Go to previous messageGo to next message
Hi Karl,
I worked on the logging stuff some time before the 4.0 release to only
make it a bit more useable.
The logger you are seeing is the one the org.eclipse.e4.ui.workbench
injected into to context. Instead you should inject yourself the
ILoggerProvider which allows you to create a specific logger for this
class similar to the Logger.getLogger() works in case of log4j.
The API of the Logger we provide does NOT necessarily use the
OSGi-LogService (our default implementation though does) but should be
able to get replaced e.g. through log4j, ... .
Tom
Am 28.03.11 14:17, schrieb Karl Weber:
> // first way
> //second way
Re: Some questions about logging [message #667657 is a reply to message #662013] Sat, 30 April 2011 14:13 Go to previous messageGo to next message
Karl Weber wrote on Mon, 28 March 2011 23:17
I am not happy with Equinox's LogService, i.e. the stuff in org.eclipse.equinox.log.
One can disable this log service with the property -Dosgi.hook.configurators.exclude=org.eclipse.core.runtime.i nternal.adaptor.EclipseLogHook
Then one can provide one's own log service as a DS implementing the interface org.osgi.service.log.LogService.
This works pretty well in a pure OSGi Application, however it does not work with an e4 RCP application. I get the exception
osgi> org.eclipse.osgi Application error
org.eclipse.e4.core.di.InjectionException: Unable to process "WorkbenchLogger#setFrameworkLog()": no actual value was found for the argument "FrameworkLog".
So something seems still missing. Could you give me some help about what I have to implement in addition?
Re: Some questions about logging [message #667917 is a reply to message #667657] Mon, 02 May 2011 14:46 Go to previous messageGo to next message
It seems to me as though our Logger subclass expects a FrameworkLog instance (and not a LogService instance) to be available for it to function.
Re: Some questions about logging [message #670928 is a reply to message #667917] Mon, 16 May 2011 05:03 Go to previous messageGo to next message
I've been working on logging in e4 the last few days. The task was to combine different legacy loggings in a single configuration. This wonderfull blog helped a lot:
http://ekkescorner.wordpress.com/blog-series/osgi-apps/
Greetings,
Christoph
Re: Some questions about logging [message #671104 is a reply to message #670928] Mon, 16 May 2011 15:11 Go to previous messageGo to next message
Are there chance you could share your work with us?
Tom
Am 16.05.11 11:03, schrieb Christoph Keimel:
> Hello,
> Greetings,
> Christoph
Re: Some questions about logging [message #671673 is a reply to message #671104] Wed, 18 May 2011 12:23 Go to previous messageGo to next message
Certainly Smile The exercise was to combine different kinds of logging under one framework. This way you can configure the logging in one single place. After following the blog mentioned above (thanks ekke!) I got a solution which satisfies this criteria.
A) SLF4J is used as Logging-API (with logback as implementation)
B) An ILoggerProvider is registered for e4 to use SL4J
C) java.util.Logging is rerouted to SLF4J with the SLF4JBridgeHandler
D) OSGI Logging is rerouted to SLF4J with de.emsw.osgi.log.over.slf4j
E) The configuration in done in the fragement de.emsw.gosa.logback.config
There is a lot to say about this, so please have a look at the projects attached. Start with de.emsw.gosa.product.logtest.LogTestPlugin (the Bundle Activator).
1) de.emsw.gosa.product.logtest
e4 Projekt with a part to enter Log Entries with different frameworks
2) de.emsw.gosa.logback.config
Fragement to configure the central logging framework (logback)
3) LogTarget
Target plug-ins to use
The plug-ins in LogTarget:
a) logback
The central logging framework; a native implementation of slf4j
see: Logback
The bundles were downloaded from springsource
b) slf4j
SLF4J libraries
see: SLF4J
I have not tested the jcl- and log4j-bridges because I do not need them. I have included the libraries in the sl4j folder, so you can include them if you wish.
One more notion to de.emsw.osgi.log.over.slf4j: I have renamed this plugin because I have stripped it's core to "just" rerouting the osgi log entries. Most of the code comes from Ekkehard Gentz who released it under the EPL. I'm new to public licenses, so I hope I repackaged it correctly. If not: Please give me a hint on how to do it properly.
Christoph
Re: Some questions about logging [message #674893 is a reply to message #671673] Sun, 29 May 2011 05:44 Go to previous messageGo to next message
There are so many logging APIs that logging is a mess.
One can always try to unify logging using all kinds of bridges.
I do hope, however, that this will always remain optional. I definitely would not like to bloat any application with all kinds of logging-API bridges (and logging APIs) one does not actually need.
A minimal solution would support only the standard, i.e. java.util.logging and OSGi logging. Equinox already has the extended log service which is outside of any standard. This extension has one advantage, though: It allows to use java.util.logging and write a handler that bridges from java.util.logging to OSGi logging. This in turn allows to add logging to OSGi bundles, whose jar files can also be used outside of an OSGi framework. Any other bridge and any other logging API should be optional. -- Unfortunately, this bridge will not work on another OSGi framework...
By the way, is there a chance that the extended log service might enter the OSGi standard some day? If I remember right, this has been suggested some time ago?
Re: Some questions about logging [message #1005792 is a reply to message #662013] Mon, 28 January 2013 13:31 Go to previous message
Anyone interested in this thread and the topic of logging within E4 will probably be interested in the enhancement I just submitted Class Logger Extended Object Supplier.
Now instead of have to directly use an ILoggerProvider you can just annotate your logger with @Inject @ClassLogger Logger and an instance of your logger will be injected. (Note: the instance will be separate from anything in the context)
For those hold outs to other logging facilities like Log4J, you are able to map o.e.e4.c.s.Logger to log4j.Logger as demonstrated in my sample project.
The one issue is that the context by default has an instance of Logger, thus the annotations of @Inject @ClassLogger Logger will not use the extended object supplier but the logger in the context. To resolve this issue just extend from Logger and inject your logger type (ex: @Inject @ClassLogger MyLogger).
This is all demonstrated in the sample project and is very easy and straight forward. If you like it, please +1 the enhancement in the attached bug.
JD
Previous Topic:Localization and extension-point schema definition errors
Next Topic:How do you inject the IEventBroker in an OSGi service ?
Current Time: Tue Oct 28 00:10:10 EDT 2025
Powered by FUDForum. Page generated in 0.12896 seconds
