Re: [teneo] UUID with containment causes "no String constructor" exception on retrieval [message #662008 is a reply to message #661800] |
Mon, 28 March 2011 20:41 |
Hi Marek,
This seems to be a missing feature or not handled correctly. Can you enter a bugzilla for this?
gr. Martin
On 03/28/2011 01:31 AM, Marek V wrote:
> I assume I'm doing something wrong, as it looks like Teneo won't work with containment using UUID ids (or any other ID
> type which doesn't have a String constructor).
> I get the following exception on retrieval:
> 28-Mar-2011 00:05:03 org.eclipse.emf.teneo.TeneoException <init>
> SEVERE: Class java.util.UUID does not have a constructor with a String parameter!
> org.eclipse.emf.teneo.hibernate.HbMapperException: Class java.util.UUID does not have a constructor with a String
> parameter!
> at org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rUserType.extractID(EContainerUserType.java:48
> 5)
> at org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rUserType.nullSafeGet(EContainerUserType.java:
> 385)
> at org.hibernate.type.AbstractType.hydrate(AbstractType.java:10 4)
> at org.hibernate.persister.entity.AbstractEntityPersister.hydra te(AbstractEntityPersister.java:2265)
> at org.hibernate.loader.Loader.loadFromResultSet(Loader.java:15 27)
> I have created a simple standalone test showing this. The test has an EMF interface called Master with a UUID id which.
> Master has a containment reference to a List<Detail>. Each Detail has a UUID id.
> With such a set up I can save a new Master with Detail, but when I try to retrieve the new Master and Detail I get the
> exception above.
> In the detail table, teneo has added a column E_CONTAINER which refers to its container and contains the String
> "java.util.UUID;390dea26-b149-45e5-99ab-40152e24cc8d".
> So what am I doing wrong as surely Teneo with Hibernate can work with UUID id objects?
> Any help much appreciated! Thanks,
> Marek
> My EMF interfaces:
> * @model
> public interface Master extends EObject {
> * @model id="true"
> public UUID getId();
> * Sets the value of the '{@link samples.teneo.uuid.domain.Master#getId <em>Id</em>}' attribute.
> * <!-- begin-user-doc -->
> * <!-- end-user-doc -->
> * @param value the new value of the '<em>Id</em>' attribute.
> * @see #getId()
> * @generated
> void setId(UUID value);
> * @model containment="true"
> * @return
> public EList<Detail> getDetails();
> * @model
> public interface Detail extends EObject {
> * @model id="true"
> * Sets the value of the '{@link samples.teneo.uuid.domain.Detail#getId <em>Id</em>}' attribute.
> * @see #getId()
> * @generated
> * @model
> * @return
> public String getValue();
> * Sets the value of the '{@link samples.teneo.uuid.domain.Detail#getValue <em>Value</em>}' attribute.
> * @param value the new value of the '<em>Value</em>' attribute.
> * @see #getValue()
> * @generated
> void setValue(String value);
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
FUDForum. Page generated in 0.44181 seconds
