Home » Eclipse Projects » Virgo » Virgo and org.eclipse.ui
Virgo and org.eclipse.ui [message #661578] Fri, 25 March 2011 09:27 Go to next message
I want to deploy a plugin on Virgo which need org.eclipse.ui package to work.
But when Virgo starts to deploy org.eclipse.ui, it throws an exception:
[2011-03-25 14:01:15.415] start-signalling-6           <DE0006E> Start failed for bundle 'org.eclipse.ui' version '3.6.1.M20100826-1330'. java.lang.RuntimeException: bundle stopped
	at org.eclipse.virgo.kernel.core.internal.BundleStartTracker$StartupTrackerBundleListener.bundleChanged(BundleStartTracker.java:246)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:919)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:149)
	at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEventPrivileged(Framework.java:1349)
	at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1300)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:395)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:284)
	at org.eclipse.virgo.kernel.core.internal.StandardBundleStarter.start(StandardBundleStarter.java:57)
	at org.eclipse.virgo.kernel.core.internal.StandardBundleStarter.start(StandardBundleStarter.java:45)
	at sun.reflect.GeneratedMethodAccessor45.invoke(Unknown Source)
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307)
	at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:58)
	at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:62)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
	at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131)
	at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119)
	at org.springframework.osgi.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:59)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
	at $Proxy60.start(Unknown Source)
	at org.eclipse.virgo.kernel.install.artifact.internal.bundle.StandardBundleDriver.startBundle(StandardBundleDriver.java:168)
	at org.eclipse.virgo.kernel.install.artifact.internal.bundle.StandardBundleDriver.start(StandardBundleDriver.java:149)
	at org.eclipse.virgo.kernel.install.artifact.internal.bundle.StandardBundleInstallArtifact.doStart(StandardBundleInstallArtifact.java:253)
	at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.driveDoStart(AbstractInstallArtifact.java:203)
	at org.eclipse.virgo.kernel.install.artifact.internal.bundle.StandardBundleInstallArtifact.start(StandardBundleInstallArtifact.java:242)
	at org.eclipse.virgo.kernel.install.artifact.internal.StandardPlanInstallArtifact.doStart(StandardPlanInstallArtifact.java:122)
	at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.start(AbstractInstallArtifact.java:194)
	at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.start(PipelinedApplicationDeployer.java:285)
	at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:195)
	at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.deploy(HotDeploymentFileSystemListener.java:174)
	at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.deployIfNotDeployed(HotDeploymentFileSystemListener.java:186)
	at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.onChange(HotDeploymentFileSystemListener.java:87)
	at org.eclipse.virgo.util.io.FileSystemChecker.notifyListeners(FileSystemChecker.java:245)
	at org.eclipse.virgo.util.io.FileSystemChecker.check(FileSystemChecker.java:166)
	at org.eclipse.virgo.kernel.deployer.hot.WatchTask.run(WatchTask.java:58)
	at java.lang.Thread.run(Thread.java:662)
[2011-03-25 14:01:15.420] fs-watcher                   <DE0006E> Start failed for bundle 'org.eclipse.ui' version '3.6.1.M20100826-1330'. org.eclipse.virgo.kernel.deployer.core.DeploymentException: BundleException
	at org.eclipse.virgo.kernel.install.artifact.internal.bundle.StandardBundleDriver.startBundle(StandardBundleDriver.java:170)
Caused by: org.osgi.framework.BundleException: The activator org.eclipse.ui.internal.UIPlugin for bundle org.eclipse.ui is invalid
What means "The activator org.eclipse.ui.internal.UIPlugin for bundle org.eclipse.ui is invalid" ?
Re: Virgo and org.eclipse.ui [message #661654 is a reply to message #661578] Fri, 25 March 2011 13:47 Go to previous message
Usually that means that the activator does not implement the correct OSGi Activator interface or, more likely, that there is some kind of problem in wiring to the org.osgi.framework package. Does your bundle import the package org.osgi.framework?
Previous Topic:Current Status of Virgo Tooling
Next Topic:Remote Repository Downloads on Port 8080 Regardless of Config
Current Time: Sat Nov 08 22:04:02 EST 2025
Powered by FUDForum. Page generated in 0.04045 seconds
