Re: Get implements interfaces, and subclasses from uml element [message #661329 is a reply to message #661179] |
Thu, 24 March 2011 09:45 |
Vlad Varnica Messages: 546 Registered: July 2009 Location: Milton Keynes - UK |
If you are a developer then Rafael answer is exactly what you need.
If you are a modeler then the easiest is to use an existing tool. You can graphically create implementation or reverse existing code.
Topcased can detect implementation from the code but all code information will not be saved in the model and it would be really painful to create views from a model. If you are lazy and have budget then just use EclipseUML Omondo because it would do the job for you.
You will spend more playing Golf or being with your family and let other lads work late in the evening to do what already exist.
Don't forget that your company will not give any gratitude if you save them software purchase because this is another budget !!
[Updated on: Thu, 24 March 2011 09:46] Report message to a moderator
FUDForum. Page generated in 0.03420 seconds
