Widget disposed too early exception [message #661019] |
Tue, 22 March 2011 17:41 |
Hi all,
I have such exception when shutting down my RCP.
How can i know which widget?
I think that I forgot to dispose some listener but don't find which one...
Kindly
kindly Elvis Dominguez
Re: Widget disposed too early exception [message #661052 is a reply to message #661019] |
Tue, 22 March 2011 22:21 |
Detailed exception
!ENTRY org.eclipse.ui.workbench 4 0 2011-03-22 23:24:08.798
!MESSAGE Widget disposed too early!
!STACK 0
java.lang.RuntimeException: Widget disposed too early!
at org.eclipse.ui.internal.WorkbenchPartReference$1.widgetDispo sed
(WorkbenchPartReference.java:172)
at org.eclipse.swt.widgets.TypedListener.handleEvent
(TypedListener.java:123)
at org.eclipse.swt.widgets.EventTable.sendEvent
(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1282)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1263)
at org.eclipse.swt.widgets.Widget.release(Widget.java:1080)
at org.eclipse.swt.widgets.Control.release(Control.java:3304)
at org.eclipse.swt.widgets.Composite.releaseChildren
(Composite.java:1293)
at org.eclipse.swt.widgets.Widget.release(Widget.java:1083)
at org.eclipse.swt.widgets.Canvas.releaseChildren(Canvas.java:2 08)
at org.eclipse.swt.widgets.Decorations.releaseChildren
(Decorations.java:469)
at org.eclipse.swt.widgets.Shell.releaseChildren(Shell.java:230 5)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:462)
at org.eclipse.swt.widgets.Shell.dispose(Shell.java:2241)
at org.eclipse.jface.window.Window.close(Window.java:335)
at org.eclipse.jface.window.ApplicationWindow.close
(ApplicationWindow.java:307)
at org.eclipse.ui.internal.WorkbenchWindow.hardClose
(WorkbenchWindow.java:1741)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose
(WorkbenchWindow.java:734)
at org.eclipse.ui.internal.WorkbenchWindow.access$0
(WorkbenchWindow.java:710)
at org.eclipse.ui.internal.WorkbenchWindow$5.run
(WorkbenchWindow.java:832)
at org.eclipse.swt.custom.BusyIndicator.showWhile
(BusyIndicator.java:70)
at org.eclipse.ui.internal.WorkbenchWindow.close
(WorkbenchWindow.java:830)
at org.eclipse.jface.window.WindowManager.close
(WindowManager.java:109)
at org.eclipse.ui.internal.Workbench$18.run(Workbench.java:1106 )
at org.eclipse.ui.internal.Workbench.busyClose
(Workbench.java:1103)
at org.eclipse.ui.internal.Workbench.access$15
(Workbench.java:1032)
at org.eclipse.ui.internal.Workbench$25.run(Workbench.java:1276 )
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1274)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1246)
(WorkbenchWindow.java:731)
at org.eclipse.jface.window.Window.handleShellCloseEvent
(Window.java:741)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:68 7)
(TypedListener.java:98)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1267)
at org.eclipse.swt.widgets.Shell.closeWidget(Shell.java:616)
at org.eclipse.swt.widgets.Shell.gtk_delete_event(Shell.java:11 66)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1735)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4796 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4360 )
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native
Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:81 89)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1238)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration
(Native Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration
(OS.java:2237)
at org.eclipse.swt.widgets.Display.readAndDispatch
(Display.java:3159)
at org.eclipse.ui.internal.Workbench.runEventLoop
(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault
(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench
(Workbench.java:664)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench
(PlatformUI.java:149)
at ch.oasi.client.workbench.Application.start(Application.java: 20)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run
(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication
(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start
(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run
(EclipseStarter.java:369)
(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke
(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke
(DelegatingMethodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework
(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
On Tue, 22 Mar 2011 17:41:18 +0000, Elvis Dominguez wrote:
> Hi all,
> I have such exception when shutting down my RCP. How can i know which
> widget?
> one...
> Kindly
FUDForum. Page generated in 0.04772 seconds
