Re: CDO server resource editor error [message #661071 is a reply to message #660695] |
Wed, 23 March 2011 00:22 |
Hi romeh,
Is it possible that you have a different version of the meta model deployed to your local application process than your collegue?
Cheers
/Eike
http://www.esc-net.de
Am 21.03.2011 02:08, schrieb romeh:
> Hi All,
> i have a derby DB,which contain persisted EMF objects,when i do the following:
> 1- open a session
> 2- register my EMF model
> 3-enable legacy mode
> 4- open transaction, which open resource under it
> 5- then when i click open editor
> i got the following exception, despite the same DB is working in another colleague machine with win 7, mine is XP:
> !MESSAGE org.eclipse.emf.ecore.impl.EGenericTypeImpl cannot be cast to org.eclipse.emf.ecore.EModelElement
> !STACK 0
> java.lang.ClassCastException: org.eclipse.emf.ecore.impl.EGenericTypeImpl cannot be cast to org.eclipse.emf.ecore.EModelElement
> at org.eclipse.emf.cdo.server.internal.db.MetaDataManager.getMe taInstance(MetaDataManager.java:84)
> at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ob jectTypeCache.getObjectType(ObjectTypeCache.java:108)
> at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.Ab stractHorizontalMappingStrategy.readObjectType(AbstractHoriz ontalMappingStrategy.java:71)
> at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.readO bjectType(DBStoreAccessor.java:158)
> at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.getOb jectType(DBStoreAccessor.java:175)
> at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.readR evision(DBStoreAccessor.java:200)
> at org.eclipse.emf.cdo.internal.server.Repository.loadRevisions (Repository.java:418)
> at org.eclipse.emf.cdo.internal.common.revision.CDORevisionMana gerImpl.loadRevisions(CDORevisionManagerImpl.java:365)
> at org.eclipse.emf.cdo.internal.common.revision.CDORevisionMana gerImpl.getRevisions(CDORevisionManagerImpl.java:268)
> at org.eclipse.emf.cdo.internal.common.revision.CDORevisionMana gerImpl.getRevision(CDORevisionManagerImpl.java:250)
> at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.execute (RevisionInfo.java:132)
> at org.eclipse.emf.cdo.server.internal.net4j.protocol.LoadRevis ionsIndication.responding(LoadRevisionsIndication.java:169)
> at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServer Indication.responding(CDOServerIndication.java:126)
> at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOu tput(IndicationWithResponse.java:96)
> at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:285)
> at org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:65)
> at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOReadIn dication.execute(CDOReadIndication.java:36)
> at org.eclipse.net4j.signal.Signal.runSync(Signal.java:240)
> at org.eclipse.net4j.signal.Signal.run(Signal.java:146)
> at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unkno wn Source)
> at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
> at java.lang.Thread.run(Unknown Source)
> any ideas here , what will be the main reason for that exception, despite the same data base is working in another machine?
Cheers
/Eike
FUDForum. Page generated in 0.03669 seconds
