Re: Birt Sample Report [message #660634 is a reply to message #660626] |
Sun, 20 March 2011 14:13 |
I don't think that's specifically a BIRT issue. Maybe WebSphere or something else. What did you get BIRT bundled with? I use BIRT, but I use either the RCP or the Eclipse All-In-One package and there are no references to WebSphere in those. Also, where did your "SalesInvoice" sample report come from?
Re: Birt Sample Report [message #661936 is a reply to message #661746] |
Mon, 28 March 2011 14:32 |
This looks like a permission issue. You should not have to put the
derby db jar in the drivers directory. This will probably cause it to
fail. In your web app server are you setting java.io.tmpdir? That is
the default location for the sample db.
Jason
On 3/27/2011 2:00 AM, atif.mehmood@live.com wrote:
> Hi Richard
> I am using birt with Websphere Application Server Community edition. I
> got the "SalesInvoice" Report from birt webpage.
> After having no success with the sample report, I have now created my
> own report in eclipse with a Derby Data Source that points to a folder
> on my C Drive. The report works fine while viewing it through the web
> viewer in eclipse. However, when I deploy the report to WAS CE I am
> getting following exception
> 27/03/2011 4:51:11 PM
> org.eclipse.birt.data.engine.odaconsumer.ConnectionManager openConnection
> SEVERE: Unable to open connection.
> Throwable occurred: org.eclipse.birt.report.data.oda.jdbc.JDBCException:
> There is an error in get connection, Failed to start database
> 'directory:/C:\birtruntime\waddington', see the next exception for
> details..
> at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.doCo
> nnect(JDBCDriverManager.java:262)
> at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.getC
> onnection(JDBCDriverManager.java:212)
> at org.eclipse.birt.report.data.oda.jdbc.Connection.connectByUr
> l(Connection.java:237)
> at org.eclipse.birt.report.data.oda.jdbc.Connection.open(Connec
> tion.java:162)
> at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaCo
> nnection.open(OdaConnection.java:250)
> at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o
> penConnection(ConnectionManager.java:165)
> at org.eclipse.birt.data.engine.executor.DataSource.newConnecti
> on(DataSource.java:224)
> at org.eclipse.birt.data.engine.executor.DataSource.open(DataSo
> urce.java:212)
> at org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiD
> ataSource(DataSourceRuntime.java:208)
> at org.eclipse.birt.data.engine.impl.QueryExecutor.openDataSour
> ce(QueryExecutor.java:406)
> at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecu
> tion(QueryExecutor.java:316)
> at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr
> eparedQuery.java:455)
> at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.pr
> oduceQueryResults(PreparedDataSourceQuery.java:190)
> at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex
> ecute(PreparedDataSourceQuery.java:178)
> at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute
> (PreparedOdaDSQuery.java:145)
> at org.eclipse.birt.report.data.adapter.impl.DataRequestSession
> Impl.execute(DataRequestSessionImpl.java:616)
> at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec
> uteQuery(DteDataEngine.java:152)
> at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine
> .doExecuteQuery(DataGenerationEngine.java:80)
> at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e
> xecute(AbstractDataEngine.java:265)
> at org.eclipse.birt.report.engine.executor.ExecutionContext.exe
> cuteQuery(ExecutionContext.java:1890)
> at org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex
> ecuteQuery(QueryItemExecutor.java:80)
> at org.eclipse.birt.report.engine.executor.TableItemExecutor.ex
> ecute(TableItemExecutor.java:62)
> at org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe
> dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 6)
> at org.eclipse.birt.report.engine.internal.executor.emitter.Rep
> ortItemEmitterExecutor.execute(ReportItemEmitterExecutor.jav a:46)
> at org.eclipse.birt.report.engine.internal.executor.dup.Suppres
> sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:43)
> at org.eclipse.birt.report.engine.internal.executor.l18n.Locali
> zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:34)
> at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking
> LM.layoutNodes(HTMLBlockStackingLM.java:65)
> at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout
> (HTMLPageLM.java:90)
> at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE
> ngine.layout(HTMLReportLayoutEngine.java:99)
> at org.eclipse.birt.report.engine.presentation.ReportDocumentBu
> ilder.build(ReportDocumentBuilder.java:249)
> at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTas k.java:260)
> at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask. java:85)
> at org.eclipse.birt.report.service.ReportEngineService.runRepor
> t(ReportEngineService.java:1315)
> at org.eclipse.birt.report.service.BirtViewerReportService.runR
> eport(BirtViewerReportService.java:158)
> at org.eclipse.birt.report.service.actionhandler.BirtRunReportA
> ctionHandler.__execute(BirtRunReportActionHandler.java:81)
> at org.eclipse.birt.report.service.actionhandler.BirtGetPageAct
> ionHandler.__checkDocumentExists(BirtGetPageActionHandler.ja va:58)
> at org.eclipse.birt.report.service.actionhandler.AbstractGetPag
> eActionHandler.prepareParameters(AbstractGetPageActionHandle r.java:119)
> eActionHandler.__execute(AbstractGetPageActionHandler.java:1 04)
> at org.eclipse.birt.report.service.actionhandler.AbstractBaseAc
> tionHandler.execute(AbstractBaseActionHandler.java:90)
> at org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc
> umentProcessor.__executeAction(AbstractBaseDocumentProcessor .java:47)
> at org.eclipse.birt.report.soapengine.processor.AbstractBaseCom
> ponentProcessor.executeAction(AbstractBaseComponentProcessor .java:143)
> at org.eclipse.birt.report.soapengine.processor.BirtDocumentPro
> cessor.handleGetPage(BirtDocumentProcessor.java:87)
> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce
> ssorImpl.java:48)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe
> thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:600)
> ponentProcessor.process(AbstractBaseComponentProcessor.java: 112)
> at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI
> mpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
> ssorImpl.java:48)
> at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP
> rovider.java:397)
> at org.apache.axis.providers.java.RPCProvider.processMessage(RP
> CProvider.java:186)
> at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi
> der.java:323)
> at org.apache.axis.strategies.InvocationStrategy.visit(Invocati
> onStrategy.java:32)
> at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
> at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
> at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:454)
> at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 )
> at org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699)
> at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer
> vlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:713)
> at org.apache.axis.transport.http.AxisServletBase.service(AxisS
> ervletBase.java:327)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:806)
> vlet.service(BirtSoapMessageDispatcherServlet.java:122)
> at org.apache.catalina.core.ApplicationFilterChain.internalDoFi
> lter(ApplicationFilterChain.java:290)
> at org.apache.catalina.core.ApplicationFilterChain.doFilter(App
> licationFilterChain.java:206)
> at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerF
> ilter.java:68)
> lter(ApplicationFilterChain.java:235)
> at org.apache.catalina.core.StandardWrapperValve.invoke(Standar
> dWrapperValve.java:233)
> at org.apache.catalina.core.StandardContextValve.invoke(Standar
> dContextValve.java:191)
> at org.apache.geronimo.tomcat.valve.DefaultSubjectValve.invoke(
> DefaultSubjectValve.java:56)
> at org.apache.geronimo.tomcat.GeronimoStandardContext$SystemMet
> hodValve.invoke(GeronimoStandardContext.java:406)
> at org.apache.geronimo.tomcat.valve.GeronimoBeforeAfterValve.in
> voke(GeronimoBeforeAfterValve.java:47)
> at org.apache.catalina.core.StandardHostValve.invoke(StandardHo
> stValve.java:127)
> at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo
> rtValve.java:102)
> at org.apache.catalina.core.StandardEngineValve.invoke(Standard
> EngineValve.java:109)
> at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogVa
> lve.java:555)
> at org.apache.geronimo.tomcat.valve.ThreadCleanerValve.invoke(T
> hreadCleanerValve.java:40)
> at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd
> apter.java:298)
> at org.apache.coyote.http11.Http11Processor.process(Http11Proce
> ssor.java:857)
> at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand
> ler.process(Http11Protocol.java:588)
> at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:489)
> at java.lang.Thread.run(Thread.java:736)
> I have placed the derby 10.5.3.1 jar inside
> \WEB-INF\platform\plugins\org.eclipse.birt.report.data.oda.j
> dbc_2.6.2.r262_v20110127\drivers.
> Any help in this regard is much appreciated.
> Thanks
Re: Birt Sample Report [message #662958 is a reply to message #662816] |
Fri, 01 April 2011 15:12 |
I would try setting the system java.io.tmpdir variable. It may be
already set. To see your current variables run the attached report.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22"
id="1">
<property name="comments">Copyright (c) 2006 Innovent Solutions,
Inc.</property>
<property name="createdBy">Eclipse BIRT Designer Version
2.6.1.v20100902 Build <2.6.1.v20100915-1750></property>
<property name="units">in</property>
<method name="beforeFactory"><![CDATA[// Create a hash table which
will contain lists of other lists
//importPackages(Packages.java.util);
var topMap = new Packages.java.util.Hashtable();
// Request Attributes
var request = reportContext.getHttpServletRequest();
var requestAttrMap = new Packages.java.util.Hashtable();
var attrNames = request.getAttributeNames();
do {
var aName = attrNames.nextElement();
requestAttrMap.put(aName, request.getAttribute(aName).toString());
} while (attrNames.hasMoreElements())
topMap.put("requestAttributes", requestAttrMap);
// Request Parameters
var requestParamMap = new Packages.java.util.Hashtable();
var paramIter = request.getParameterMap().entrySet().iterator();
do{
var entry = paramIter.next();
requestParamMap.put(entry.getKey(), (entry.getValue()[0]));
} while (paramIter.hasNext())
topMap.put("requestParameters",requestParamMap);
// Session Attributes
var sessionAttrMap = new Packages.java.util.Hashtable();
var session = request.getSession();
// Insert a variable on the session
session.setAttribute("ReportAttribute", "arbitrary value to pass to
container");
var sessionAttrNames = session.getAttributeNames();
var i = 0;
do {
i ++;
var aaa = sessionAttrNames.nextElement();
sessionAttrMap.put(aaa, session.getAttribute(aaa));
} while (sessionAttrNames.hasMoreElements())
topMap.put("sessionAttributes", sessionAttrMap);
// Get the system properties
topMap.put("systemProps", Packages.java.lang.System.getProperties());
importPackage(Packages.java.lang.management)
var RuntimemxBean = ManagementFactory.getRuntimeMXBean();
arguments = RuntimemxBean.getInputArguments();
var argsMap = new Packages.java.util.Hashtable();
iterator = arguments.iterator();
while ( iterator.hasNext() ){
var val = iterator.next();
argsMap.put( val, val );
topMap.put("vmargs", argsMap);
// Store top map as a global
reportContext.setPersistentGlobalVariable("topMap", topMap);]]></method>
<property name="layoutPreference">auto layout</property>
<data-sources>
<script-data-source name="setScript" id="4"/>
</data-sources>
<data-sets>
<script-data-set name="setEnvironmentVars" id="5">
<list-property name="resultSetHints">
<structure>
<property name="position">1</property>
<property name="name">propName</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">propValue</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">propType</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">propName</property>
</structure>
<structure>
<property name="columnName">propValue</property>
</structure>
<structure>
<property name="columnName">propType</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<property name="dataSource">setScript</property>
<method name="open"><![CDATA[aMap =
reportContext.getPersistentGlobalVariable("topMap");
topIter = aMap.entrySet().iterator();
if (topIter == null)
topIterator = new Packages.java.util.Iterator();
Packages.java.util.logging.Logger.getLogger("").info("OPEN NULL " );
innerIter = null;]]></method>
<method name="fetch"><![CDATA[do
{ // find an innerIter that has a new value
if (innerIter == null || innerIter.hasNext() == false)
{ // no value in the inner iterator, get the next Hashtable out of the
toHashtable
if (topIter.hasNext())
outerObject = topIter.next();
innerIter = outerObject.getValue().entrySet().iterator();
else
{ // no more top hash tables. close things up
return false;
while (innerIter.hasNext() == false)
// we must have another innerIter
innerObject = innerIter.next();
row["propName"] = innerObject.getKey();
row["propValue"] = innerObject.getValue().toString();
row["propType"] = outerObject.getKey();
return true;
Iterator i = topMap.entrySet().iterator();
while (i.hasNext()) {
Entry entry = (Entry) i.next();
logger.info(entry.getKey() + " " + entry.getValue() );
*/]]></method>
</script-data-set>
</data-sets>
<styles>
<style name="detail" id="36">
<property name="backgroundColor">#FFFF80</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">small</property>
</style>
<style name="headerfooter" id="37">
<property name="backgroundColor">#004080</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
</style>
<style name="groupheader" id="38">
<property name="backgroundColor">#0080FF</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="orientation">landscape</property>
<property name="topMargin">0.5in</property>
<property name="leftMargin">0.5in</property>
<property name="bottomMargin">0.5in</property>
<property name="rightMargin">0.5in</property>
</simple-master-page>
</page-setup>
<body>
<table id="6">
<property name="width">100%</property>
<property name="dataSet">setEnvironmentVars</property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["propName"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["propValue"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["propType"]</expression>
<simple-property-list name="aggregateOn">
<value>propType</value>
</simple-property-list>
</structure>
</list-property>
<property name="pageBreakInterval">50</property>
<column id="16"/>
<column id="17"/>
<header>
<row id="7">
<property name="style">headerfooter</property>
<cell id="8">
<label id="18">
<text-property
name="text">propName</text-property>
</label>
</cell>
<cell id="9">
<label id="20">
<text-property
name="text">propValue</text-property>
</label>
</cell>
</row>
</header>
<group id="22">
<property name="groupName">propType</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr">row["propType"]</expression>
<structure name="toc">
<expression
name="expressionValue">row["propType"]</expression>
</structure>
<header>
<row id="23">
<cell id="24">
<data id="29">
<property
name="resultSetColumn">propType</property>
</data>
</cell>
<cell id="25"/>
</row>
<row id="33">
<property name="height">2pt</property>
<property name="backgroundColor">#000000</property>
<cell id="34"/>
<cell id="35"/>
</row>
</header>
<footer>
<row id="26">
<cell id="27"/>
<cell id="28"/>
</row>
</footer>
</group>
<detail>
<row id="10">
<property name="style">groupheader</property>
<cell id="11">
<data id="19">
<property
name="resultSetColumn">propName</property>
</data>
</cell>
<cell id="12">
<data id="21">
<property
name="resultSetColumn">propValue</property>
</data>
</cell>
</row>
<row id="30">
<property name="backgroundColor">#C0C0C0</property>
<cell id="31"/>
<cell id="32"/>
</row>
</detail>
<footer>
<row id="13">
<cell id="14"/>
<cell id="15"/>
</row>
</footer>
</table>
</body>
</report>
On 4/1/2011 12:42 AM, atif.mehmood@live.com wrote:
> Jason
> Thanks for your reply.
> Actually, I have not specified java.io.tmpdir any where in Websphere
> application server CE. I just did what was mentioned on the Birt
> website. Do I need to specify the temp dir when I configure database url
> in my Birt report as 'directory:/C:\birtruntime\waddington'?.
> Thanks
Re: Birt Sample Report [message #663085 is a reply to message #662958] |
Sun, 03 April 2011 12:29 |
No real name Messages: 4 Registered: March 2011 |
Hi Jason
I believe there are some serious issues in my BIRT and Websphere CE configuration. I tried running the report, however it was blank with just the header column displaying propName and propValue. When I checked the logs I found this nested exception
03/04/2011 10:21:00 PM org.eclipse.birt.report.engine.script.internal.ScriptExecuto r addException
WARNING: Unhandled exception when executing script.
Throwable occurred: org.eclipse.birt.report.engine.api.EngineException: Unhandled exception when executing script.
at org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.addException(ScriptExecutor.java:162)
at org.eclipse.birt.report.engine.script.internal.ReportScriptE xecutor.handleBeforeFactory(ReportScriptExecutor.java:82)
at org.eclipse.birt.report.engine.api.impl.EngineTask.startFact ory(EngineTask.java:1804)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTas k.java:218)
at org.eclipse.birt.report.service.ReportEngineService.runRepor t(ReportEngineService.java:1315)
at org.eclipse.birt.report.service.BirtViewerReportService.runR eport(BirtViewerReportService.java:158)
at org.eclipse.birt.report.service.actionhandler.BirtRunReportA ctionHandler.__execute(BirtRunReportActionHandler.java:81)
at org.eclipse.birt.report.service.actionhandler.BirtGetPageAct ionHandler.__checkDocumentExists(BirtGetPageActionHandler.ja va:58)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.prepareParameters(AbstractGetPageActionHandle r.java:119)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.__execute(AbstractGetPageActionHandler.java:1 04)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc umentProcessor.__executeAction(AbstractBaseDocumentProcessor .java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.executeAction(AbstractBaseComponentProcessor .java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentPro cessor.handleGetPage(BirtDocumentProcessor.java:87)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:48)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.process(AbstractBaseComponentProcessor.java: 112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrategy.java:32)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerF ilter.java:68)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
at org.apache.geronimo.tomcat.valve.DefaultSubjectValve.invoke( DefaultSubjectValve.java:56)
at org.apache.geronimo.tomcat.GeronimoStandardContext$SystemMet hodValve.invoke(GeronimoStandardContext.java:406)
at org.apache.geronimo.tomcat.valve.GeronimoBeforeAfterValve.in voke(GeronimoBeforeAfterValve.java:47)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogVa lve.java:555)
at org.apache.geronimo.tomcat.valve.ThreadCleanerValve.invoke(T hreadCleanerValve.java:40)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:298)
at org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:857)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:588)
Caused by: org.mozilla.javascript.EvaluatorException: missing ; before statement (/report/method[@name="beforeFactory"]#2)
at org.mozilla.javascript.DefaultErrorReporter.runtimeError(Def aultErrorReporter.java:109)
at org.mozilla.javascript.DefaultErrorReporter.error(DefaultErr orReporter.java:96)
at org.mozilla.javascript.Parser.addError(Parser.java:146)
at org.mozilla.javascript.Parser.reportError(Parser.java:160)
at org.mozilla.javascript.Parser.statementHelper(Parser.java:12 66)
at org.mozilla.javascript.Parser.statement(Parser.java:707)
at org.mozilla.javascript.Parser.parse(Parser.java:401)
at org.mozilla.javascript.Parser.parse(Parser.java:338)
at org.mozilla.javascript.Context.compileImpl(Context.java:2368 )
at org.mozilla.javascript.Context.compileString(Context.java:13 59)
at org.mozilla.javascript.Context.compileString(Context.java:13 48)
at org.eclipse.birt.report.engine.javascript.JavascriptEngine$3 .run(JavascriptEngine.java:232)
at org.eclipse.birt.report.engine.javascript.JavascriptEngine$3 .run(JavascriptEngine.java:1)
at java.security.AccessController.doPrivileged(AccessController .java:202)
at org.eclipse.birt.report.engine.javascript.JavascriptEngine.c ompile(JavascriptEngine.java:228)
at org.eclipse.birt.report.engine.javascript.JavascriptEngine.c ompile(JavascriptEngine.java:1)
at org.eclipse.birt.core.script.ScriptContext.compile(ScriptCon text.java:148)
at org.eclipse.birt.report.engine.executor.ExecutionContext.com pile(ExecutionContext.java:762)
at org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:696)
at org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.handleScriptInternal(ScriptExecutor.java:61)
at org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.handleScript(ScriptExecutor.java:48)
at org.eclipse.birt.report.engine.script.internal.ReportScriptE xecutor.handleBeforeFactory(ReportScriptExecutor.java:74)
... 57 more
03/04/2011 10:21:02 PM org.eclipse.birt.report.engine.script.internal.DtEScriptExec utor handleJS
WARNING: Fail to execute script in function __bm_OPEN(). Source:
" + aMap =
innerIter = null; + "
A BIRT exception occurred. See next exception for more information.
Error evaluating Javascript expression. Script engine error: TypeError: Cannot call method "entrySet" of null (/report/data-sets/script-data-set[@id="5"]/method[@name="open "]#3)
Script source: /report/data-sets/script-data-set[@id="5"]/method[@name="open "], line: 0, text:
__bm_OPEN()
Throwable occurred: org.eclipse.birt.data.engine.core.DataException: Fail to execute script in function __bm_OPEN(). Source:
" + aMap =
__bm_OPEN()
at org.eclipse.birt.data.engine.script.JSMethodRunner.runScript (JSMethodRunner.java:147)
at org.eclipse.birt.report.engine.script.internal.DtEScriptExec utor.handleJS(DtEScriptExecutor.java:90)
at org.eclipse.birt.report.engine.script.internal.DataSetScript Executor.handleJS(DataSetScriptExecutor.java:246)
at org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:9 7)
at org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.open( ScriptDataSetRuntime.java:80)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor$CustomDataSet.open(PreparedScriptDSQuery.j ava:247)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :223)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:1103)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(ServiceForQueryResults.java:232)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:173)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init >(QueryResultSet.java:98)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:168)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine .doExecuteQuery(DataGenerationEngine.java:80)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:265)
at org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1890)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:80)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 6)
at org.eclipse.birt.report.engine.internal.executor.emitter.Rep ortItemEmitterExecutor.execute(ReportItemEmitterExecutor.jav a:46)
at org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:43)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:99)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBu ilder.build(ReportDocumentBuilder.java:258)
Caused by: org.eclipse.birt.data.engine.core.DataException: A BIRT exception occurred. See next exception for more information.
__bm_OPEN()
at org.eclipse.birt.data.engine.core.DataException.wrap(DataExc eption.java:118)
at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJ SAsExpr(ScriptEvalUtil.java:1005)
at org.eclipse.birt.data.engine.script.JSMethodRunner.runScript (JSMethodRunner.java:138)
... 79 more
Caused by: org.eclipse.birt.core.exception.CoreException: Error evaluating Javascript expression. Script engine error: TypeError: Cannot call method "entrySet" of null (/report/data-sets/script-data-set[@id="5"]/method[@name="open "]#3)
__bm_OPEN()
at org.eclipse.birt.core.script.JavascriptEvalUtil.wrapRhinoExc eption(JavascriptEvalUtil.java:303)
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawS cript(JavascriptEvalUtil.java:102)
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateScri pt(JavascriptEvalUtil.java:134)
at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJ SAsExpr(ScriptEvalUtil.java:1001)
... 80 more
Caused by: org.mozilla.javascript.EcmaError: TypeError: Cannot call method "entrySet" of null (/report/data-sets/script-data-set[@id="5"]/method[@name="open "]#3)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3654)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3632)
at org.mozilla.javascript.ScriptRuntime.typeError(ScriptRuntime .java:3660)
at org.mozilla.javascript.ScriptRuntime.typeError2(ScriptRuntim e.java:3679)
at org.mozilla.javascript.ScriptRuntime.undefCallError(ScriptRu ntime.java:3698)
at org.mozilla.javascript.ScriptRuntime.getPropFunctionAndThisH elper(ScriptRuntime.java:2221)
at org.mozilla.javascript.ScriptRuntime.getPropFunctionAndThis( ScriptRuntime.java:2214)
at org.mozilla.javascript.optimizer.OptRuntime.callProp0(OptRun time.java:117)
at org.mozilla.javascript.gen.c4._c1(/report/data-sets/script-d ata-set[@id= "5"]/method[@name="open"]:3)
at org.mozilla.javascript.gen.c4.call(/report/data-sets/script- data-set[@id= "5"]/method[@name="open"])
at org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRun time.java:108)
at org.mozilla.javascript.gen.c5._c0(/report/data-sets/script-d ata-set[@id= "5"]/method[@name="open"])
at org.mozilla.javascript.gen.c5.call(/report/data-sets/script- data-set[@id= "5"]/method[@name="open"])
at org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:398)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:3065)
at org.mozilla.javascript.gen.c5.exec(/report/data-sets/script- data-set[@id= "5"]/method[@name="open"])
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawS cript(JavascriptEvalUtil.java:95)
... 82 more
WARNING: Fail to execute script in function __bm_FETCH(). Source:
" + do
toHashtable
else
return false;
return true;
Error evaluating Javascript expression. Script engine error: ReferenceError: "innerIter" is not defined.
Script source: /report/data-sets/script-data-set[@id="5"]/method[@name="fetch "], line: 0, text:
__bm_FETCH()
Throwable occurred: org.eclipse.birt.data.engine.core.DataException: Fail to execute script in function __bm_FETCH(). Source:
" + do
toHashtable
else
return false;
return true;
__bm_FETCH()
at org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java: 140)
at org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.fetch (ScriptDataSetRuntime.java:103)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor$CustomDataSet.fetch(PreparedScriptDSQuery. java:260)
at org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch (OdiAdapter.java:226)
at org.eclipse.birt.data.engine.executor.cache.RowResultSet.nex t(RowResultSet.java:105)
at org.eclipse.birt.data.engine.executor.cache.ExpandableRowRes ultSet.next(ExpandableRowResultSet.java:63)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .populateData(SmartCacheHelper.java:316)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .initInstance(SmartCacheHelper.java:285)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .getResultSetCache(SmartCacheHelper.java:246)
at org.eclipse.birt.data.engine.executor.cache.SmartCache.<init >(SmartCache.java:73)
at org.eclipse.birt.data.engine.executor.transform.pass.PassUti l.populateOdiResultSet(PassUtil.java:110)
at org.eclipse.birt.data.engine.executor.transform.pass.PassUti l.pass(PassUtil.java:62)
at org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.populateResultSetCacheInResultSetPopulator(PassManager. java:317)
at org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.populateDataSet(PassManager.java:279)
at org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.prepareDataSetResultSet(PassManager.java:98)
at org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.pass(PassManager.java:125)
at org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.populateResultSet(PassManager.java:74)
at org.eclipse.birt.data.engine.executor.transform.ResultSetPop ulator.populateResultSet(ResultSetPopulator.java:198)
at org.eclipse.birt.data.engine.executor.transform.CachedResult Set. <init>(CachedResultSet.java:195)
at org.eclipse.birt.data.engine.executor.CandidateQuery.execute (CandidateQuery.java:106)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :226)
__bm_FETCH()
... 96 more
Caused by: org.eclipse.birt.core.exception.CoreException: Error evaluating Javascript expression. Script engine error: ReferenceError: "innerIter" is not defined.
__bm_FETCH()
... 97 more
Caused by: org.mozilla.javascript.EcmaError: ReferenceError: "innerIter" is not defined.
at org.mozilla.javascript.ScriptRuntime.notFoundError(ScriptRun time.java:3717)
at org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRu ntime.java:1758)
at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java :1697)
at org.mozilla.javascript.gen.c6._c1(/report/data-sets/script-d ata-set[@id= "5"]/method[@name="fetch"])
at org.mozilla.javascript.gen.c6.call(/report/data-sets/script- data-set[@id= "5"]/method[@name="fetch"])
at org.mozilla.javascript.gen.c7._c0(/report/data-sets/script-d ata-set[@id= "5"]/method[@name="fetch"])
at org.mozilla.javascript.gen.c7.call(/report/data-sets/script- data-set[@id= "5"]/method[@name="fetch"])
at org.mozilla.javascript.gen.c7.exec(/report/data-sets/script- data-set[@id= "5"]/method[@name="fetch"])
... 99 more
03/04/2011 10:21:02 PM org.eclipse.birt.report.engine.script.internal.ScriptExecuto r addException
WARNING: Data Set script method "Fetch" returned null; expected a Boolean value.
Throwable occurred: org.eclipse.birt.report.engine.api.EngineException: Data Set script method "Fetch" returned null; expected a Boolean value.
at org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.addException(ScriptExecutor.java:158)
at org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.addException(ScriptExecutor.java:147)
at org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java: 162)
Caused by: org.eclipse.birt.data.engine.core.DataException: Data Set script method "Fetch" returned null; expected a Boolean value.
at org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java: 150)
... 93 more
I did manage to find out the value of java.io.tmpdir variable in Websphere CE and it is set to
C:\Program Files (x86)\IBM\WebSphere\AppServerCommunityEdition\var\temp
I am totally lost as I can not proceed any further without your help.
Any help is much appreciated.
Re: Birt Sample Report [message #663646 is a reply to message #663085] |
Wed, 06 April 2011 02:43 |
That error looks like there is something wrong with the beforeFactory
script. I am not certain why that is happening in your environment.
Can you open a bugzilla entry for the original error?
Jason
On 4/3/2011 8:30 AM, atif.mehmood@live.com wrote:
> Hi Jason
> ssorImpl.java:48)
> ssorImpl.java:48)
> rovider.java:397)
> CProvider.java:186)
> der.java:323)
> onStrategy.java:32)
> ilter.java:68)
> stValve.java:127)
> rtValve.java:102)
> lve.java:555)
> apter.java:298)
> ssor.java:857)
> orReporter.java:96)
> text.java:148)
> ... 57 more
> " + aMap =
> Script source:
> 0, text:
> __bm_OPEN()
> " + aMap =
> Script source:
> 0, text:
> __bm_OPEN()
> ssorImpl.java:48)
> ssorImpl.java:48)
> rovider.java:397)
> CProvider.java:186)
> der.java:323)
> onStrategy.java:32)
> ilter.java:68)
> stValve.java:127)
> rtValve.java:102)
> lve.java:555)
> apter.java:298)
> ssor.java:857)
> Script source:
> 0, text:
> __bm_OPEN()
> eption.java:118)
> ... 79 more
> Script source:
> 0, text:
> __bm_OPEN()
> ... 80 more
> ntime.java:3654)
> ntime.java:3632)
> e.java:3679)
> ntime.java:3698)
> time.java:117)
> time.java:108)
> ry.java:398)
> ... 82 more
> " + do
> toHashtable
> else
> return false;
> return true;
> Script source:
> 0, text:
> __bm_FETCH()
> " + do
> toHashtable
> else
> return false;
> return true;
> Script source:
> 0, text:
> __bm_FETCH()
> ssorImpl.java:48)
> ssorImpl.java:48)
> rovider.java:397)
> CProvider.java:186)
> der.java:323)
> onStrategy.java:32)
> ilter.java:68)
> stValve.java:127)
> rtValve.java:102)
> lve.java:555)
> apter.java:298)
> ssor.java:857)
> Script source:
> 0, text:
> __bm_FETCH()
> eption.java:118)
> ... 96 more
> Script source:
> 0, text:
> __bm_FETCH()
> ... 97 more
> is not defined.
> ntime.java:3654)
> ntime.java:3632)
> time.java:3717)
> ntime.java:1758)
> time.java:108)
> ry.java:398)
> ... 99 more
> Boolean value.
> ssorImpl.java:48)
> ssorImpl.java:48)
> rovider.java:397)
> CProvider.java:186)
> der.java:323)
> onStrategy.java:32)
> ilter.java:68)
> stValve.java:127)
> rtValve.java:102)
> lve.java:555)
> apter.java:298)
> ssor.java:857)
> ... 93 more
> Websphere CE and it is set to C:\Program Files
Re: Birt Sample Report [message #759966 is a reply to message #759754] |
Wed, 30 November 2011 18:19 |
Are you using a beforeFactory script?
Jason
On 11/29/2011 3:35 PM, Tosh wrote:
> I am getting same exception reported in this thread. I am also trying to
> run the example application in WAS CE. Was a resolution found? Thx. Tosh.
Re: Birt Sample Report [message #759982 is a reply to message #759977] |
Wed, 30 November 2011 19:12 |
Is this the default test1.rptdesign or has it been modified?
Jason
On 11/30/2011 2:03 PM, Tosh wrote:
> Jason,
> Not sure how to answer that. Maybe this screen shot can answer that perhaps?
> After making the selections in the parameter dialog windows I press OK and then see the exception at the start of this post.
Re: Birt Sample Report [message #759993 is a reply to message #759986] |
Wed, 30 November 2011 20:05 |
This sounds like a bug. Can you log a bugzilla request for this?
Jason
On 11/30/2011 2:20 PM, Tosh wrote:
> It is the default report.
> I can preview the report fine in Report Editor perspective.
> Please see the attached screen shot.
FUDForum. Page generated in 0.05046 seconds
