Eclipse Helios / Remote System Explorer issue [message #660551] |
Sat, 19 March 2011 09:33 |
Eric Messages: 17 Registered: March 2011 |
Hi all,
I have a big problem with the latest Eclipse Helios and Remote System Explorer. RSE seems to crash after trying to open a file on a remote system. The error log says nothing else than the following:
!ENTRY org.eclipse.rse.ui 4 0 2011-03-19 10:06:00.021
!MESSAGE RSEF1002
The error message which pops up is the following:
Message reported from file system: The system cannot find the specified path.
I thought an update would be the solution so I checked for new updates and was prompted to install "Eclipse IDE for PHP Developers 1.3.2.20110301-1807". Unfortunately, the update fails with the following error:
!ENTRY org.eclipse.equinox.p2.engine 4 4 2011-03-19 10:24:16.095
!MESSAGE An error occurred while uninstalling
!SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2011-03-19 10:24:16.095
!MESSAGE session context was:(profile=epp.package.php, phase=org.eclipse.equinox.internal.p2.engine.phases.Uninstall, operand=[R]org.eclipse.cvs_root 1.1.101.R35x_v20100125-7E79FGD9kKF67BPDZ7PKCE1911 --> null, action=org.eclipse.equinox.internal.p2.touchpoint.natives.actions.CleanupzipAction).
!SUBENTRY 1 org.eclipse.equinox.p2.touchpoint.natives 4 0 2011-03-19 10:24:16.095
!MESSAGE Backup of file D:\Program Files\eclipse\epl-v10.html failed.
!STACK 0
java.io.FileNotFoundException: C:\Users\Asus\AppData\Local\Temp\epp.package.php_25d9adbc7420_c0a8b215c63e\D\Program Files\eclipse\epl-v10.html (The system cannot find the specified path)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(Unknown Source)
at org.eclipse.equinox.internal.p2.touchpoint.natives.BackupStore.backup(BackupStore.java:253)
at org.eclipse.equinox.internal.p2.touchpoint.natives.LazyBackupStore.backup(LazyBackupStore.java:36)
at org.eclipse.equinox.internal.p2.touchpoint.natives.actions.CleanupzipAction.cleanupzip(CleanupzipAction.java:85)
at org.eclipse.equinox.internal.p2.touchpoint.natives.actions.CleanupzipAction.execute(CleanupzipAction.java:30)
at org.eclipse.equinox.internal.p2.engine.ParameterizedProvisioningAction.execute(ParameterizedProvisioningAction.java:35)
at org.eclipse.equinox.internal.p2.engine.Phase.mainPerform(Phase.java:149)
at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:78)
at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:44)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:73)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44)
at org.eclipse.equinox.p2.operations.ProvisioningSession.performProvisioningPlan(ProvisioningSession.java:174)
at org.eclipse.equinox.p2.operations.ProfileModificationJob.runModal(ProfileModificationJob.java:79)
at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
RSE and Eclipse were working fine some days ago and I didn't change anything on my set-up. Now I can't even open 1 single file as "the specified path cannot be found".
Could it be a Java or Windows update causing these recent errors? I'm using Windows Vista.
I have also tried a completely fresh install of Helios and RSE, added some remote systems and tried to open files. The problem even persists there!
Can anybody please help me? I have already spend 2 days now searching for solutions but this problem doesn't seem to be pretty common.
Please let me know whether any more information is needed.
Thank you so much in advance!
I'm really helpless at the moment.
[Updated on: Sat, 19 March 2011 09:56] Report message to a moderator
FUDForum. Page generated in 0.02963 seconds
