Re: Proxy Resolution Problem [message #660379 is a reply to message #660373] |
Fri, 18 March 2011 08:21 |
Markus Herrmannsdoerfer Messages: 50 Registered: July 2009 |
Member |
Unfortunately, I cannot switch to the trunk version of EMF in some
projects. Is there a way to circumvent this problem, i.e. to force these
proxies to resolve?
Thanks.
Am 18.03.2011 08:42, schrieb Markus Herrmannsdoerfer:
> Hi *,
> I have the problem that proxies of single-valued references do not get
> resolved, even though resolve proxies is true. As a result, migrations
> specified in COPE/Edapt are not working. I debugged a lot and found the
> following code snippet in EStructuralFeatureImpl:
> 2815 public static class
> InternalSettingDelegateSingleEObjectResolvingUnsettable extends
> 2816 {
> 2817 public
> InternalSettingDelegateSingleEObjectResolvingUnsettable(ECla ss eClass,
> EStructuralFeature feature)
> 2818 {
> 2819 super(eClass, feature);
> 2820 }
> 2821
> 2822 @Override
> 2823 protected boolean isUnsettable()
> 2824 {
> 2825 return true;
> 2826 }
> 2827 }
> Must the class InternalSettingDelegateSingleEObjectResolvingUnsettable
> not inherit from InternalSettingDelegateSingleEObjectResolving instead
> of InternalSettingDelegateSingleEObject? It seems to me that this only
> affects reflective deserialization.
> Thanks and cheers,
> Markus
Re: Proxy Resolution Problem [message #660454 is a reply to message #660379] |
Fri, 18 March 2011 13:41 |
Ed Merks Messages: 33142 Registered: July 2009 |
Markus,
Yes, that looks wrong. Please open a bugzilla.
EStructuralFeature.Internal.setSettingDelegate can be used to set your
own setting delegate implementation into the feature that's not working
properly otherwise.
> these proxies to resolve?
> Thanks.
>> Hi *,
>> 2816 {
>> 2817 public
>> 2818 {
>> 2820 }
>> 2821
>> 2822 @Override
>> 2824 {
>> 2825 return true;
>> 2826 }
>> 2827 }
>> Thanks and cheers,
>> Markus
Ed Merks
FUDForum. Page generated in 0.03220 seconds
