Link Lifeline to Class in Sequence Diagrams [message #660143] |
Wed, 16 March 2011 23:28  |
I created a simple Class Diagram containing two classes, Master and Slave, with a usage relationship (Master->Slave).
Now I'm trying to create a Sequence Diagram, but I can't link a Lifeline on the diagram with any of the classes. I instantiated a Lifeline but when I try to select the object this Lifeline represents, nothing appears on the selection window ("Select Represents").
Is this a bug or I'm doing it the wrong way?
Thanks in advance,
Thiago Figueredo
Re: Link Lifeline to Class in Sequence Diagrams [message #664152 is a reply to message #660143] |
Thu, 07 April 2011 12:14  |
William,
I was doing this you described. I noticed that when you create an association between two classes, properties are created, so you may use them (it seems more accurate).
In my case, my classes weren't assoaciated to any other, so I created another class representing the top-level entity (System) and made the associations.
Thiago
FUDForum. Page generated in 0.33941 seconds
