Home » Eclipse Projects » Rich Client Platform (RCP) » Creating a console view in the RCP Application
Creating a console view in the RCP Application [message #660096] Wed, 16 March 2011 15:11 Go to next message
Hi.
I am new to RCP and am trying to add a console view, similar to the one in Eclipse in my RCP Application. I am unable to add the console itself. I want to display the log contents generated by log4j in it.
Currently I have tried 2 methods to add a console view, however to no avail.
1. I added the following to my Perspective.java class
MessageConsole myConsole = new MessageConsole("Console", Activator
.getImageDescriptor("icons/book.png"));
ConsolePlugin.getDefault().getConsoleManager()
.addConsoles(new IConsole[] { myConsole });
final MessageConsoleStream stream = myConsole.newMessageStream();
final PrintStream myS = new PrintStream(stream);
System.setOut(myS);
System.setErr(myS);
2. This is a piece of code I came across on one forum. the displayConsoleView is returning 'false'.
error received : Could not create view: org.eclipse.ui.console.ConsoleView
Do I have to create a view in the extensions of my application first? or should this be created at runtime?
package org.taf.ui;
import org.eclipse.jface.dialogs.MessageDialog;
import org.eclipse.jface.text.IDocument;
import org.eclipse.swt.SWT;
import org.eclipse.ui.IWorkbenchPage;
import org.eclipse.ui.IWorkbenchWindow;
import org.eclipse.ui.PartInitException;
import org.eclipse.ui.PlatformUI;
import org.eclipse.ui.console.ConsolePlugin;
import org.eclipse.ui.console.IConsole;
import org.eclipse.ui.console.IConsoleConstants;
import org.eclipse.ui.console.MessageConsole;
import org.eclipse.ui.console.MessageConsoleStream;
* Create an instance of this class in any of your plugin classes.
* Use it as follows ...
* ConsoleDisplayMgr.getDefault().println("Some error msg",
* ConsoleDisplayMgr.MSG_ERROR); ... ... ConsoleDisplayMgr.getDefault().clear();
public class ConsoleDisplayMgr {
private static ConsoleDisplayMgr fDefault = null;
private String fTitle = null;
private MessageConsole fMessageConsole = null;
public static final int MSG_INFORMATION = 1;
public static final int MSG_ERROR = 2;
public static final int MSG_WARNING = 3;
public ConsoleDisplayMgr(String messageTitle) {
fDefault = this;
fTitle = messageTitle;
public static ConsoleDisplayMgr getDefault() {
return fDefault;
public void println(String msg, int msgKind) {
if (msg == null)
return;
if (!displayConsoleView()) {
MessageDialog.openError(PlatformUI.getWorkbench()
.getActiveWorkbenchWindow().getShell(), "Error", msg);
return;
getNewMessageConsoleStream(msgKind).println(msg);
public void clear() {
IDocument document = getMessageConsole().getDocument();
if (document != null) {
document.set("");
public boolean displayConsoleView() {
try {
IWorkbenchWindow activeWorkbenchWindow = PlatformUI.getWorkbench()
.getActiveWorkbenchWindow();
if (activeWorkbenchWindow != null) {
IWorkbenchPage activePage = activeWorkbenchWindow
.getActivePage();
PlatformUI
.getWorkbench()
.getActivePage()
.showView(IConsoleConstants.ID_CONSOLE_VIEW, null,
IWorkbenchPage.VIEW_VISIBLE);
if (activePage != null)
activePage.showView(IConsoleConstants.ID_CONSOLE_VIEW,
null, IWorkbenchPage.VIEW_VISIBLE);
} catch (PartInitException partEx) {
return false;
return true;
private MessageConsoleStream getNewMessageConsoleStream(int msgKind) {
int swtColorId = SWT.COLOR_DARK_GREEN;
switch (msgKind) {
case MSG_INFORMATION:
break;
case MSG_ERROR:
swtColorId = SWT.COLOR_DARK_MAGENTA;
break;
case MSG_WARNING:
swtColorId = SWT.COLOR_DARK_BLUE;
break;
default:
MessageConsoleStream msgConsoleStream = getMessageConsole()
msgConsoleStream.setColor(Display.getCurrent().getSystemColo r(
swtColorId));
return msgConsoleStream;
private MessageConsole getMessageConsole() {
if (fMessageConsole == null)
createMessageConsoleStream(fTitle);
return fMessageConsole;
private void createMessageConsoleStream(String title) {
fMessageConsole = new MessageConsole(title, null);
.addConsoles(new IConsole[] { fMessageConsole });
Re: Creating a console view in the RCP Application [message #660205 is a reply to message #660096] Thu, 17 March 2011 07:07 Go to previous messageGo to next message
Did you add the plugin that contains the console view?
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Creating a console view in the RCP Application [message #660227 is a reply to message #660205] Thu, 17 March 2011 09:15 Go to previous messageGo to next message
when I add the org.eclipse.ui.console plugin in the dependencies.It gives me an error
Runtime exception : No application id has been found.
However if I include it in the runtime dependencies and execute, It gives me a Partinit error, at the location where the console id is provided in the displayConsoleView().
Re: Creating a console view in the RCP Application [message #660427 is a reply to message #660227] Fri, 18 March 2011 07:53 Go to previous messageGo to next message
You'll have to make sure you add all the dependencies you need to make
console work, or you cannot use it. In your launch config, if you
validate the plugins what does it say?
The part init error + other errors in the log should provide an idea of
why the console didn't show up.
http://random-eclipse-tips.blogspot.com/2009/03/eclipse-writ ing-to-console-in-rcp.html
Paul Webster
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Creating a console view in the RCP Application [message #663775 is a reply to message #660427] Wed, 06 April 2011 09:21 Go to previous messageGo to next message
I went through a sample code that displays a console in its RCP application. It sets the 'Console View'
in the Perspective.java itself. The 2 lines of code that do so are:
IFolderLayout consoleFolder = layout.createFolder("console",
IPageLayout.BOTTOM, 0.65f, "messages");
consoleFolder.addView(IConsoleConstants.ID_CONSOLE_VIEW);
The import used for this is:
and the org.eclipse.ui.console(3.5.0) has been included in the
dependencies.
However if I do the same in my application, it provides the following
error:
!ENTRY org.eclipse.osgi 4 0 2011-04-06 14:18:11.678
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(Eclips
eAppContainer.java:242)
org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicatio
nLauncher.java:29)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication
(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseA
ppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:3
9)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImp
l.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
As it was a runtime Exception, I added the org.eclipse.ui.console (3.5.0) in the runtime
dependencies. It now dozent give an error, but however it does not even display the console view.
any input is appreciated
Re: Creating a console view in the RCP Application [message #663794 is a reply to message #663775] Wed, 06 April 2011 09:33 Go to previous messageGo to next message
I've you've added it to an already open perspective, you'll have to
reset the perspective to see the change.
PW
Paul Webster
Re: Creating a console view in the RCP Application [message #664180 is a reply to message #663794] Thu, 07 April 2011 14:12 Go to previous messageGo to next message
I am not adding the console to an already open perspective. I want the console present when the application gets loaded.
I did try the reset perspective method,however it still does not work
snippet of the perspective.java:
import org.eclipse.ui.IFolderLayout;
import org.eclipse.ui.IPageLayout;
import org.eclipse.ui.IPerspectiveFactory;
public class Perspective implements IPerspectiveFactory {
static int count = 0;
public void createInitialLayout(IPageLayout layout) {
count++;
System.out.println("Perspective.createInitialLayout()");
layout.setEditorAreaVisible(false);
layout.addView("org.taf.ui.view.CatalogueBrowserVw", IPageLayout.LEFT,
0.23f, IPageLayout.ID_EDITOR_AREA);
layout.getViewLayout("org.taf.ui.view.CatalogueBrowserVw")
.setCloseable(false);
.createFolder("console", IPageLayout.BOTTOM, 0.65f,
"org.taf.ui.view.CatalogueBrowserVw");
if (count == 1) {
PlatformUI.getWorkbench().getActiveWorkbenchWindow()
.getActivePage().resetPerspective();
If i add the org.eclipse.ui.console to the dependencies, and then run, i get the following error:
!ENTRY org.eclipse.osgi 4 0 2011-04-07 23:41:22.858
!STACK 1
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
And if i add it in the runtime dependencies, i get :
!ENTRY org.eclipse.ui 4 4 2011-04-07 23:19:03.102
!MESSAGE Exception in org.eclipse.ui.internal.FolderLayout.addView(String): org.eclipse.ui.PartInitException: View descriptor not found: org.eclipse.ui.console.ConsoleView
!STACK 1
at org.eclipse.ui.internal.FolderLayout.addView(FolderLayout.ja va:75)
at org.taf.ui.Perspective.createInitialLayout(Perspective.java: 29)
at org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Pers pective.java:816)
at org.eclipse.ui.internal.Perspective.createPresentation(Persp ective.java:270)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:156)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation. createPerspective(Workbench3xImplementation.java:55)
at org.eclipse.ui.internal.WorkbenchPage.createPerspective(Work benchPage.java:1672)
at org.eclipse.ui.internal.WorkbenchPage.init(WorkbenchPage.jav a:2453)
at org.eclipse.ui.internal.WorkbenchPage.<init>(WorkbenchPage.java:563)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation. createWorkbenchPage(Workbench3xImplementation.java:39)
at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:768)
at org.eclipse.ui.internal.Workbench$23.runWithException(Workbe nch.java:1220)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3660)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$31.runWithException(Workbe nch.java:1566)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2537)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
at org.taf.ui.Application.start(Application.java:134)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
!SUBENTRY 1 org.eclipse.ui 4 0 2011-04-07 23:19:03.104
!MESSAGE View descriptor not found: org.eclipse.ui.console.ConsoleView
!ENTRY org.eclipse.ui 4 0 2011-04-07 23:19:03.107
!MESSAGE Unhandled event loop exception
!STACK 0
at org.taf.ui.Perspective.createInitialLayout(Perspective.java: 33)
Re: Creating a console view in the RCP Application [message #664333 is a reply to message #664180] Fri, 08 April 2011 08:07 Go to previous messageGo to next message
If those are your errors, then the plugin providing the console view is
not included in your launch config. Go to Run>Run Configurations and
make sure the console plugin is included, and then do a validate to make
sure your launch config is still sane.
PW
Paul Webster
Re: Creating a console view in the RCP Application [message #1007897 is a reply to message #664333] Thu, 07 February 2013 21:28 Go to previous messageGo to next message
Even i had same problem . Go to Run configuration. Select tab plugins and select add required plugins. The error is rectified
Re: Creating a console view in the RCP Application [message #1007900 is a reply to message #664333] Thu, 07 February 2013 22:13 Go to previous message
Go to Run>Run Configurations -> Plugins tab and select add required plugins. This will correct the error
Previous Topic:Help Home depending on user language
Next Topic:Nested "modal" editor?
Current Time: Fri Sep 26 09:12:49 EDT 2025
Powered by FUDForum. Page generated in 0.06357 seconds
