Home » Archived » SeMantic Information Logistics Architecture (SMILA) » Announcing changes in SMILA
Announcing changes in SMILA [message #660033] Wed, 16 March 2011 11:18 Go to next message
Originally posted by: juergen.schumacher.attensity.com
Hi folks,
About 3 weeks ago I wrote this on the dev mailing list:
>FYI: We started a branch of SMILA where we try to simplify some of the
> core elements of SMILA. This affects mainly the data model which we wa=
nt
> to redesign completely, but this has effects on many parts of the
> processing framework of SMILA. The branch URL is =
> https://dev.eclipse.org/svnroot/rt/org.eclipse.smila/branche s/2011-02-=
24_Simplification
>I also created a wiki page to document the changes we are doing there:
> http://wiki.eclipse.org/SMILA/Documentation/2011.Simplificat ion
>Not much has happened yet, but it definitely will in the next couple of=
> weeks (: The merge back to trunk is currently planned to happen in abo=
ut
> 4 weeks.
>Cheers,
> J=C3=BCrgen
We're done with these modifications now and planning to move these
changes back to trunk until end of week. To do this, I will create a tag=
from the current state of the trunk, so if you really want to continue
with the current state of SMILA, you can do this by switching to this
tag. Then I'll probably just replace the complete trunk with the branch
(no worries, I constantly merged all trunk changes in the last 3 weeks
to the branch, so nothing will get lost). You will have to adapt your
own implementations then, which can be quite some work (we've gone
through this ourselves by now), but be assured: It's worth it (-;
J=C3=BCrgen.
Re: Announcing changes in SMILA [message #660242 is a reply to message #660033] Thu, 17 March 2011 09:51 Go to previous message
I've replaced the SMILA trunk by the branch. Additionally I added a bit
of structure to the SMILA trunk (as proposed by Thomas Menzel ... but
it's not his complete proposal yet):
- The SMILA "core" bundles are now in
https://dev.eclipse.org/svnroot/rt/org.eclipse.smila/trunk/c ore
This is currently all you need to setup a SMILA workspace for
development.
- The SMILA extension for the Eclipse BPEL designer are now in
https://dev.eclipse.org/svnroot/rt/org.eclipse.smila/trunk/t ooling
- I didn't change the SMILA.releng (now named "releng" folder for now,
I have to adapt the PSF file in there later.
- Also the URL files to the guideline and setup web pages are still in
trunk/. I think that's a good place for them.
Have fun!
J=C3=BCrgen.
Previous Topic:Deleting stored records
Next Topic:Flushing records to late
Current Time: Wed Aug 06 00:40:27 EDT 2025
Powered by FUDForum. Page generated in 0.04830 seconds
