Home » Modeling » EMF » [CDO] Win7 DbStore starts OK but CDO Explorer cannot connect
Re: [CDO] Win7 DbStore starts OK but CDO Explorer cannot connect [message #659824 is a reply to message #659823] |
Tue, 15 March 2011 17:54 |
Am 15.03.2011 18:53, schrieb Eike Stepper:
> Am 15.03.2011 18:08, schrieb David Wynter:
>> I have successfully setup a CDO DbStore repo on Win7_x64. I can see from the logs (I turned tracing on for all packages) that the "CDO Server started" with no errors.
>> I am using the standards org.eclipse.emf.cdo.server.product-feature with a modified cdo-server.xml to have the databaseName for Derby to point at a local directory.
>> When I use CDO Explorer perspective to connect to this repo on localhost:2036 it gives me a "org.eclipse.net4j.util.concurrent.TimeoutRuntimeException: Registration timeout after 10000 milliseconds"
>> Is there any other log file or somewhere that might tell me why this is happening? When I use osgi>clode, it closes down without any exceptions. There are no exceptions I can find anywhere.
> Most commonly this is because the org.eclipse.emf.cdo.server.net4j is not deployed properly to the server.
And org.eclipse.net4j.tcp is also needed on the server. Please also check your firewall settings.
I doubt this is a Win7_64 related issue, as I'm using the same for development ;-)
Cheers
/Eike
http://www.esc-net.de
Cheers
/Eike
Re: [CDO] Win7 DbStore starts OK but CDO Explorer cannot connect [message #659825 is a reply to message #659814] |
Tue, 15 March 2011 17:56 |
David Wynter Messages: 4624 Registered: July 2009 |
> a local directory.
> Thx.
> David
I checked netstat -A and there is nothing on port 2036 on 0.0.0.0 or
127.0.0.1 ( I tried both in the config )
Here is the last part of the startup console output:
app thread - org.eclipse.emf.cdo.server.app.0 [debug.lifecycle.dump]
DUMP SmartPreparedStatementCache@25
AbstractPreparedStatementCache.connection =
org.apache.derby.impl.jdbc.EmbedConnection40@515768123 (XID = 715),
(SESSIONID = 15), (DATABASE =
C:/Users/David/workspace/com.example.mdwmui/cdo/derbyedmmode l), (DRDAID
= null)
cache =
org.eclipse.emf.cdo.server.internal.db.SmartPreparedStatemen tCache$Cache@4bbf8a41
checkedOut =
DUMP DBStoreAccessor@24
StoreAccessor.commitContexts =
StoreAccessor.store = DBStore@5
StoreAccessor.context = null
StoreAccessor.reader = true
connection = org.apache.derby.impl.jdbc.EmbedConnection40@515768123
(XID = 715), (SESSIONID = 15), (DATABASE =
= null)
connectionKeepAliveTask =
org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor$ConnectionKeepAliveTask@c0dd841
statementCache = SmartPreparedStatementCache@25
newObjects =
app thread - org.eclipse.emf.cdo.server.app.0 [debug] Created Resource
Query: a228c043-012e-ba8c-7a96-00000400ed18
Query: ea5bc046-012e-ba8c-7a96-00000400ed18
app thread - org.eclipse.emf.cdo.server.app.0 [debug] Resource query
returned ID 1
app thread - org.eclipse.emf.cdo.server.app.0 [debug.lifecycle]
Deactivating DBStoreAccessor@24
Deactivating SmartPreparedStatementCache@25
DUMP Default@26
Repository.name = edmodelrepo
Repository.uuid = null
Repository.store = DBStore@5
Repository.type = MASTER
Repository.state = ONLINE
Repository.properties =
supportingAudits=true
supportingEcore=true
supportingBranches=true
overrideUUID=
Repository.supportingAudits = true
Repository.supportingBranches = true
Repository.ensuringReferentialIntegrity = false
Repository.packageRegistry =
http://www.eclipse.org/emf/2002/Ecore=CDOPackageInfo[packageURI=http://www.eclipse.org/emf/2002/Ecore,
parentURI=null, metaIDRange=[MID1:MID420]]
http://www.eclipse.org/emf/CDO/Eresource/2.0.0=CDOPackageInf o[packageURI=http://www.eclipse.org/emf/CDO/Eresource/2.0.0,
parentURI=null, metaIDRange=[MID421:MID455]]
Repository.branchManager = CDOBranchManagerImpl@21
Repository.revisionManager = CDORevisionManagerImpl@15
Repository.commitInfoManager = CDOCommitInfoManagerImpl@18
Repository.sessionManager = SessionManager@14
Repository.queryManager = QueryManager@17
Repository.commitManager = CommitManager@19
Repository.lockManager = LockManager@20
Repository.queryHandlerProvider = null
Repository.readAccessHandlers =
Repository.writeAccessHandlers =
Repository.rootResourceID = OID1
[INFO] CDO server started
!ENTRY org.eclipse.emf.cdo.server 1 0 2011-03-15 17:24:55.054
!MESSAGE CDO server started
Application Started: 5792
Plugins enabled ( clicked "Add required plugins") include
org.apache.derby (10.5.1.1)
org.apache.derby.core
org.eclipse.emf.cdo (3.0.1)
org.eclipse.emf.cdo.common
org.eclipse.emf.cdo.server.db
org.eclipse.net4j (3.0.1)
org.eclipse.net4j.db
org.eclipse.net4j.db.derby
org.eclipse.net4j.derby
Helios SR2
Without exceptions being thrown kinda hard to know where to look next.
David
Re: [CDO] Win7 DbStore starts OK but CDO Explorer cannot connect [message #659827 is a reply to message #659826] |
Tue, 15 March 2011 18:06 |
Ha,
I missed the org.eclipse.emf.cdo.server.tcp. I was following this
http://wiki.eclipse.org/Setting_up_a_CDO_Server
And it lists these
* org.apache.derby
* org.eclipse.emf.cdo.server.db
* org.eclipse.net4j.db.derby
* org.eclipse.net4j.tcp
And the "Add required plugins" does not pick it up, opps.
Thx.
David
>> development ;-)
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>> http://twitter.com/eikestepper
> Firewall allows all ports in and out for Eclipse. But to be safe I added
> a new rule to allow port 2036 in and out for anything. It satill does
> not appear in netstat -A on 0.0.0.0
> As in my recent post, net4j is enabled in the plugins
> Thx.
> David
Re: [CDO] Win7 DbStore starts OK but CDO Explorer cannot connect [message #659834 is a reply to message #659827] |
Tue, 15 March 2011 18:10 |
Am 15.03.2011 19:06, schrieb David Wynter:
> Ha,
There's no such plugin. You mean org.eclipse.emf.cdo.server.net4j? That's important and Add Required Plugins wouldn't pick it up because it's optional from a repository's perspective. So, does it work now?
Cheers
/Eike
> And it lists these
> * org.apache.derby
> Thx.
> David
>>> development ;-)
>>> Cheers
>>> /Eike
>> Hi,
>> Thx.
>> David
Cheers
/Eike
Re: [CDO] Win7 DbStore starts OK but CDO Explorer cannot connect [message #659835 is a reply to message #659834] |
Tue, 15 March 2011 18:28 |
Yeah, sorry, what you said ;)
Yes it works fine, the tutorial just needs to have
added to the list, which I just did.
Thx.
David
>> Ha,
> Cheers
> /Eike
>> And it lists these
>> * org.apache.derby
>> Thx.
>> David
>>>> development ;-)
>>>> Cheers
>>>> /Eike
>>> Hi,
>>> Thx.
>>> David
Re: [CDO] Win7 DbStore starts OK but CDO Explorer cannot connect [message #659876 is a reply to message #659835] |
Tue, 15 March 2011 20:42 |
Am 15.03.2011 19:28, schrieb David Wynter:
> Yes it works fine,
Great ;-)
Thank you!
Cheers
/Eike
> Thx.
> David
>>> Ha,
>> Cheers
>> /Eike
>>> And it lists these
>>> * org.apache.derby
>>> Thx.
>>> David
>>>>> development ;-)
>>>>> Cheers
>>>>> /Eike
>>>> Hi,
>>>> Thx.
>>>> David
Cheers
/Eike
Current Time: Thu Sep 19 20:43:40 GMT 2024
Powered by FUDForum. Page generated in 0.03934 seconds
