Home » Modeling » EMF » [CDO] Objectivity store
[CDO] Objectivity store [message #659762] Tue, 15 March 2011 10:22 Go to next message
Hi all,
I've being doing some debug on CDO using Objectivity store and I would like to ask some questions around this implementation, mainly regarding its testing project and the expected test results from running the full suite.
I have tested the store on both CDO version 3 and 4 using AllTestsObjyBranching suite.
Both versions would not pass the full test suite of CDO, so I am wondering is that a normal situation or is there any upcoming fixes, also I would like to know if this can cause errors in the future and if this implementation is 'safe' to use and in which case it will not be.
As an example, the following test would not pass fully and have some errors or failures ComplexTest, BranchingTestWithCacheClear (testCommit, testCommitAddOrderDetail, testCommitRemoveOrderDetail).
I can provide the traces if required,
Thanks a lot,
Re: [CDO] Objectivity store [message #659812 is a reply to message #659762] Tue, 15 March 2011 12:52 Go to previous messageGo to next message
Hi Kaab,
I've cc'ed Ibe from Objectivity in the hope that he can answer your questions and confirm that the info on http://wiki.eclipse.org/CDO/Objectivity_Store is up to date...
Cheers
/Eike
http://www.esc-net.de
Am 15.03.2011 15:22, schrieb kaab:
> Hi all,
> Thanks a lot,
Re: [CDO] Objectivity store [message #659843 is a reply to message #659762] Tue, 15 March 2011 14:48 Go to previous messageGo to next message
Hi Kaab,
Sorry about that, I haven't updated the store for almost a year now. I do have a new code base that I'll check into 3.0 sometime this week (hopefully), it should be more stable, and more performant. I'll check the tests and will make sure they pass.
I'll update the 4.0 base as well.
Ibrahim
Re: [CDO] Objectivity store [message #660016 is a reply to message #659843] Wed, 16 March 2011 10:50 Go to previous messageGo to next message
Hi all,
Thanks for the fast reply,
I've been working on this yesterday, so I produced a small patch at least for the tests I mentioned, using this patch will help get rid of some errors in the handling of Deltas and should get the BranchingTest to pass more tests.
There's still an issue on the detach (BranchingTestWithCacheClear), but I didn't figure this one out yet,
You'll find the patch at the end of this message.
Please let me know what you think,
Index: src/org/eclipse/emf/cdo/server/internal/objectivity/Objectiv ityStoreAccessor.java
--- src/org/eclipse/emf/cdo/server/internal/objectivity/Objectiv ityStoreAccessor.java (revision 7110)
+++ src/org/eclipse/emf/cdo/server/internal/objectivity/Objectiv ityStoreAccessor.java (working copy)
@@ -423,15 +423,20 @@
if (getStore().isRequiredToSupportAudits())
// newObjyRevision = objySession.getObjectManager().copyRevision(this, objyRevision);
- objyRevision.setRevisedTime(branch.getPoint(created).getTime Stamp() - 1);
// objyRevision.setRevisedBranchId(branch.getID();
InternalCDORevision originalRevision = getStore().getRepository().getRevisionManager()
.getRevisionByVersion(delta.getID(), delta, 0, true);
InternalCDORevision newRevision = originalRevision.copy();
- newRevision.setVersion(deltaVersion + 1);
- newRevision.setBranchPoint(delta.getBranch().getPoint(create d));
+ // newRevision.setVersion(deltaVersion + 1);
+ // newRevision.setBranchPoint(delta.getBranch().getPoint(create d));
+ newRevision.adjustForCommit(branch, created);
+ if (newRevision.getVersion() != CDORevision.FIRST_VERSION)
+ objyRevision.setRevisedTime(branch.getPoint(created).getTime Stamp() - 1);
newObjyRevision = objySession.getObjectManager().newObject(newRevision.getECla ss(), objyRevision.ooId());
newObjyRevision.update(this, newRevision);
objyObject.addToRevisions(newObjyRevision);
Re: [CDO] Objectivity store [message #660065 is a reply to message #660016] Wed, 16 March 2011 13:20 Go to previous messageGo to next message
Hi Kaab,
I'm glad to see that you can help and want to. But it strikes me that a bugzilla would be a better place to exchange patches and capture discussions ;-)
Cheers
/Eike
Am 16.03.2011 15:50, schrieb kaab:
> Hi all,
> Thanks
Re: [CDO] Objectivity store [message #660081 is a reply to message #660065] Wed, 16 March 2011 14:21 Go to previous messageGo to next message
Hi Eike,
My bad,
I'd be happy to help as much as I can.
The bug reported is created :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=340205
Re: [CDO] Objectivity store [message #660086 is a reply to message #660081] Wed, 16 March 2011 14:33 Go to previous message
Am 16.03.2011 19:21, schrieb kaab:
> Hi Eike,
> My bad,
No worries!
> The bug reported is created : https://bugs.eclipse.org/bugs/show_bug.cgi?id=340205
Thank you ;-)
Cheers
/Eike
Previous Topic:EMF Support for xsd:override
Next Topic:De-serialization of extended eCore models
Current Time: Wed Nov 05 16:32:29 EST 2025
Powered by FUDForum. Page generated in 0.24841 seconds
