Re: EMF Editor and CrossReference [message #659246 is a reply to message #659211] |
Fri, 11 March 2011 15:26 |
Ed Merks Messages: 33218 Registered: July 2009 |
--------------040407020401090506050802
David,
If you generated them from a single GenModel it would work. Or you
could use the approach described here:
http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt-know.html
David wrote:
> Hi, my question is the following: Is there a way to manage two models
> in the same generated editor. For example :
> (I have two model where i generate Model / Edit / Editor).
> Model 1:
> Class A , contains many 'AbstractA'
> 'AConcrete' extends 'AbstractA'
> Model 2 (in a different plugin):
> Class B extends 'AbstractA' by cross-reference to model 1.
> When i generate editor for model1 and execute it, when i use the
> custom editor generated for model1 and i try to create new element
> from Class A, using the right-click .. createChild, the only element
> that appears is 'AConcrete'. Is there a way to show 'Class B' also?
> This should not be a problem because Class B extends the same element
> as 'AConcrete'.
> Is there something i'm doing wrong? or is there any options in the
> genModel that allow me to achieve this?
> Thanks for your help
> David C.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
David,<br>
<br>
could use the approach described here:<br>
<blockquote><a
href=" http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt-know.html"> http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt-know.html</a><br>
</blockquote>
<br>
David wrote:
<blockquote cite="mid:ildcrm$que$1@news.eclipse.org" type="cite">Hi, my
question is the following: Is there a way to manage two models in the
<br>
<br>
<br>
<br>
Model 1:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
When i generate editor for model1 and execute it, when i use the custom
editor generated for model1 and i try to create new element from Class
A, using the right-click .. createChild, the only element that appears
<br>
<br>
as 'AConcrete'.
<br>
<br>
<br>
<br>
<br>
<br>
David C.
<br>
</blockquote>
</body>
</html>
--------------040407020401090506050802--
Ed Merks
FUDForum. Page generated in 0.03776 seconds
