| Adding children, to a nested rectangle. [message #658963] |
Thu, 10 March 2011 09:54  |
Suppose, I want to be able to add children to a rectangle which is
nested into another rectangle. Normally, this is not possible, as the
contentPane is always the parent rectangle. In order to make is possible
I am doing this in the editpart:
(I override getContentPane to return a child rectangle, produced with a
child access).
public IFigure getContentPane() {
if (contentPane != null) {
if(contentPane instanceof CabinetFigure){
return ((CabinetFigure)contentPane).getFigureSubrackContainer();
return super.getContentPane();
Is this somehow possible with GMF Tooling? I noticed, a Node has a
property named: Content Pane. Setting this to a child access to a nested
rectangle, doesn't seem to change the generated edit part.
Thanks, Christophe Bouhier
| Re: Adding children, to a nested rectangle. [message #659345 is a reply to message #659153] |
Sat, 12 March 2011 09:22  |
On 11-03-11 11:07, Mickael Istria wrote:
> Do you want to have a figure which is made of 2 rectangles (one inner
> and one container), but which will be a single editPart,
or do you want
> to have the first rectangle an editPart which will contain another
> editPart as an inner rectangle?
> For the first use case, that would be simply about defining the figure
> correctly in the gmfgraph;
> For the second use case, that would be simple containment using
> ChildReference for your node mapping in gmfmap.
Thanks Mickael, I try to avoid containments. I have no requirements for
collapsible, and even if I turn it off, I will have limited options for
layouts. (As containments only support a ListLayout or a XYLayout).
> HTH
FUDForum. Page generated in 0.03807 seconds
