Re: ECF plugins disappear... [message #659938 is a reply to message #659733] |
Wed, 16 March 2011 08:43 |
Ivan Furnadjiev Messages: 2427 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Peter,
if you are using RAP target platform 1.4 Mx with Eclipse 3.6.x this
message is normal. The latest Eclipse version is 3.7 M6. About your
problem with ECF, I still don't understand how do you compose your
target and how the "ECF plugins disappear".
Best,
Ivan
On 3/15/2011 2:10 PM, Peter Boccia wrote:
> Hi Ivan,
> I add to my target platform from p2 repository.
> Another question: is normal that when I add from the zip file, Eclipse
> shows me a warning: "You have selected a target with a newer version
> than your current Eclipse installation. This can cause unexpected
> behaviour in PDE. Please use a newer version of Eclipse" (but instead
> I download again today the last version)?
> Every day a new problem and I didn't see anything for my thesis... The
> prof ask me only a simple chat between two client in ECF because
> coffee is so far to do now.
> Hope to get my degree soon.
> Thank you all of you!
> Ivan Furnadjiev wrote on Mon, 14 March 2011 12:25
>> Hi Peter,
>> could you explain a little bit more (step-by-step) how did you setup
>> your target platform? Create it manually from RAP, ECF and EMF for
>> RAP downloads or use p2 repository?
>> Best,
>> Ivan
>> On 3/9/2011 1:22 PM, Peter Boccia wrote:
>> > Something wrong happens when I load in my Target Platform
>> > - RAP target platform
>> > - ECF
>> > - EMF for RAP
>> > After I download EMF for RAP, ECF won't work anyway also if I pull
>> out > the EMF. The only thing for fixing this is to download again
>> eclipse > and repeat the setting 'till ECF.
>> > What's wrong with EMF for RAP?
FUDForum. Page generated in 0.04319 seconds
