Home » Language IDEs » Java Development Tools (JDT) » Updating jee package to 1.3.2 causes javax.net.ssl.SSLKeyException: RSA premaster secret error
Updating jee package to 1.3.2 causes javax.net.ssl.SSLKeyException: RSA premaster secret error [message #658545] |
Tue, 08 March 2011 21:47 |
David Becker Messages: 13 Registered: July 2009 |
After updating my system (OS X) to Eclipse IDE for Java EE Developers, 1.3.2.20110301-1807, epp.package.jee
I now get a "javax.net.ssl.SSLKeyException: RSA premaster secret error" while starting up my webapp on my
tomcat instance from the IDE. I've done some testing to try and figure it out, and have confirmed that the ONLY
thing changing is the jee package version. Oddly enough, reverting the eclipse configuration with the built in
tools does NOT fix it. I had to restore my entire eclipse folder and workspace folder back to get it working again.
It's as if the new version writes something in the project...
Does anyone have any ideas or suggestions? I like to keep up on my upgrades, but can't take this one for now.
Here's the exact errors I get:
Mar 4, 2011 12:19:47 PM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: .:/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java
Mar 4, 2011 12:19:47 PM org.apache.tomcat.util.digester.SetPropertiesRule begin
WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.jee.server:docsportal' did not find a matching property.
WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context/Loader} Setting property 'useSystemClassLoaderAsParent' to 'false' did not find a matching property.
Mar 4, 2011 12:19:48 PM org.apache.coyote.AbstractProtocolHandler init
INFO: Initializing ProtocolHandler ["http-bio-8888"]
Mar 4, 2011 12:19:48 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 624 ms
Mar 4, 2011 12:19:48 PM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
Mar 4, 2011 12:19:48 PM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.8
Mar 4, 2011 12:19:49 PM com.microsoft.sqlserver.jdbc.TDSChannel enableSSL
INFO: java.security path: /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/lib/security
Security providers: [SunPKCS11-Darwin version 1.6, SUN version 1.6, Apple version 1.0, SunRsaSign version 1.5, SunJSSE version 1.6, SunJCE version 1.6, SunJGSS version 1.0, SunSASL version 1.5, XMLDSig version 1.0, SunPCSC version 1.6]
SSLContext provider info: Sun JSSE provider(PKCS12, SunX509 key/trust factories, SSLv3, TLSv1)
SSLContext provider services:
[SunJSSE: KeyFactory.RSA -> sun.security.rsa.RSAKeyFactory
aliases: [1.2.840.113549.1.1, OID.1.2.840.113549.1.1]
, SunJSSE: KeyPairGenerator.RSA -> sun.security.rsa.RSAKeyPairGenerator
, SunJSSE: Signature.MD2withRSA -> sun.security.rsa.RSASignature$MD2withRSA
aliases: [1.2.840.113549.1.1.2, OID.1.2.840.113549.1.1.2]
, SunJSSE: Signature.MD5withRSA -> sun.security.rsa.RSASignature$MD5withRSA
aliases: [1.2.840.113549.1.1.4, OID.1.2.840.113549.1.1.4]
, SunJSSE: Signature.SHA1withRSA -> sun.security.rsa.RSASignature$SHA1withRSA
aliases: [1.2.840.113549.1.1.5, OID.1.2.840.113549.1.1.5, 1.3.14.3.2.29, OID.1.3.14.3.2.29]
, SunJSSE: Signature.MD5andSHA1withRSA -> com.sun.net.ssl.internal.ssl.RSASignature
, SunJSSE: KeyManagerFactory.SunX509 -> com.sun.net.ssl.internal.ssl.KeyManagerFactoryImpl$SunX509
, SunJSSE: KeyManagerFactory.NewSunX509 -> com.sun.net.ssl.internal.ssl.KeyManagerFactoryImpl$X509
, SunJSSE: TrustManagerFactory.SunX509 -> com.sun.net.ssl.internal.ssl.TrustManagerFactoryImpl$SimpleFactory
, SunJSSE: TrustManagerFactory.PKIX -> com.sun.net.ssl.internal.ssl.TrustManagerFactoryImpl$PKIXFactory
aliases: [SunPKIX, X509, X.509]
, SunJSSE: SSLContext.SSL -> com.sun.net.ssl.internal.ssl.SSLContextImpl
, SunJSSE: SSLContext.SSLv3 -> com.sun.net.ssl.internal.ssl.SSLContextImpl
, SunJSSE: SSLContext.TLS -> com.sun.net.ssl.internal.ssl.SSLContextImpl
, SunJSSE: SSLContext.TLSv1 -> com.sun.net.ssl.internal.ssl.SSLContextImpl
, SunJSSE: SSLContext.Default -> com.sun.net.ssl.internal.ssl.DefaultSSLContextImpl
, SunJSSE: KeyStore.PKCS12 -> com.sun.net.ssl.internal.pkcs12.PKCS12KeyStore
java.ext.dirs: /Library/Java/Extensions:/System/Library/Java/Extensions:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/lib/ext
[2011-03-04 12:19:49,713] [WARN] [Thread-2] [org.hibernate.cfg.SettingsFactory]: Could not obtain connection to query metadata
org.apache.tomcat.dbcp.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "RSA premaster secret error".)
at org.apache.tomcat.dbcp.dbcp.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:1549)
at org.apache.tomcat.dbcp.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1388)
at org.apache.tomcat.dbcp.dbcp.BasicDataSource.getConnection(BasicDataSource.java:1044)
at org.hibernate.connection.DatasourceConnectionProvider.getConnection(DatasourceConnectionProvider.java:92)
at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:114)
at org.hibernate.cfg.Configuration.buildSettingsInternal(Configuration.java:2833)
at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2829)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1840)
at com.ahcrx.docs.util.Hibernate.getSessionFactory(Hibernate.java:28)
at com.ahcrx.docs.util.Hibernate.getCurrentSession(Hibernate.java:34)
at com.ahcrx.docs.util.Hibernate.isActiveTransaction(Hibernate.java:38)
at com.ahcrx.docs.listener.QuartzListener.contextInitialized(QuartzListener.java:30)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4600)
at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5097)
at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5092)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:680)
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "RSA premaster secret error".
at com.microsoft.sqlserver.jdbc.SQLServerConnection.terminate(SQLServerConnection.java:1352)
at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1533)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:1042)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:817)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:700)
at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:842)
at org.apache.tomcat.dbcp.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at org.apache.tomcat.dbcp.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:582)
at org.apache.tomcat.dbcp.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1556)
at org.apache.tomcat.dbcp.dbcp.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:1545)
... 19 more
Caused by: javax.net.ssl.SSLKeyException: RSA premaster secret error
at com.sun.net.ssl.internal.ssl.RSAClientKeyExchange.<init>(RSAClientKeyExchange.java:97)
at com.sun.net.ssl.internal.ssl.ClientHandshaker.serverHelloDone(ClientHandshaker.java:744)
at com.sun.net.ssl.internal.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:238)
at com.sun.net.ssl.internal.ssl.Handshaker.processLoop(Handshaker.java:593)
at com.sun.net.ssl.internal.ssl.Handshaker.process_record(Handshaker.java:529)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:893)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1138)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1165)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1149)
at com.microsoft.sqlserver.jdbc.TDSChannel.enableSSL(IOBuffer.java:1483)
... 27 more
Caused by: java.security.NoSuchAlgorithmException: SunTlsRsaPremasterSecret KeyGenerator not available
at javax.crypto.KeyGenerator.<init>(DashoA13*..)
at javax.crypto.KeyGenerator.getInstance(DashoA13*..)
at com.sun.net.ssl.internal.ssl.JsseJce.getKeyGenerator(JsseJce.java:223)
at com.sun.net.ssl.internal.ssl.RSAClientKeyExchange.<init>(RSAClientKeyExchange.java:89)
... 36 more
Mar 4, 2011 12:19:51 PM com.microsoft.sqlserver.jdbc.TDSChannel enableSSL
[2011-03-04 12:19:51,765] [WARN] [Thread-2] [org.hibernate.util.JDBCExceptionReporter]: SQL Error: 0, SQLState: null
[2011-03-04 12:19:51,765] [ERROR] [Thread-2] [org.hibernate.util.JDBCExceptionReporter]: Cannot create PoolableConnectionFactory (The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "RSA premaster secret error".)
Mar 4, 2011 12:19:51 PM org.apache.catalina.core.StandardContext listenerStart
SEVERE: Exception sending context initialized event to listener instance of class com.ahcrx.docs.listener.QuartzListener
org.hibernate.exception.GenericJDBCException: Cannot open connection
at org.hibernate.exception.SQLStateConverter.handledNonSpecificException(SQLStateConverter.java:140)
at org.hibernate.exception.SQLStateConverter.convert(SQLStateConverter.java:128)
at org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExceptionHelper.java:66)
at org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExceptionHelper.java:52)
at org.hibernate.jdbc.ConnectionManager.openConnection(ConnectionManager.java:449)
at org.hibernate.jdbc.ConnectionManager.getConnection(ConnectionManager.java:167)
at org.hibernate.jdbc.JDBCContext.connection(JDBCContext.java:160)
at org.hibernate.transaction.JDBCTransaction.begin(JDBCTransaction.java:81)
at org.hibernate.impl.SessionImpl.beginTransaction(SessionImpl.java:1473)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.hibernate.context.ThreadLocalSessionContext$TransactionProtectionWrapper.invoke(ThreadLocalSessionContext.java:344)
at $Proxy22.beginTransaction(Unknown Source)
at com.ahcrx.docs.util.Hibernate.beginTransaction(Hibernate.java:43)
at com.ahcrx.docs.listener.QuartzListener.contextInitialized(QuartzListener.java:31)
Caused by: org.apache.tomcat.dbcp.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (The driver could not establish a secure connection to SQL Server by using Secure Sockets Layer (SSL) encryption. Error: "RSA premaster secret error".)
at org.hibernate.jdbc.ConnectionManager.openConnection(ConnectionManager.java:446)
... 20 more
... 24 more
... 32 more
... 41 more
Mar 4, 2011 12:19:51 PM org.apache.catalina.core.StandardContext startInternal
SEVERE: Error listenerStart
SEVERE: Context [/XYZZY] startup failed due to previous errors
Mar 4, 2011 12:19:51 PM org.apache.catalina.loader.WebappClassLoader clearReferencesJdbc
SEVERE: The web application [/XYZZY] registered the JDBC driver [com.microsoft.sqlserver.jdbc.SQLServerDriver] but failed to unregister it when the web application was stopped. To prevent a memory leak, the JDBC Driver has been forcibly unregistered.
Mar 4, 2011 12:19:51 PM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory host-manager
INFO: Deploying web application directory manager
Mar 4, 2011 12:19:51 PM org.apache.coyote.AbstractProtocolHandler start
INFO: Starting ProtocolHandler ["http-bio-8888"]
Mar 4, 2011 12:19:51 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 3779 ms
My configuration details:
[code]
*** Date: Tuesday, March 8, 2011 1:45:12 PM Pacific Standard Time
*** Platform Details:
*** System properties:
awt.nativeDoubleBuffering=true
awt.toolkit=apple.awt.CToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20100909-0800
eclipse.commands=-os
macosx
-ws
cocoa
-arch
x86_64
-showsplash
-launcher
/Applications/eclipse/Eclipse.app/Contents/MacOS/eclipse
-name
Eclipse
--launcher.library
/Applications/eclipse/Eclipse.app/Contents/MacOS//../../../p lugins/org.eclipse.equinox.launcher.cocoa.macosx.x86_64_1.1. 1.R36x_v20100810/eclipse_1309.so
-startup
/Applications/eclipse/Eclipse.app/Contents/MacOS/../../../pl ugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar
-product
org.eclipse.epp.package.jee.product
-keyring
/Users/dbecker/.eclipse_keyring
-showlocation
-vm
/System/Library/Frameworks/JavaVM.framework
eclipse.home.location=file:/Applications/eclipse/
eclipse.launcher=/Applications/eclipse/Eclipse.app/Contents/ MacOS/eclipse
eclipse.launcher.name=Eclipse
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=epp.package.jee
eclipse.product=org.eclipse.epp.package.jee.product
eclipse.startTime=1299620662550
eclipse.vm=/System/Library/Frameworks/JavaVM.framework
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
-XstartOnFirstThread
-Dorg.eclipse.swt.internal.carbon.smallFonts
-XX:MaxPermSize=256m
-Xms1024m
-Xmx2048m
-Xdock:icon=../Resources/Eclipse.icns
-Djava.class.path=/Applications/eclipse/Eclipse.app/Contents /MacOS/../../../plugins/org.eclipse.equinox.launcher_1.1.0.v 20100507.jar
equinox.use.ds=true
file.encoding=MacRoman
file.encoding.pkg=sun.io
file.separator=/
ftp.nonProxyHosts=local|*.local|169.254/16|*.169.254/16
gopherProxySet=false
java.awt.graphicsenv=apple.awt.CGraphicsEnvironment
java.awt.printerjob=apple.awt.CPrinterJob
java.class.path=/Applications/eclipse/Eclipse.app/Contents/M acOS/../../../plugins/org.eclipse.equinox.launcher_1.1.0.v20 100507.jar
java.class.version=50.0
java.endorsed.dirs=/System/Library/Java/JavaVirtualMachines/ 1.6.0.jdk/Contents/Home/lib/endorsed
java.ext.dirs=/Library/Java/Extensions:/System/Library/Java/ Extensions:/System/Library/Java/JavaVirtualMachines/1.6.0.jd k/Contents/Home/lib/ext
java.home=/System/Library/Java/JavaVirtualMachines/1.6.0.jdk /Contents/Home
java.io.tmpdir=/var/folders/9Y/9YJB8hudG4ebkU5ULdsRCE+++TU/- Tmp-/
java.library.path=.:/Library/Java/Extensions:/System/Library /Java/Extensions:/usr/lib/java
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_22-b04-307-10M3261
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor=Apple Inc.
java.vendor.url=http://www.apple.com/
java.vendor.url.bug=http://bugreport.apple.com/
java.version=1.6.0_22
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Apple Inc.
java.vm.version=17.1-b03-307
line.separator=
mrj.build=10M3261
mrj.version=1060.1.6.0_22-307
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.NoOpLog
org.eclipse.debug.ui.breakpoints.toggleFactoriesUsed=false
org.eclipse.equinox.launcher.splash.location=/Applications/e clipse/plugins/org.eclipse.platform_3.6.1.v201009090800/spla sh.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator/bundles.info
org.eclipse.swt.internal.carbon.smallFonts=
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2S E-1.4,J2SE-1.5,JavaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=MacOSX
org.osgi.framework.os.version=10.6.6
org.osgi.framework.processor=x86-64
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.ws.wsaddressing,javax.xml.xpath,org.i etf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.p ortable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage ,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.om g.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.om g.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.Dyn amicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.Dyna micAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPac kage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.Port ableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPacka ge,org.omg.PortableServer,org.omg.PortableServer.CurrentPack age,org.omg.PortableServer.POAManagerPackage,org.omg.Portabl eServer.POAPackage,org.omg.PortableServer.portable,org.omg.P ortableServer.ServantLocatorPackage,org.omg.SendingContext,o rg.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w 3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.l s,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.tra versal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.x ml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.5.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86_64
os.name=Mac OS X
os.version=10.6.6
osgi.arch=x86_64
osgi.bundles=reference:file: org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503.jar @1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=/Applications/eclipse/configuration/org.ecl ipse.osgi/bundles
osgi.configuration.area=file:/Applications/eclipse/configura tion/
osgi.framework=file:/Applications/eclipse/plugins/org.eclips e.osgi_3.6.1.R36x_v20100806.jar
osgi.framework.extensions=
osgi.framework.shape=jar
osgi.framework.version=3.6.1.R36x_v20100806
osgi.install.area=file:/Applications/eclipse/
osgi.instance.area=file:/Users/dbecker/Documents/workspace/
osgi.instance.area.default=file:/Users/dbecker/Documents/wor kspace/
osgi.logfile=/Users/dbecker/Documents/workspace/.metadata/.l og
osgi.manifest.cache=/Applications/eclipse/configuration/org. eclipse.osgi/manifests
osgi.nl=en_US
osgi.os=macosx
osgi.splashLocation=/Applications/eclipse/plugins/org.eclips e.platform_3.6.1.v201009090800/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/Applications/eclipse/plugins
osgi.tracefile=/Users/dbecker/Documents/workspace/.metadata/ trace.log
osgi.ws=cocoa
path.separator=:
socksNonProxyHosts=local|*.local|169.254/16|*.169.254/16
sun.arch.data.model=64
sun.boot.class.path=/System/Library/Java/JavaVirtualMachines /1.6.0.jdk/Contents/Classes/jsfd.jar:/System/Library/Java/Ja vaVirtualMachines/1.6.0.jdk/Contents/Classes/classes.jar:/Sy stem/Library/Frameworks/JavaVM.framework/Frameworks/JavaRunt imeSupport.framework/Resources/Java/JavaRuntimeSupport.jar:/ System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/C lasses/ui.jar:/System/Library/Java/JavaVirtualMachines/1.6.0 .jdk/Contents/Classes/laf.jar:/System/Library/Java/JavaVirtu alMachines/1.6.0.jdk/Contents/Classes/sunrsasign.jar:/System /Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Classes /jsse.jar:/System/Library/Java/JavaVirtualMachines/1.6.0.jdk /Contents/Classes/jce.jar:/System/Library/Java/JavaVirtualMa chines/1.6.0.jdk/Contents/Classes/charsets.jar
sun.boot.library.path=/System/Library/Java/JavaVirtualMachin es/1.6.0.jdk/Contents/Libraries
sun.cpu.endian=little
sun.cpu.isalist=
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=MacRoman
sun.management.compiler=HotSpot 64-Bit Server Compiler
sun.os.patch.level=unknown
user.country=US
user.dir=/Applications/eclipse/Eclipse.app/Contents/MacOS
user.home=/Users/dbecker
user.language=en
user.name=dbecker
user.timezone=America/Los_Angeles
*** Features:
org.eclipse.cvs (1.2.0.v20100427-7B77FKt90GE5h0SBT5FV9A01911) "Eclipse CVS Client"
org.eclipse.datatools.common.doc.user (1.8.1.v20100618-26-311A16321A3557) "Data Tools Platform User Documentation"
org.eclipse.datatools.connectivity.doc.user (1.8.1.v20100618-37D-7733L3D753L7BBF) "Data Tools Platform Connectivity User Documentation"
org.eclipse.datatools.connectivity.feature (1.8.1.v20100618-7C7b8hEt1ZvtiLkdlO7BVoL_wm6) "Data Tools Platform Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.core.feature (1.8.1.v20100618-7B7C79CcNBGKBgIZCSNS) "DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature (1.8.1.v20100618-4107w3121151A1A53) "DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.feature (1.8.1.v20100618-7H7C7ACcNBHBBkHeGSMd) "DTP Open Data Access"
org.eclipse.datatools.doc.user (1.8.1.v20100618-47C08w95ENAK6AFDFK7) "Data Tool Platform User Documentation"
org.eclipse.datatools.enablement.apache.derby.feature (1.8.1.v20100618-77778eBmKDNOMgJvJ8Of7QBR) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.feature (1.8.1.v20100618-7J8x7FBWwUL6z-2z-fcrYC2s55KI) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature (1.8.1.v20100618-67C1AqGBJVKbHlH1GU7QBR) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ibm.feature (1.8.1.v20100618-7F47SFC7sRbrSZope9vW) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ingres.feature (1.8.1.v20100618-540AkF78Y7VCOCQDB) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.jdbc.feature (1.8.1.v20100618-4-29oB56N5N7L6PAQ) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.jdt.feature (1.8.1.v20100618-2-07w31211518181A) "Data Tools Platform Connectivity JDT Extension Plug-in"
org.eclipse.datatools.enablement.msft.feature (1.8.1.v20100618-542AkF79P7QCP9SDB) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.mysql.feature (1.8.1.v20100618-546AkF78Y7R9PAX77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.oda.designer.feature (1.8.1.v20100618-3328s73533G4A5B63) "Eclipse Data Tools Platform XML ODA Designer"
org.eclipse.datatools.enablement.oda.feature (1.8.1.v20100618-7A7T78DZRDKDDdFyFiKD) "Eclipse Data Tools Platform XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature (1.8.1.v20100618-548cAkF79P7UBMATEE) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.postgresql.feature (1.8.1.v20100618-542AkF77g7V9N9e77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sap.feature (1.8.1.v20100618-540AkF77g7V9N9e77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sqlite.feature (1.8.1.v20100618-541AkF79P7N8NAQ77) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sybase.feature (1.8.1.v20100618-7E45F9NiNWvOOXxPdVT) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.intro (1.8.1.v20100618-26-7w312116392911) "Eclipse Data Tools Platform Intro Plug-in"
org.eclipse.datatools.modelbase.feature (1.8.1.v20100618-77078CcNBGKBZI_FcRd) "Eclipse Data Tools Platform SQLModel Plug-in"
org.eclipse.datatools.sqldevtools.ddlgen.feature (1.8.1.v20100618-7A-2F7RZHLz-HvNlPz-Uk) "Eclipse Data Tools Platform FE UI Plug-in"
org.eclipse.datatools.sqldevtools.feature (1.8.1.v20100618-7N7y7AFDrhoZFIFUNhpFwckfaS-S) "Eclipse Data Tools Platform SQL Tools Common UI Plug-in"
org.eclipse.datatools.sqldevtools.parsers.feature (1.8.1.v20100618-622BgJ9CR9XFcEWLP) "Eclipse Data Tools Platform SQL Parser Plugin"
org.eclipse.datatools.sqltools.doc.user (1.8.1.v20100618-37D-7733L3D753L7BBF) "Data Tools Platform SQL Tools User Documentation"
org.eclipse.draw2d (3.6.1.v20100908-1100-4507w31211A2403131) "Graphical Editing Framework Draw2d"
org.eclipse.emf (2.6.1.v20100914-1218) "EMF - Eclipse Modeling Framework Runtime and Tools"
org.eclipse.emf.codegen (2.6.0.v20100914-1218) "EMF Code Generation"
org.eclipse.emf.codegen.ecore (2.6.1.v20100914-1218) "EMF Ecore Code Generator"
org.eclipse.emf.codegen.ecore.ui (2.6.0.v20100914-1218) "EMF Ecore Code Generator UI"
org.eclipse.emf.codegen.ui (2.6.0.v20100914-1218) "EMF Code Generation UI"
org.eclipse.emf.common (2.6.0.v20100914-1218) "EMF Common"
org.eclipse.emf.common.ui (2.6.0.v20100914-1218) "EMF Common UI"
org.eclipse.emf.converter (2.6.0.v20100914-1218) "EMF Model Converter"
org.eclipse.emf.databinding (1.2.0.v20100914-1218) "EMF Data Binding"
org.eclipse.emf.databinding.edit (1.2.0.v20100914-1218) "EMF Edit Data Binding"
org.eclipse.emf.ecore (2.6.1.v20100914-1218) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.6.0.v20100914-1218) "EMF Ecore Edit"
org.eclipse.emf.ecore.editor (2.6.0.v20100914-1218) "EMF Sample Ecore Editor"
org.eclipse.emf.edit (2.6.0.v20100914-1218) "EMF Edit"
org.eclipse.emf.edit.ui (2.6.0.v20100914-1218) "EMF Edit UI"
org.eclipse.emf.mapping (2.6.0.v20100914-1218) "EMF Mapping"
org.eclipse.emf.mapping.ecore (2.6.0.v20100914-1218) "EMF Ecore Mapping"
org.eclipse.emf.mapping.ecore.editor (2.6.0.v20100914-1218) "EMF Ecore Mapping Editor"
org.eclipse.emf.mapping.ui (2.6.0.v20100914-1218) "EMF Mapping UI"
org.eclipse.epp.mpc (1.0.1.v20100826-2143) "EPP Marketplace Client"
org.eclipse.epp.package.jee.feature (1.3.1.20100916-1202) "Java EE IDE"
org.eclipse.gef (3.6.1.v20100908-1100-777B181A3Bz-6B663E7974242) "Graphical Editing Framework GEF"
org.eclipse.help (1.2.0.v20100427-7e7jEQFEp4jsWcboLU9l93) "Help System Base"
org.eclipse.jdt (3.6.1.r361_v20100714-0800-7z8XFUSFLFlmgLc5z-Bvrt8-HVkH) "Eclipse Java Development Tools"
org.eclipse.jpt.eclipselink.feature (2.3.2.v201008242310-7778BjBgJ9E99_H_DFBA) "Dali Java Persistence Tools - EclipseLink Support"
org.eclipse.jpt.feature (2.3.2.v201008242310-7N7UF75FD3wTgbUpoff0aT) "Dali Java Persistence Tools"
org.eclipse.jst.common.fproj.enablement.jdt (3.2.2.v201008170019-377AB8s73533J5J759F) "Eclipse Faceted Project Framework JDT Enablement"
org.eclipse.jst.enterprise_ui.feature (3.2.2.v201008190400-7b7GHf2FSK2WBLQ2D-mrubYEOrRh) "Eclipse Java EE Developer Tools"
org.eclipse.jst.ws.axis2tools.feature (1.1.100.v201005241530-78-FF0DZRDKDDePSKwHj) "Axis2 Tools"
org.eclipse.jst.ws.cxf.feature (1.0.2.v201008232129-7H777DFAKlRiOX8lGdRoz0878J) "CXF Web Services Core"
org.eclipse.jst.ws.jaxws.feature (1.0.1.v201008232129-7E777CF8NcJSSK-UBTwXn) "JAX-WS Tools Core"
org.eclipse.mylyn_feature (3.4.2.v20100916-0100-e3x-7Z7f77FBBoPbPQeUoFeZXJ8) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (3.4.2.v20100916-0100-e3x-7D773BgJ9DH9fCc4CICE1) "Mylyn"
org.eclipse.mylyn.context_feature (3.4.2.v20100916-0100-e3x-777718s73533L3L135331) "Mylyn"
org.eclipse.mylyn.ide_feature (3.4.2.v20100916-0100-e3x-7G7J2BgJ9E99jDd49E994) "Mylyn"
org.eclipse.mylyn.java_feature (3.4.2.v20100916-0100-e3x-7D7F-AkF7B77V7c37B773) "Mylyn"
org.eclipse.mylyn.team_feature (3.4.2.v20100916-0100-e3x-4317w31211A1A012110) "Mylyn"
org.eclipse.mylyn.wikitext_feature (1.3.2.v20100916-0100-e3x-7F7e1FC7sReRSnX-DReRRD) "Mylyn"
org.eclipse.pde (3.6.1.r361_v20100727-7b7mFL-FET3dhESDgE5_bkJ) "PDE"
org.eclipse.platform (3.6.1.r361_v20100909-9gF78GrkFqw7GrsZnvz0JWNTeb6fue6896L) "Eclipse Platform"
org.eclipse.rcp (3.6.1.r361_v20100827-9OArFLdFjY-ThSQXmKvKz0_T) "Eclipse RCP"
org.eclipse.rse (3.2.1.v201008191400-7L78FA-8wqbPcNj4qa8R0eViy7vZ) "Remote System Explorer End-User Runtime"
org.eclipse.rse.core (3.2.1.v201008191400-7a7FFMWFC7sRd_Sga_dQoV) "RSE Core"
org.eclipse.rse.dstore (3.2.1.v201008191400-7L77FD8EVVFLXG4Oz0NjKF) "RSE DStore Services"
org.eclipse.rse.ftp (3.0.200.v201005221100-780Bg9oB56N5J9QBADD) "RSE FTP Service"
org.eclipse.rse.local (2.1.201.v201009071110-7B4F8PBgJ9Ai9dIaHNA9) "RSE Local Services"
org.eclipse.rse.ssh (3.0.100.v201005221100-7A2BhAkF77g7VEYDG7C) "RSE SSH Services"
org.eclipse.rse.telnet (2.2.100.v201005221100-7730AkF77g7UDXELEF) "RSE Telnet Service"
org.eclipse.rse.terminals (1.0.101.v201008191400-77-DH9uCFiO1U8MBKTDB3622) "RSE Terminals UI"
org.eclipse.rse.useractions (1.1.200.v201005221100-31A78s733L3D7H7933) "Remote System Explorer User Actions"
org.eclipse.team.svn (0.7.9.I20110124-1700) "Subversive SVN Team Provider (Incubation)"
org.eclipse.tm.terminal (3.0.201.v201008191400-4-8_7w3121192A2511) "Target Management Terminal Widget"
org.eclipse.tm.terminal.ssh (2.0.200.v201005271030-3-A77w312116382141) "Target Management Terminal SSH Connector"
org.eclipse.tm.terminal.telnet (2.0.200.v201005032000-3-8_7w311A1A271116) "Target Management Terminal Telnet Connector"
org.eclipse.tm.terminal.view (2.1.0.v201006030830-30-7w312117152351) "Target Management Terminal View"
org.eclipse.wst.common.fproj (3.2.2.v201008170019-377AB8s73533J5H335L) "Eclipse Faceted Project Framework"
org.eclipse.wst.jsdt.feature (1.2.2.v201008170101-7C78FGMF9JgLWLMUUEMtXc) "Eclipse JavaScript Development Tools"
org.eclipse.wst.web_ui.feature (3.2.2.v201008100100-7O7CFbKEMf84nUlEJyX7-SPQjhYZ) "Eclipse Web Developer Tools"
org.eclipse.wst.xml_ui.feature (3.2.2.v201008170029-7H7AFUQDxumQGOpBqffOY2f1qxDZ) "Eclipse XML Editors and Tools"
org.eclipse.wst.xml.xpath2.processor.feature (1.1.5.v201009091745-67K2BgJ9DIAXCbBWJO) "Eclipse XPath 2 Developers Tools"
org.eclipse.wst.xsl.feature (1.1.2.v201009091745-7S7WFAPFIpS-1-NbCE6tnacCXKP) "Eclipse XSL Developer Tools"
org.polarion.eclipse.team.svn.connector (2.2.2.I20110124-1700) "Subversive SVN Connectors"
org.polarion.eclipse.team.svn.connector.javahl16 (2.2.2.I20110124-1700) "Subversive SVN 1.6 JavaHL Connector"
*** Plug-in Registry:
ch.qos.logback.classic (0.9.19.v20100519-1505) "Logback Classic Module" [Resolved]
ch.qos.logback.core (0.9.19.v20100419-1216) "Logback Core Module" [Resolved]
ch.qos.logback.slf4j (0.9.19.v20100519-1910) "Logback Native SLF4J Logger Module" [Resolved]
com.google.appengine.eclipse.core (2.2.0.v201102111811) "Google App Engine Plugin" [Starting]
com.google.appengine.eclipse.sdkbundle.1.3.5 (1.3.5.v201006301309) "Google App Engine SDK" [Starting]
com.google.appengine.eclipse.sdkbundle.1.3.6 (1.3.6.v201008132057) "Google App Engine SDK" [Starting]
com.google.appengine.eclipse.sdkbundle.1.3.7 (1.3.7.v201008311427) "Google App Engine SDK" [Starting]
com.google.appengine.eclipse.sdkbundle.1.3.8 (1.3.8.v201010161055) "Google App Engine SDK" [Starting]
com.google.appengine.eclipse.sdkbundle.1.4.0 (1.4.0.v201012021502) "Google App Engine SDK" [Starting]
com.google.appengine.eclipse.sdkbundle.1.4.2 (1.4.2.v201102111811) "Google App Engine SDK" [Starting]
com.google.gdt.eclipse.core (2.2.0.v201102111811) "Google Core Plugin" [Active]
com.google.gdt.eclipse.designer (2.2.0.r36x201102111505) "GWT Designer" [Active]
com.google.gdt.eclipse.designer.gpe (2.2.0.r36x201102111547) "GWT Designer GPE Support" [Starting]
com.google.gdt.eclipse.designer.hosted (2.2.0.r36x201102111446) "GWT Designer Hosted Support" [Starting]
com.google.gdt.eclipse.designer.hosted.1_6 (2.2.0.r36x201102111446) "GWT Designer Hosted Support 1.6" [Starting]
com.google.gdt.eclipse.designer.hosted.1_6.mac (2.2.0.r36x201102111446) "GWT Designer Support Safari Support 1.6" [Starting]
com.google.gdt.eclipse.designer.hosted.1_6.super (2.2.0.r36x201102111446) "GWT Designer Super Support 1.6" [Starting]
com.google.gdt.eclipse.designer.hosted.2_0 (2.2.0.r36x201102111446) "GWT Designer Hosted Support 2.0" [Starting]
com.google.gdt.eclipse.designer.hosted.2_0.super (2.2.0.r36x201102111446) "GWT Designer Super Support 2.0" [Starting]
com.google.gdt.eclipse.designer.hosted.2_0.webkit (2.2.0.r36x201102111446) "GWT Designer WebKit Support 2.0" [Starting]
com.google.gdt.eclipse.designer.hosted.2_2 (2.2.0.r36x201102111446) "GWT Designer Hosted Support 2.2" [Starting]
com.google.gdt.eclipse.designer.hosted.2_2.webkit (2.2.0.r36x201102111446) "GWT Designer WebKit Support 2.2" [Starting]
com.google.gdt.eclipse.designer.hosted.lib (2.2.0.r36x201102111446) "GWT Designer Hosted Libraries" [Starting]
com.google.gdt.eclipse.designer.UiBinder (2.2.0.r36x201102111505) "GWT Designer UiBinder Support" [Active]
com.google.gdt.eclipse.maven (2.2.0.v201102111811) "GDT Maven Integration Plugin" [Starting]
com.google.gdt.eclipse.platform (2.2.0.v201102111811) "Google Eclipse Platform Plugin" [Starting]
com.google.gdt.eclipse.platform.e36 (2.2.0.v201102111811) "Google Eclipse 3.6 Platform Plugin" [Active]
com.google.gdt.eclipse.platform.shared (2.2.0.v201102111811) "Google Eclipse Shared Platform Plugin" [Active]
com.google.gdt.eclipse.suite (2.2.0.v201102111811) "Google Suite Plugin" [Starting]
com.google.gwt.eclipse.core (2.2.0.v201102111811) "Google Web Toolkit Plugin" [Active]
com.google.gwt.eclipse.oophm (2.2.0.v201102111811) "Google OOPHM Plugin" [Starting]
com.google.gwt.eclipse.sdkbundle.2.0.4 (2.0.4.v201006301309) "Google Web Toolkit SDK" [Starting]
com.google.gwt.eclipse.sdkbundle.2.1.0 (2.1.0.v201010280102) "Google Web Toolkit SDK" [Starting]
com.google.gwt.eclipse.sdkbundle.2.1.1 (2.1.1.v201012170127) "Google Web Toolkit SDK" [Starting]
com.google.gwt.eclipse.sdkbundle.2.2.0 (2.2.0.v201102111811) "Google Web Toolkit SDK" [Starting]
com.ibm.icu (4.2.1.v20100412) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.41.v200903070017) "JSch" [Resolved]
java_cup.runtime (0.10.0.v201005080400) "Java Cup" [Resolved]
javax.activation (1.1.0.v201005080500) "Apache Geronimo Activation Plug-in" [Resolved]
javax.jws (2.0.0.v201005080400) "Web Services Metadata" [Resolved]
javax.mail (1.4.0.v201005080615) "Javax Mail Plug-in" [Resolved]
javax.servlet (2.5.0.v200910301333) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle" [Resolved]
javax.wsdl (1.5.1.v201005080630) "WSDL4J" [Resolved]
javax.wsdl (1.6.2.v201005080631) "WSDL4J" [Resolved]
javax.xml (1.3.4.v201005080400) "JAXP XML" [Resolved]
javax.xml.bind (2.0.0.v20080604-1500) "JAXB" [Resolved]
javax.xml.bind (2.1.9.v201005080401) "XML Binding for Java" [Resolved]
javax.xml.rpc (1.1.0.v201005080400) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v201005080501) "SAAJ" [Resolved]
javax.xml.stream (1.0.1.v201004272200) "Java XML Streaming API" [Resolved]
javax.xml.ws (2.1.0.v200902101523) "Java API for XML Web Services (JAX-WS)" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v201004271650) "SourceForge LPG" [Resolved]
org.apache.ant (1.7.1.v20100518-1145) "Apache Ant" [Resolved]
org.apache.axis (1.4.0.v201005080400) "Apache Web Services" [Resolved]
org.apache.bcel (5.2.0.v201005080400) "Apache BCEL" [Resolved]
org.apache.commons.codec (1.3.0.v20100106-1700) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.codec (1.3.0.v20100518-1140) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.collections (3.2.0.v201005080500) "Apache Commons Collections" [Resolved]
org.apache.commons.discovery (0.2.0.v201004190315) "Jakarta-Commons Discovery" [Resolved]
org.apache.commons.el (1.0.0.v201004212143) "Apache Commons JSP 2.0 Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v20080605-1935) "Apache Commons Httpclient" [Resolved]
org.apache.commons.httpclient (3.1.0.v201005080502) "Apache Commons Httpclient" [Resolved]
org.apache.commons.lang (2.1.0.v201005080500) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.lang (2.3.0.v201005080501) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.logging (1.0.4.v200904062259) "Apache Commons Logging Plug-in" [Resolved]
org.apache.commons.logging (1.0.4.v201005080501) "Apache Commons Logging Plug-in" [Resolved]
org.apache.commons.net (2.0.0.v200905272248) "Apache Commons Net" [Resolved]
org.apache.jasper (5.5.17.v201004212143) "Apache Jasper 2 Plug-in" [Resolved]
org.apache.log4j (1.2.15.v201005080500) "Apache Jakarta log4j Plug-in" [Resolved]
org.apache.lucene (1.9.1.v20100518-1140) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20100518-1140) "Apache Lucene Analysis" [Resolved]
org.apache.oro (2.0.8.v201005080400) "Apache Jakarta ORO" [Resolved]
org.apache.velocity (1.5.0.v200905192330) "Apache Velocity Plug-in" [Resolved]
org.apache.ws.commons.util (1.0.0.v20100518-1135) "WS Commons Util Plug-in" [Resolved]
org.apache.wsil4j (1.0.0.v200901211807) "WSIL4J" [Resolved]
org.apache.xalan (2.7.1.v201005080400) "Xalan-Java" [Resolved]
org.apache.xerces (2.9.0.v201005080400) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v201005080400) "Apache XmlResolver" [Resolved]
org.apache.xml.serializer (2.7.1.v201005080400) "Apache XML Commons Serializer" [Resolved]
org.apache.xmlrpc (3.0.0.v20100427-1100) "Apache XML-RPC Plug-in" [Resolved]
org.eclipse.ant.core (3.2.200.v20100427) "Ant Build Tool Core" [Starting]
org.eclipse.ant.launching (1.0.0.v20100427) "Ant Launching Support" [Starting]
org.eclipse.ant.ui (3.5.0.v20100427) "Ant UI" [Starting]
org.eclipse.compare (3.5.100.I20100526-0800) "Compare Support" [Active]
org.eclipse.compare.core (3.5.100.I20100526-0800) "Core Compare Support" [Starting]
org.eclipse.core.boot (3.1.200.v20100505) "Core Boot" [Starting]
org.eclipse.core.commands (3.6.0.I20100512-1500) "Commands" [Resolved]
org.eclipse.core.contenttype (3.4.100.v20100505-1235) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.3.100.I20100601-0800) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.2.100.I20100601-0800) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.3.0.I20100601-0800) "JFace Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.3.0.I20100601-0800) "JFace Data Binding" [Starting]
org.eclipse.core.expressions (3.4.200.v20100505) "Expression Language" [Active]
org.eclipse.core.externaltools (1.0.1.v20100831_r361) "External Tools Headless Support" [Starting]
org.eclipse.core.filebuffers (3.5.100.v20100520-0800) "File Buffers" [Active]
org.eclipse.core.filesystem (1.3.1.R36x_v20100727-0745) "Core File Systems" [Active]
org.eclipse.core.filesystem.macosx (1.3.0.v20100505) "Core File System for Macintosh" [Resolved]
org.eclipse.core.jobs (3.5.1.R36x_v20100824) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.2.100.I20100511-0800) "Internet Connection Management" [Active]
org.eclipse.core.resources (3.6.0.R36x_v20100825-0600) "Core Resource Management" [Active]
org.eclipse.core.runtime (3.6.0.v20100505) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.100.v20100505) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.200.v20100517) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.3.0.v20100520) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.400.v20100505) "Core Variables" [Starting]
org.eclipse.cvs (1.0.500.v201009090800) "Eclipse CVS Client" [Starting]
org.eclipse.datatools.common.doc.user (1.7.0.20090521092446) "Data Tools Platform User Documentation" [Starting]
org.eclipse.datatools.connectivity (1.2.1.v201007142147) "Data Tools Platform Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby (1.0.100.v200906020900) "Eclipse Data Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby.dbdefinition (1.0.2.v200906161815) "Eclipse Data Tools Platform Apache Derby Database Definition" [Starting]
org.eclipse.datatools.connectivity.apache.derby.ui (1.0.3.v201007080903) "Eclipse Data Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.console.profile (1.0.0.v200906020553) "DTP Connection Profiles Storage File Editor Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.1.v200908130547) "Eclipse Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.v201004070709) "Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC (1.0.1.v200906161815) "Eclipse Data Tools Platform DBDefinition Generic JDBC Plug-in" [Starting]
org.eclipse.datatools.connectivity.doc.user (1.7.0.20090521092446) "Data Tools Platform Connectivity User Documentation" [Starting]
org.eclipse.datatools.connectivity.doc.user.contexts (1.7.0.20090521092446) "Data Tools Platform Connectivity User Documentation for context-sensitive help" [Starting]
org.eclipse.datatools.connectivity.oda (3.3.1.v201008030730) "DTP Open Data Access" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.2.3.v201005281018) "DTP ODA Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.3.1.v201008171206) "DTP ODA Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.2.4.v201007150318) "DTP ODA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.1.1.v201001131420) "Eclipse Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.1.1.v201001131420) "Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.2.4.v201007150318) "DTP ODA Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.2.1.v201004090942) "DTP ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.2.1.v201008120113) "Eclipse Data Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.2.0.v201002281800) "Eclipse Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.1.100.v200910270503) "Eclipse Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.2.0.v201006250003) "Data Tools Platform Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.1.4.v201004270430) "Eclipse Data Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.doc.user (1.7.0.20090521092446) "Data Tool Platform User Documentation" [Starting]
org.eclipse.datatools.enablement.finfo (1.5.1.v200906161800) "Eclipse Data Tools Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.v200906020900) "Eclipse Data Tools Platform HSQLDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform HSQLDB Database Definition Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform HSQLDB UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries (1.0.2.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n (1.0.3.v200906161800) "DB2 UDB iSeries Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.ui (1.0.1.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB UI iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw (1.0.2.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition (1.0.4.v201005211215) "Eclipse Data Tools Platform DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.ui (1.0.2.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB LUW UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries (1.0.2.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n (1.0.4.v201005211230) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.ui (1.0.1.v201005211230) "Eclipse Data Tools Platform IBM DB2 UDB zSeries UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix (1.0.1.v201005211230) "Eclipse Data Tools Platform Informix Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition (1.0.4.v201005211230) "Eclipse Data Tools Platform Informix Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.ui (1.0.2.v201005211230) "Eclipse Data Tools Platform Informix UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform IBM UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres (1.0.0.v200906111150) "Ingres DTP Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres.dbdefinition (1.0.0.v200906161800) "Ingres DTP Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres.ui (1.0.0.v201006242214) "Ingres DTP UI Plug-in" [Starting]
org.eclipse.datatools.enablement.jdt.classpath (1.0.1.v201004070709) "Data Tools Platform Connectivity JDT Extension Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver (1.0.1.v201001180222) "Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition (1.0.0.v201004211630) "Eclipse Data Tools Platform SQL Server Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.ui (1.0.1.v200908130512) "Eclipse Data Tools Platform Microsoft SQL Server UI Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.2.v201002041100) "Eclipse Data Tools Platform MySQL Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.4.v200906161800) "Eclipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform MySQL UI Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.2.2.v201001131420) "Eclipse Data Tools Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.2.2.v201007141330) "Eclipse Data Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.2.1.v201001151620) "Eclipse Data Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.2.1.v201006031500) "Eclipse Data Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle (1.0.0.v200908130544) "Eclipse Data Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.101.v201004211630) "Eclipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.ui (1.0.2.v201005051303) "Eclipse Data Tools Platform Oracle UI Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql (1.0.1.v200906020900) "PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition (1.0.1.v200906161800) "PostgreSQL DB Definition" [Starting]
org.eclipse.datatools.enablement.postgresql.ui (1.0.0.v200906020900) "PostgreSQL Connection Profile and Driver Template UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb (1.0.0.v200906020900) "Eclipse Data Tools Platform MaxDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform MaxDB Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform MaxDB UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite (1.0.0.v201002041100) "Eclipse Data Tools Platform SQLite Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite.dbdefinition (1.0.1.v201002041100) "Eclipse Data Tools Platform SQLite Database Definition Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform SQLite UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.v200906020900) "High-level Sybase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.1.v200906020900) "Sybase ASA Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform Sybase ASA Database Definition" [Starting]
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.v200906020900) "Sybase ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.asa.schemaobjectedit or.examples (2.5.0.200810071) "Sybase ASA Schema Object Editor" [Starting]
org.eclipse.datatools.enablement.sybase.asa.ui (1.0.1.v200906111150) "Sybase ASA Connection Profile UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase (1.0.1.v200906020900) "JDBC/Sybase ASE Connection Profile Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform Sybase ASE Database Definition" [Starting]
org.eclipse.datatools.enablement.sybase.ase.models (1.0.1.v200906020900) "Sybase ASE Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.ui (1.0.1.v200906020900) "ASE Enablement UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.models (1.0.0.v200906020900) "Sybase Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ui (1.0.0.v200906090458) "Sybase UI Plug-in" [Starting]
org.eclipse.datatools.help (1.5.0.v200906020553) "Data Tools Platform Help Utilities" [Resolved]
org.eclipse.datatools.intro (1.7.0.v201005281800) "Eclipse Data Tools Platform Intro Plug-in" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.2.v201002130228) "Eclipse Data Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.v201002161452) "Eclipse Data Tools Platform Derby Model Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql (1.0.4.v201002250945) "Eclipse Data Tools Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.1.v201002161452) "Eclipse Data Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.1.1.v201008100700) "Eclipse Data Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.query.edit (1.0.0.v200906022249) "SQL Query Edit Support Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.1.v201004291415) "Eclipse Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.1.1.v200907031118) "DTP ODA Context-
[Updated on: Tue, 08 March 2011 21:49] Report message to a moderator
Current Time: Fri Apr 26 09:08:07 GMT 2024
Powered by FUDForum. Page generated in 0.03683 seconds
