Re: Target platform materialization [message #658404 is a reply to message #658397] |
Tue, 08 March 2011 11:21 |
On 2011-03-08 12:14, Christian K. wrote:
> I'm trying to materialize a target platform during a buckminster build using p2 from the official Eclipse update sites.
> For that I created the needed files: .mspec, .rmap and .cquery
> Basically there are two issues:
> - platform specific fragments are not fetched into the target platform, e.g. swt win32 bundles, this leads to compile
> errors later on
You should try adding:
target.os=*
target.ws=*
target.arch=*
to your CQUERY. Or alternatively pass them in as system properties.
> - features are not fetched into the target platform, the features in the target paltform are referenced as requirements
> of the feature that I want to build with buckminster, this also leads to errors later on the build
Feature requirements are not generated as Buckminster dependencies. Only feature includes. So either try that, or
complement your feature with a buckminster.cspex where the requirements are listed as dependencies.
> Things I already tried are:
> - Setting an explicit target platform location: setpreference targetPlatformPath=${user.dir}/tp
That is always a good idea since it keeps your TP separate from your runtime.
> - Various settings for the target.* properties
> Are there any known issues with the p2 materializer? Is this the intended behaviour of the p2 materializer?
Try what I just described and see if that solves your problems. No software is perfect but there are no known issues in
the p2 materializer that would give the symptoms that you describe here.
HTH,
- thomas
Re: Target platform materialization [message #658417 is a reply to message #658397] |
Tue, 08 March 2011 13:04 |
Christian K. Messages: 15 Registered: March 2010 |
I tried creating a buckminster.cspex for my feature that is referencing the target platform features. This results in errors that the feature/component cannot be resolved anymore at all. Further investigation shows that there are problems with parsing the .cspex file:
Problem during meta-data refresh: org.eclipse.buckminster.sax.UnrecognizedElementException: Unrecognized element <dependency> encountered in tag <alterDependencies>: file:///.../core/features/org.ecli pse.sphinx.sdk-feature/buckminster.cspex at line: 22 column: 76
org.eclipse.core.runtime.CoreException: org.eclipse.buckminster.sax.UnrecognizedElementException: Unrecognized element <dependency> encountered in tag <alterDependencies>: file:///.../core/features/org.ecli pse.sphinx.sdk-feature/buckminster.cspex at line: 22 column: 76
at org.eclipse.buckminster.runtime.BuckminsterException.fromMes sage(BuckminsterException.java:57)
at org.eclipse.buckminster.runtime.BuckminsterException.wrap(Bu ckminsterException.java:123)
at org.eclipse.buckminster.core.parser.AbstractParser.parseInpu t(AbstractParser.java:240)
at org.eclipse.buckminster.core.cspecext.parser.AlterCSpecParse r.parse(AlterCSpecParser.java:42)
at org.eclipse.buckminster.core.cspecext.parser.AlterCSpecParse r.parse(AlterCSpecParser.java:1)
at org.eclipse.buckminster.core.cspec.AbstractResolutionBuilder $1.consumeStream(AbstractResolutionBuilder.java:116)
at org.eclipse.buckminster.core.cspec.AbstractResolutionBuilder $1.consumeStream(AbstractResolutionBuilder.java:1)
at org.eclipse.buckminster.core.reader.URLCatalogReader.innerRe adFile(URLCatalogReader.java:188)
at org.eclipse.buckminster.core.reader.AbstractCatalogReader.re adFile(AbstractCatalogReader.java:161)
at org.eclipse.buckminster.core.cspec.AbstractResolutionBuilder .applyExtensions(AbstractResolutionBuilder.java:108)
at org.eclipse.buckminster.pde.cspecgen.PDEBuilder.build(PDEBui lder.java:73)
at org.eclipse.buckminster.core.ctype.AbstractComponentType.get Resolution(AbstractComponentType.java:316)
at org.eclipse.buckminster.core.ctype.AbstractComponentType.get Resolution(AbstractComponentType.java:201)
at org.eclipse.buckminster.core.resolver.LocalResolver.fromPath (LocalResolver.java:164)
at org.eclipse.buckminster.core.resolver.LocalResolver.fromPath (LocalResolver.java:185)
at org.eclipse.buckminster.core.metadata.MetadataSynchronizer.r efreshProject(MetadataSynchronizer.java:295)
at org.eclipse.buckminster.core.metadata.MetadataSynchronizer.w orkspaceCatchUp(MetadataSynchronizer.java:394)
at org.eclipse.buckminster.core.metadata.MetadataSynchronizer$W orkspaceCatchUpJob.run(MetadataSynchronizer.java:185)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: org.eclipse.buckminster.sax.UnrecognizedElementException: Unrecognized element <dependency> encountered in tag <alterDependencies>
at org.eclipse.buckminster.sax.ChildHandler.createHandler(Child Handler.java:56)
at org.eclipse.buckminster.core.cspecext.parser.AlterDependenci esHandler.createHandler(AlterDependenciesHandler.java:50)
at org.eclipse.buckminster.sax.ChildHandler.startElement(ChildH andler.java:154)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidato r.emptyElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown Source)
at org.eclipse.buckminster.core.parser.AbstractParser.parseInpu t(AbstractParser.java:237)
... 16 more
It seems like that the XSD wants a "dependency" element inside the "alterDepencies" element but the parser expects an "component" element. At least that's what it looks like in the code at:
There the element name is compared against ComponentRequestHandler.TAG=ComponentRequest.TAG="component "
There is also another question: Will the platform specific bundles be resolved once the feature references are fixed?
[Updated on: Tue, 08 March 2011 13:05] Report message to a moderator
Re: Target platform materialization [message #658424 is a reply to message #658417] |
Tue, 08 March 2011 13:36 |
You're not supposed to alter any existent dependency. Just use a normal <dependencies> element to add more dependencies
and not <alterDependencies>.
- thomas
> file:///M:/CK_Projekte/artop-sphinx-2/core/features/org.ecli pse.sphinx.sdk-feature/buckminster.cspex at line: 22 column: 76
> ... 16 more
Re: Target platform materialization [message #658425 is a reply to message #658420] |
Tue, 08 March 2011 13:38 |
On 2011-03-08 14:19, Christian K. wrote:
> BTW, thanks for your quick reply. I am currently so deep in these releng things that I forgot to mention that.
> Another thing that I'm wondering about is what will happen once the feature depencies are fixed. Will this result in the
> situation that these features will also show up in the resulting update site?
No. If you want them to show up, you need to include the dependencies.
> To me it looks like that the cspec is not
> able to distinguish between requirements and inclusions as it is possible inside a feature.xml. This would be my
> preferred method to control what wil be part of the resulting update site.
Another way is to have a specific feature that actually describes the site. Such a feature will normally not be part of
the site in itself.
- thomas
Re: Target platform materialization [message #658698 is a reply to message #658397] |
Wed, 09 March 2011 13:59 |
One more note regarding my previous problem:
When you want to build against a Galileo target platform, which is probably pretty rare these days it might also be necessary to reference an older Orbit repository:
http://download.eclipse.org/tools/orbit/downloads/drops/R200 90529135407/updateSite
(Make sure you are getting the different suffix /updateSite instead of /repository)
Related to the field target platform materialization, after I was actually able to accomplish that, I now have another question:
For us target platform download/materialization/resolution is quite "expensive" and the target platform rarely changes. Therefore it might make sense to just re-use a target platform that has been created earlier and that still exists on the local file system. Is there a best practice how this can be done?
I already tried to setup resolutionFilter's on the respective providers in the rmap, but this isn't really working. This results in "Attempt to use an unresolved node" errors. I've tried this in combination with "setpreference targetPlatformPath=${user.dir}/tp".
[Updated on: Wed, 09 March 2011 14:04] Report message to a moderator
Re: Target platform materialization [message #659730 is a reply to message #659729] |
Tue, 15 March 2011 11:35 |
My guess would be that you have some kind of circular dependencies. Buckminster should normally trap that though, so I'm
not sure. But it's something to check for.
- thomas
On 2011-03-15 12:29, Christian K. wrote:
> We now setup a job on the Eclipse Hudson instance for our build. Unfortunately when running the build on the Eclipse
> Hudson instance an StackOverflowError occurs during import. See
> https://hudson.eclipse.org/hudson/job/buckminster-sphinx-0.7 -helios/28/console for details.
> I cannot reproduce the StackOverflowError when running the build on my local machine.
> Also I'm not able to show more details about the StackOverflowError. I already tried using --loglevel debug and
> --displaystacktraces but neither the console output nor the workspace log will show a stacktrace.
Re: Target platform materialization [message #660076 is a reply to message #660062] |
Wed, 16 March 2011 18:04 |
Looks like you have a property expansion construct (i.e. a ${some.property}) that when expanded somehow expands to a
string containing the same property expansion.
- thomas
On 2011-03-16 18:38, Christian K. wrote:
> I was just able to obtain a stack trace of the StackOverflowError by doing a remote debug of the build:
> [java] java.lang.StackOverflowError
> [java] at java.util.HashMap.get(HashMap.java:300)
> [java] at org.eclipse.buckminster.core.helpers.MapUnion.get(MapUnion.j ava:211)
> [java] at org.eclipse.buckminster.core.helpers.MapUnion.get(MapUnion.j ava:201)
> [java] at org.eclipse.buckminster.core.common.model.ExpandingPropertie s.get(ExpandingProperties.java:304)
> [java] at org.eclipse.buckminster.core.helpers.UnmodifiableMapUnion.ge t(UnmodifiableMapUnion.java:175)
> [java] at org.eclipse.buckminster.core.helpers.UnmodifiableMapUnion.ge t(UnmodifiableMapUnion.java:161)
> [java] at org.eclipse.buckminster.core.common.model.ExpandingPropertie s.checkedExpand(ExpandingProperties.java:144)
> [java] at org.eclipse.buckminster.core.common.model.ExpandingPropertie s.expand(ExpandingProperties.java:91)
> [java] at org.eclipse.buckminster.core.common.model.Constant.checkedGe tValue(Constant.java:70)
> [java] at org.eclipse.buckminster.core.common.model.ExpandingPropertie s.get(ExpandingProperties.java:305)
> Now it will be interesting to further investigate what is causing this.
FUDForum. Page generated in 0.05989 seconds
