Re: Trouble starting 32-bit Eclipse Classic 3.6.2 on 64-bit Linux [message #698212 is a reply to message #698211] |
Tue, 19 July 2011 02:42 |
Peter Shannon Messages: 3 Registered: July 2011 |
No good either. Helios 32 bit & java 32 bit, result: same error.
/home/shannon/lib/helios> eclipse -vm /home/shannon/lib/jdk1.6.0_26/bin/java
JVM terminated. Exit code=13
-Xms128m
-Xmx512m
-Dorg.eclipse.equinox.p2.reconciler.dropins.directory=/usr/share/eclipse/dropins
-XX:CompileCommand=exclude,org/eclipse/core/internal/dtree/DataTreeNode,forwardDeltaWith
-XX:CompileCommand=exclude,org/eclipse/jdt/internal/compiler/lookup/ParameterizedMethodBinding,<init>
-XX:CompileCommand=exclude,org/eclipse/cdt/internal/core/dom/parser/cpp/semantics/CPPTemplates,instantiateTemplate
-XX:CompileCommand=exclude,org/eclipse/cdt/internal/core/pdom/dom/cpp/PDOMCPPLinkage,addBinding
-XX:CompileCommand=exclude,org/python/pydev/editor/codecompletion/revisited/PythonPathHelper,isValidSourceFile
-XX:CompileCommand=exclude,org/python/pydev/ui/filetypes/FileTypesPreferencesPage,getDottedValidSourceFiles
-XX:MaxPermSize=256m
-jar /usr/lib64/eclipse//plugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar
-os linux
-ws gtk
-arch x86_64
-showsplash
-launcher /usr/lib64/eclipse/eclipse
-name Eclipse
--launcher.library /usr/lib64/eclipse//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.1.R36x_v20100810/eclipse_1309.so
-startup /usr/lib64/eclipse//plugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar
-exitdata d8004
-vmargs
-Xms128m
-Xmx512m
Re: Trouble starting 32-bit Eclipse Classic 3.6.2 on 64-bit Linux [message #703551 is a reply to message #703370] |
Wed, 27 July 2011 16:47 |
On 27-Jul-11 07:55, David I wrote:
> For reference, I'm seeing the same problem:
> /usr/java/latest/bin/java
> -Dosgi.requiredJavaVersion=1.5
> -Xms40m
> -Xmx512m
> -jar
> /home/isheedm/bin/eclipse//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
> -os linux
> -ws gtk
> -arch x86
> -showsplash
> -launcher /home/isheedm/bin/eclipse/eclipse
> -name Eclipse
> --launcher.library
> /home/isheedm/bin/eclipse//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.100.v20110505/eclipse_1407.so
> -startup
> --launcher.overrideVmargs
> -exitdata 1180010
> -product org.eclipse.epp.package.jee.product
> -vm /usr/java/latest/bin/java
> -vmargs
> -Xms40m
> -Xmx512m
> -jar
>> /usr/java/latest/bin/java -version
> java version "1.6.0_25"
> Java(TM) SE Runtime Environment (build 1.6.0_25-b06)
> Java HotSpot(TM) 64-Bit Server VM (build 20.0-b11, mixed mode)
> Is there a problem running 32 bit Eclipse with a 64 bit Java?
> David
Yup.
FUDForum. Page generated in 0.11874 seconds
