Re: work with bugzilla 4 [message #658178 is a reply to message #658083] |
Mon, 07 March 2011 09:46 |
On 03/06/2011 05:57 AM, Steffen Pingel wrote:
> Hi Lorenzo,
> that is the expected behavior. Synchronize only updates your Task List with
> changes from Bugzilla but does not actually submit outgoing changes. If you
> want to submit your changes back to the repository you have to do that from
> the Task Editor. The terminology can be a bit confusing and we are still
> discussing to change it to make that more obvious.
yes, indeed it's a little bit confusing ;)
> It sounds like Mylyn is working for you but please feel free to file a bug
> in case you run into any problems with Bugzilla 4.0.
OK, then it really looks it runs fine.
Thanks!
Lore
> Steffen
> Lorenzo Bettini wrote:
>> Hi Steffen
>> I'm using the version of mylyn which comes from the updatesite
>> org.eclipse.mylyn.bugzilla.ide_3.4.1.v20110131-0100-e3x.jar
>> org.eclipse.mylyn.bugzilla.core_3.4.2.v20100902-0100-e3x.jar
>> in the meantime I've been using mylyn with my bugzilla installation for
>> a few days; actually it works, meaning that I can file new bugs (after
>> adding the status NEW to my bugzilla installation) and I can "submit"
>> after I changed something in the rich editor; but synchronize does not
>> work for updating something to bugzilla (as I said, I have to press
>> "submit"); I can still get updates from bugzilla with synchronize...
>> probably this is related to the current version of mylyn and bugzilla?
>> Or did I get wrong the way that synchronize and submit should work?
>> I'll also try to get a more recent version of mylyn using the update
>> site you said.
>> cheers
>> Lorenzo
>> On 03/05/2011 04:53 AM, Steffen Pingel wrote:
>>> Which version of Mylyn are you running? Bugzilla 4 pre-dates the latest
>>> stable release but you can use the latest weekly build which has Bugzilla
>>> 4 support: http://eclipse.org/mylyn/new/weekly.php
>>> Please file a bug including details about the error message if updating
>>> does not resolve the problem.
>>> Steffen
>>>> Hi
>>>> I've just installed bugzilla 4 on my machine;
>>>> I can access it with mylyn (I can see tasks and perform query); however,
>>>> task synchronization does not work (I successfully logged into).
>>>> Do I have to configure bugzilla somehow? I didn't find information
>>>> about this...
>>>> thanks in advance
>>>> Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
FUDForum. Page generated in 0.02746 seconds
