Re: [Acceleo] eliminate white lines generated by template [message #657568 is a reply to message #657379] |
Thu, 03 March 2011 04:02  |
--------------010502050705090203060008
Content-Type: text/plain; charset=UTF-8; format=flowed
A template, if it returns the empty String, won't generate anything in
the output file. What you have here is (I assume) something like this :
[file (...)]
some text
[templateCallThatDoesNotGenerateAnything()/]
and some other text
[/file]
And you expect the output to be
some text
and some other text
whereas you get
some text
and some other text
This is normal, and expected. The line where you have a template call
ends with a carriage return, this carriage return _will_ be generated.
There is no way to prevent this from happening.
Laurent Goubet
Obeo
On 02/03/2011 16:58, olafo987 wrote:
> Hi
> There is some form of eliminate the white lines generated when one
> template returns the string ''?
> I tried with "trim()" but It does not work.
> in advance, thanks for your help
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyIj5PYmVvPC9hPg0KZW1haWw7 aW50ZXJuZXQ6
bGF1cmVudC5nb3ViZXRAb2Jlby5mcg0KdXJsOmh0dHA6Ly93d3cub2Jlby5m cg0KdmVyc2lv
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------010502050705090203060008--
FUDForum. Page generated in 0.11039 seconds
