Home » Modeling » EMF » [CDO] Resource.getContents().remove(Object) unnecessarily loads all elements from database
[CDO] Resource.getContents().remove(Object) unnecessarily loads all elements from database [message #656810] |
Mon, 28 February 2011 17:15 |
Gábor Nagy Messages: 9 Registered: July 2009 Location: Budapest, Hungary |
While trying to delete an item from a CDO resource, I found that the whole resource contents was loaded into memory. This is less than ideal for the 300.000> elements at hand...
Some debugging revealed the following:
1) remove(Object) on the resource contents calls indexOf(Object), which basically compares the to-be-removed element to all others in the list.
2) Once the element is removed from it's container, the reference is also unset in the other direction in InternalEOBjectImpl.eSetResource(). The EObject tries to remove itself again from it's container (however since it is no longer in that list, removal doesn't occur and we don't get into an endless loop).
3) In DelegatingEcoreEList.indexOf(Object) if the element is not found in the list, each element is resolved and compared again. If the item is really not in the list, the iteration stops only when the end of the list is reached.
4) Combine 2) and 3), and BAM, the whole resource is loaded.
I reckon if remove() is not called the second time, the whole loading will not occur for the above scenario. I haven't traced it, but I assume the same holds true for any one-to-many containment relationship that is also bidirectional, not just resource contents.
If the element never existed in the list in the first place, the proxy proxy loading can not be avoided. Or can it? I'm wondering if for resources proxy resolution is necessary at all for indexOf(Object). In order to get a reference to the object, it needs to be looked up. The only occasion I can think of when a lookup returns a proxy is if the element is not contained in any of the resources in the resource set (dangling URI somewhere), in which case indexOf() should just return -1.
Is this a bug to be filed?
Greg
Re: [CDO] Resource.getContents().remove(Object) unnecessarily loads all elements from database [message #656834 is a reply to message #656810] |
Mon, 28 February 2011 18:16 |
Hi Greg,
I've not yet heard about this issue, so, without further investigation, I can hardly know what's going on there. I wonder if, what you describe, is the normal EMF behaviour and is "just" not optimal in a lazy loading environment. Due to my EclipseCon preparations my time is a little limited until end of March, but a bugzilla makes perfect sense.
In the meantime you could try to regenerate your model with Resolve Proxies=false. CDO does not rely on EMF proxies.
Cheers
/Eike
http://www.esc-net.de
Am 28.02.2011 18:16, schrieb Gergely Nagy:
> Greg
Cheers
/Eike
Re: [CDO] Resource.getContents().remove(Object) unnecessarily loads all elements from database [message #656851 is a reply to message #656810] |
Mon, 28 February 2011 18:58 |
Ed Merks Messages: 33141 Registered: July 2009 |
Greg,
I'm trying to figure out if there are CDO-specific issues here or
something more general.
> the list.
Yes, though it uses == comparison, which is very fast, and of course you
could use remove(int) instead.
You mean the container or the resource? Is cross resource containment
involved?
You mean BasicEObjectImpl... Yes, removing from a resource requires the
object's pointer at the resource to be updated.
You mean from the resource? I.e., this **line.
Resource.Internal oldResource = eDirectResource();
if (oldResource != null)
** notifications =
((InternalEList<?>)oldResource.getContents()).basicRemove(this,
notifications);
Hmmm. I wonder if we need to check in the case that the new resource is
null...
Is that used by CDO for the resource's contents? In the standard
runtime's implementation, a resource's contents can't be proxies...
No.
I don't expect resources to ever contain proxies directly; the standard
runtime doesn't support.
> return -1.
> Greg
Ed Merks
Re: [CDO] Resource.getContents().remove(Object) unnecessarily loads all elements from database [message #656962 is a reply to message #656810] |
Tue, 01 March 2011 08:03 |
I've filed bug 338508: CDOResource.contents should not resolve proxies
https://bugs.eclipse.org/bugs/show_bug.cgi?id=338508
Cheers
/Eike
> Greg
Cheers
/Eike
Re: [CDO] Resource.getContents().remove(Object) unnecessarily loads all elements from database [message #656997 is a reply to message #656851] |
Tue, 01 March 2011 10:14 |
Ed,
Thanks for your reply.
Ed Merks wrote on Mon, 28 February 2011 13:58
>> the list.
1) Is not really the issue, that comparison is in fact sufficiently fast if no proxies need to be resovled. It was just the first observation I made while debugging, that I wanted to mention separately from 2) and 3), since both are affected by it.
I tried to use remove(int) directly, but I couldn't find a good way to get that index for an object at hand. I considered a DB query to a CDO lists table, but that won't work once the DB and the transaction get out of sync as the user changes things, e.g. for the second remove before a commit...
> involved?
In my case container == resource. I incorrectly presumed this may also be the case for 1->* containment relationships, thus the generic phrasing...
>** notifications =
>notifications);
Yes, that, and also in CDOOBjectImpl.eSetResource().
>null...
If the new resource is null we still have to remove it from the old resource, and that check seems to be in order.
Yes. I see Eike is already addressing this.
>No.
I have debugged it now, and indeed, for non-resource containment there is no second remove, emf inverseRemove never turns into a full remove.
However, ContentCDOList.inverseRemove() calls eObject.eSetResource, which should be eBasicSetContainer() according to the above. So then in 2) eSetResource is working correctly, but it should not be called.
> return -1.
Ok thanks, I wasn't sure about this.
I'll try out Eike's fix for never resolving proxies in CDO resources. What about ContentCDOList.inverseRemove()? Is there a bug as well?
Greg
Re: [CDO] Resource.getContents().remove(Object) unnecessarily loads all elements from database [message #657001 is a reply to message #656997] |
Tue, 01 March 2011 10:33 |
Am 01.03.2011 11:14, schrieb Gergely Nagy:
> Ed,
>> Yes, though it uses == comparison, which is very fast, and of course you could use remove(int) instead.
I don't suggest that a server round trip is a good solution here but please note that CDO's IQueryHandlers can now consider the client's dirty state on the server side. The OCLQueryHandler does that for example if the query has been created on a CDOTransaction.
>> You mean the container or the resource? Is cross resource containment involved?
>> You mean BasicEObjectImpl... Yes, removing from a resource requires the object's pointer at the resource to be updated.
>> ** notifications = ((InternalEList<?>)oldResource.getContents()).basicRemove(this, notifications);
>> Hmmm. I wonder if we need to check in the case that the new resource is null...
>> Is that used by CDO for the resource's contents? In the standard runtime's implementation, a resource's contents can't be proxies...
Yes, i've committed that fix for both CDOResource.contents and CDOResourceFolder.nodes.
>> No.
>> I don't expect resources to ever contain proxies directly; the standard runtime doesn't support.
> Greg
Cheers
/Eike
Re: [CDO] Resource.getContents().remove(Object) unnecessarily loads all elements from database [message #906782 is a reply to message #657001] |
Sun, 02 September 2012 14:39 |
András Péteri Messages: 22 Registered: January 2010 |
We've changed our code to use remove(int) in the meantime, but still seeing the same problem because of the previously discussed code segment in CDOObjectImpl.eSetResource, line 742:
// When setting the resource to null we assume that detach has already been called in the resource implementation
if (!isSameView && resource != null)
oldResource.detached(this);
The parallel class of EMF, BasicEObjectImpl has been changed in the version shipping with Juno to the following:
if (oldResource != null && resource != null)
...which seems to be the realisation of the idea Ed was contemplating in his reply above ("I wonder if we need to check in the case that the new resource is null..."). eSetResource should only be called from inverseAdd/inverseRemove in the appropriate ContentsEList implementation (current javadoc only mentions inverseAdd), and in the latter case, there's no need to attempt removing the object in question from its old resource twice - the second remove operation is effectively a no-op, as the object is no longer a member of the list, but it results in mass loading of revisions, as all of the remaining members (which are kept as a partially populated list of CDOIDs in the EStore implementation) have to be loaded, converted into EObjects, and only then checked for reference equality.
My suggestion would be to update CDOObjectImpl in a similar way as it was done in BasicEObjectImpl; I'd love to post a patch for this, but am not sure where the "isSameView" checks would have to be placed, which complicates matters a bit in CDO's implementation.
Re: [CDO] Resource.getContents().remove(Object) unnecessarily loads all elements from database [message #911277 is a reply to message #906782] |
Tue, 11 September 2012 09:27 |
Am 02.09.2012 16:39, schrieb Andras Peteri:
Thanks for the offer. Looking at the code I thought the fix could be easy. I've filed this bug:
389231: Don't load all resource contents for remove(int)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=389231
And fixed it. Please cc yourself and tell whether it helps you.
Cheers
/Eike
Cheers
/Eike
Current Time: Fri Apr 26 01:19:57 GMT 2024
Powered by FUDForum. Page generated in 0.04125 seconds
