Home » Eclipse Projects » Eclipse Platform » Launcher finds Sun VM instead of IBM VM on Windows.
Launcher finds Sun VM instead of IBM VM on Windows. [message #656772] Mon, 28 February 2011 09:40 Go to next message
I have an IBM VM as my system VM (the IBM java.exe is in \windows\system32
When I start Memory Analyzer it uses the Sun VM instead. I think this is because org.eclipse.equinox.executable/library/win32/eclipseWin.c doesn't find a JRE/SDK directory for the java.exe, so goes straight to using registry keys to find the VM.
I know I could use -vm to chose a VM, but I think the launcher could do better. The simplest solution would be to use isSunVM() on the executable, and only use the registry keys if it is a Sun VM. Starting the java.exe otherwise for IBM VMs would be acceptable for me, though using the IBM registry keys and linking to java.dll would be even better.
C:\Documents and Settings\Administrator>java -version
java version "1.6.0"
Java(TM) SE Runtime Environment (build pwi3260sr8fp1ifix-20100903_02(SR8 FP1+IZ83654))
IBM J9 VM (build 2.4, JRE 1.6.0 IBM J9 2.4 Windows XP x86-32 jvmwi3260sr8-20100401_55940 (JIT enabled, AOT enabled)
J9VM - 20100401_055940
JIT  - r9_20100401_15339
GC   - 20100308_AA)
JCL  - 20100903_02
C:\Documents and Settings\Administrator>"c:\Program Files\IBM\Java60\jre\bin\java.exe" -version
GC   - 20100308_AA)
JCL  - 20100903_02
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
-launcher
C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat\MemoryAnalyzer.exe
-name
MemoryAnalyzer
--launcher.library
C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.0.200.v20090519\eclipse_1206.dll
-startup
C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat\plugins\org.eclipse.equinox.launcher_1.0.200.v20090520.jar
-vm
C:\Program Files\Java\jre6\bin\client\jvm.dll
eclipse.home.location=file:/C:/m5/MemoryAnalyzer-1.0.1.20100809-win32.win32.x86/mat/
eclipse.launcher=C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat\MemoryAnalyzer.exe
eclipse.product=org.eclipse.mat.ui.rcp.MemoryAnalyzer
eclipse.startTime=1298901024062
eclipse.vm=C:\Program Files\Java\jre6\bin\client\jvm.dll
eclipse.vmargs=-Xmx1024m
-Djava.class.path=C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat\plugins\org.eclipse.equinox.launcher_1.0.200.v20090520.jar
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre6\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre6\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre6
java.io.tmpdir=C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\
java.library.path=C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat;.;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:/Program Files/Java/jre6/bin/client;C:/Program Files/Java/jre6/bin;C:\Program Files\ThinkPad\Utilities;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\IBM\Infoprint Select;C:\Notes;C:\Program Files\XLView;C:\lotus\compnent;C:\Utilities;C:\Program Files\IBM\Personal Communications\;C:\Program Files\IBM\Trace Facility\;C:\Program Files\ThinkPad\ConnectUtilities;C:\WINDOWS\Downloaded Program Files;C:\Program Files\ObjREXX;C:\Program Files\ObjREXX\OODIALOG;C:\Program Files\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Common Files\Lenovo;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\IBM\CMVCDC50
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_18-b07
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_18
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=16.0-b13
line.separator=
Re: Launcher finds Sun VM instead of IBM VM on Windows. [message #656820 is a reply to message #656772] Mon, 28 February 2011 12:37 Go to previous messageGo to next message
Andrew,
The launcher has a JRE tab. By default it uses the same JRE you used to
run Eclipse itself, I think. But you can configure other JREs and use
those.
> \windows\system32
> GC - 20100308_AA)
> JCL - 20100903_02
> GC - 20100308_AA)
> JCL - 20100903_02
> win32
> -ws
> win32
> -arch
> x86
> -showsplash
> -launcher
> C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat\Memo ryAnalyzer.exe
> -name
> MemoryAnalyzer
> --launcher.library
> C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat\plug ins\org.eclipse.equinox.launcher.win32.win32.x86_1.0.200.v20 090519\eclipse_1206.dll
> -startup
> C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat\plug ins\org.eclipse.equinox.launcher_1.0.200.v20090520.jar
> -vm
> eclipse.home.location=file:/C:/m5/MemoryAnalyzer-1.0.1.20100 809-win32.win32.x86/mat/
> eclipse.launcher=C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.w in32.x86\mat\MemoryAnalyzer.exe
> -Djava.class.path=C:\m5\MemoryAnalyzer-1.0.1.20100809-win32. win32.x86\mat\plugins\org.eclipse.equinox.launcher_1.0.200.v 20090520.jar
> file.separator=\
> java.class.path=C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.wi n32.x86\mat\plugins\org.eclipse.equinox.launcher_1.0.200.v20 090520.jar
> java.library.path=C:\m5\MemoryAnalyzer-1.0.1.20100809-win32. win32.x86\mat;.;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32; C:\WINDOWS;C:/Program
> Files\ThinkPad\Utilities;C:\WINDOWS\system32;C:\WINDOWS;C:\W INDOWS\System32\Wbem;C:\Program
> Files\IBM\CMVCDC50
> line.separator=
Re: Launcher finds Sun VM instead of IBM VM on Windows. [message #656988 is a reply to message #656820] Tue, 01 March 2011 04:47 Go to previous messageGo to next message
The problem occurs when running Memory Analyzer as an RCP product, not when launching Memory Analyzer from inside Eclipse.
The problem also occurs when running Eclipse without the -vm option.
Help->About->Installation Details->Configuration
shows the Sun VM even though the system VM is an IBM one.
eclipseWin.c
Re: Launcher finds Sun VM instead of IBM VM on Windows. [message #657106 is a reply to message #656988] Tue, 01 March 2011 10:32 Go to previous message
Andrew,
If you really want something in the implementation to change, you'll
need to open a bugzilla and then wait very patiently.
> Help->About->Installation Details->Configuration shows the Sun VM even
> http://dev.eclipse.org/viewcvs/viewvc.cgi/org.eclipse.equino x/framework/bundles/org.eclipse.equinox.executable/library/w in32/eclipseWin.c?view=markup&root=RT_Project
Previous Topic:Eclipse Extension Point search
Next Topic:whole word file search
Current Time: Mon Jul 07 15:24:09 EDT 2025
Powered by FUDForum. Page generated in 0.07061 seconds
