| Discarding changes in working copy (file or folder) [message #656704] |
Mon, 28 February 2011 03:20  |
Hi all
Coming from the svn world, I'm used to have a "revert" command - which I can apply to files as well as whole folders, projects or even working sets in my working directory.
In (native) git, several possibilities seem to exist. I found the "reset" command (which however is not applicable to "single files", right?). Recently, I figured out, that I can just "checkout again" and will override my working directory (changes). That can also be done on file level.
In egit, this seems not to be available in the UI. I'm about to create a feature request, but I'm unsure as how I would actually name the popup / context menu entry. While in svn this is called "revert", in git "revert" has a different meaning. Calling it "reset" seems to be unprecise, as it cannot be applied to single files. The remaining "checkout" may be the most accurate in terms of what happens in the back, but git-noobs won't realize that they can revert local changes with this (at least I wouldn't ).
How about "Checkout / Override"?
Any suggestions / better ideas?
Kay
| Re: Discarding changes in working copy (file or folder) [message #657326 is a reply to message #656704] |
Wed, 02 March 2011 08:12  |
Sounds great, thanks Chris!
So, that means, we gonna have the functionality, now I'd still like to discuss the "usability" part
In Subversive (me being a "converting" svn user...) I have the possibility to "revert" my changes directly from within the Team "main" menu. The "Replace With" option exists in svn as well, but as "commit" and "revert" are basic functions, they're in the main part.
That command exists for subversive, subclipse and probably other scm providers as well - so I vote to have same functionality (with a "new" name?) directly in the Team menu (Converters will love it ).
IMHO, independently whether I'm coming from svn or another scm or none at all, the Team menu somehow reflects the "main functionality available to the user". That's where he's used to start searching for features...
What do you think?
Kay
[EDIT] added a screenshot of my subversive "Team" popup commands on a file:
[Updated on: Wed, 02 March 2011 08:22] by Moderator
FUDForum. Page generated in 0.04337 seconds
