Re: Eclipse for PHP Developers Helios Service Release 2 Now Available [message #657128 is a reply to message #656920] |
Tue, 01 March 2011 16:48   |
Tomasz Rakowski Messages: 2 Registered: October 2009 |
Toshihiro Izumi wrote on Mon, 28 February 2011 19:47 | I noticed another issue...
Toggle Comment, Add/Remove Block Comment, they don't work in PHP Editor.
I added bug fixed plugin org.eclipse.php.ui_2.2.1.v20101001-2300.jar.
Try it when you were blown down by this malfunction.
I've used your patch, and it works well. Please remember to start eclipse with --clean option.
I'm really tired of pdt releases with major bugs. I do not get it how this can go trough QA. With the frequency at which pdt is released, these releases need to be bug free, or at least major bug free. Users should not be required to dig thru forums to find patches. Also, whenever a release has bugs of this magnitude, an update should be released ASAP...
I really do like eclipse pdt, and I think it's a great IDE in general, and I appreciate that it's free. However, there is no reason why an open source project should not have high quality standards.
Anyways, thanks to Toshihiro Izumi for a great patch !
Re: Eclipse for PHP Developers Helios Service Release 2 Now Available [message #657530 is a reply to message #656920] |
Thu, 03 March 2011 08:10   |
Originally posted by: ng.tomo.at
Am 01.03.2011 01:47, schrieb Toshihiro Izumi:
can you please make this patch available for the latest plugin builds,
from Eclipse IDE for PHP Developers 1.3.2.20110301-1807
(epp-package update on 2011-03-01)?
my plugin is org.eclipse.php.ui_2.2.1.v201010250319.jar and so i can not
use patched org.eclipse.php.ui_2.2.1.v20101001-2300.jar.
thanks in advance!
Re: Eclipse for PHP Developers Helios Service Release 2 Now Available [message #658193 is a reply to message #658079] |
Mon, 07 March 2011 11:37   |
You are definitely right, i had forgotten a nightly pdt build in some
local repository, which was installed over the original.
After reverting the version i am now able to use your patched plugin and
it works as expected.
thank you for pointing me in the right direction to solve the problem!
Am 06.03.2011 04:02, schrieb Toshihiro Izumi:
> Hmm, I've tried update via "Check for Updates" so I could get
> Version: Helios Service Release 2
> Build id: 20110301-1815
> EPP PHP Feature 1.3.2.20110301-1807
> However it includes
> PHP Development Tools (PDT) SDK Feature
> 2.2.1.v20101001-2300-53184QAN4JBQgLYPWMLcXn6Na9Od
> There is no org.eclipse.php.ui_2.2.1.v201010250319.jar.
FUDForum. Page generated in 0.02631 seconds
