Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3] Overriding Templates
[Acceleo 3] Overriding Templates [message #656426] Fri, 25 February 2011 10:22 Go to next message
I'm using Eclipse 3.5.2 with Acceleo 3.0.1.
Here is my situation :
- I have "plugin A" which implements "Documentation.mtl A" for elements of "meta-model A"
- "Documentation.mtl A" contains a template "generateElementDoc(e : Element)"
- I have "plugin B" which implements a "meta-model B" which extends "meta-model A"
I want to :
- Implement the generation action in "plugin A" which launches "Documentation.mtl A"
- I want to overrides "generateElementDoc(e : Element)" in "plugin B" to consider subclasses of "Element" (e.g. let's call it "SubElement")
After reading the documentation of Acceleo, I thought my solution could be :
---- Documentation.mtl A ----------------------------------------
[module Documentation('metamodelA.uri')/]
[template public generate(m : Model)]
        [comment @main /]
	[file ('index.html', false, 'UTF-8')]
	  	[for (e : Element | m.elements)]
		[generateElementDoc(e)/]
	  	[/for]
	[/file]
[/template]
[template public generateElementDoc(e : Element)]
       Hello, I'm an Element
[/template]
---- Documentation.mtl B ----------------------------------------
[module Documentation('metamodelB.uri') extends pluginA::Documentation/]
[template public generateElementDoc(e : SubElement) overrides generateElementDoc]
	Hello, I'm a SubElement
[/template]
But, I get an error under the second "generateElementDoc" in "Documentation.mtl B" which is saying
"No public template 'generateElementDoc' found." even if the package containing Documentation.mtl A
is exported.
Where am I wrong ? Crying or Very Sad
The last question is : since "plugin A" which implements the action doesn't know "plugin B", I will have to
use "dynamic template" extension for declaring "Documentation.mtl B" ? Rolling Eyes
Thank you for your answers,
Sylvain
Re: [Acceleo 3] Overriding Templates [message #656710 is a reply to message #656426] Mon, 28 February 2011 03:45 Go to previous messageGo to next message
Hi Sylvain,
First of all, I think you would need to have the uri of your two metamodels in the module B to make it work, and if you want to have no dependencies in your first generator to the second generator, you have to use the extension point for the dynamic overriding.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Acceleo wiki: http://wiki.eclipse.org/Acceleo
Blogs: http://stephanebegaudeau.tumblr.com & http://sbegaudeau.tumblr.com
Re: [Acceleo 3] Overriding Templates [message #657092 is a reply to message #656710] Tue, 01 March 2011 10:27 Go to previous message
Hi Stéphane,
Thank you for your reply ! I've finally found my mystake.
The overriden method must have the same signature in "Documentation.mtl B".
In fact, I made a mystake by wanting "overriding" + "polymorphing".
So, in "Documentation.mtl B", the template must looks like this :
[module Documentation('metamodelA.uri', 'metamodelB.uri') extends pluginA::Documentation/]
[template public generateElementDoc(e : Element) overrides generateElementDoc]
	Hello, I'm redefining generateElementDoc !
[/template]
Sylvain
Previous Topic:[xpand/xtend] xtend expression retuns a string between square brakets
Next Topic:GMF integartion wid xpand
Current Time: Fri Oct 31 19:14:03 EDT 2025
Powered by FUDForum. Page generated in 0.02921 seconds
