Home » Modeling » TMF (Xtext) » Error executing EValidator(eclipse shows an errormarker without any more info)
Error executing EValidator [message #656388] Fri, 25 February 2011 06:59 Go to next message
in my .generator project, I have a simple workflow like this:
module workflow.DmDslGenerator
import org.eclipse.emf.mwe.utils.*
var targetDir = "src-gen"
Workflow {
	component = org.eclipse.xtext.mwe.Reader {...}
	component = org.eclipse.xpand2.Generator {...}
in another project 'appDataAccess' I have another workflow where I just want to reference the DmDslGenerator workflow and change the targetDir property:
module workflow.GenerateEntities
@DmDslGenerator {
	targetDir = "generated-sources/tmf"
In this file, eclipse will always show an errormarker:
Description: Error executing EValidator
Resource: GenerateEntities.mwe2
Path: /appDataAccess/src/main/tmf/workflow
Location /appDataAccess/src/main/tmf/workflow/GenerateEntities.mwe2
Type: Xtext Check (fast)
without any more info - I have no idea what could be wrong.
When I run the Workflow, everything is generated as it should be - even the targetDir property is the expected one.
another note: when I remove the target dir property in GenerateEntities, the error-marker is gone
any ideas?
TIA, martin
Re: Error executing EValidator [message #656400 is a reply to message #656388] Fri, 25 February 2011 07:49 Go to previous messageGo to next message
Hi Martin,
is there something in the error log?
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 25.02.11 12:59, schrieb Martin Trummer:
> Workflow {
> property:
> @DmDslGenerator {
> any ideas?
> TIA, martin
Re: Error executing EValidator [message #656402 is a reply to message #656400] Fri, 25 February 2011 07:58 Go to previous messageGo to next message
nothing that gives me more information:
eclipse.buildId=M20100909-0800
java.version=1.6.0_23
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_AT
Framework arguments:  -XX:PermSize=512m -XX:MaxPermSize=1024m
Command-line arguments:  -os win32 -ws win32 -arch x86 -XX:PermSize=512m -XX:MaxPermSize=1024m
Error
Fri Feb 25 12:54:53 CET 2011
org.eclipse.xtext.validation.CompositeEValidator  - Error executing EValidator
and it says:
An exception stack trace is not available.
Re: Error executing EValidator [message #656412 is a reply to message #656402] Fri, 25 February 2011 08:39 Go to previous message
ah - now it works - was a newbie mistake.
I just need to add a Workflow around it.
But the errormessage was really not helpful.
Workflow {
	component = @DmDslGenerator {
		targetDir = generationDir
Previous Topic:Stdlib extensions
Next Topic:Issues while MW2 generating of Xtext Grammar(LL issues)
Current Time: Mon Nov 10 09:04:30 EST 2025
Powered by FUDForum. Page generated in 0.04113 seconds
