Re: Preview fails when parameters present [message #655865 is a reply to message #655848] |
Tue, 22 February 2011 21:52 |
Don,
Can you post an example report that contains the issue?
Jason
On 2/22/2011 3:03 PM, Don wrote:
> I am developing BIRT reports in 2.3.2. When I attempt to preview a
> report in the development environment that has no parameters, the
> preview works fine. However, when I preview a report that has
> parameters, the parameter prompts appear. Then, when I click OK, I
> receive the following error...
> java.lang.ClassCastException: java.lang.NoSuchMethodError incompatible
> with java.lang.Exception
> Our team is using jsp pages and the BIRT Viewer to view the reports in
> production which works fine. It's only in the development environment
> that we are having an issue.
> Any thoughts on why this would behave like this?
> Any help would be greatly appreciated.
> -Don
Re: Preview fails when parameters present [message #655962 is a reply to message #655946] |
Wed, 23 February 2011 14:31 |
Don,
Are you using the allinone download for 2.3.2? What os are you running on?
Jason
On 2/23/2011 8:33 AM, Don wrote:
> Jason,
> I've included a simple report I put together using the Classic Models
> SampleDB. This fails with the same error when I click the OK button on
> the "Enter Parameters" dialogue of the Preview.
> <report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17"
> id="1">
> <property name="createdBy">Eclipse BIRT Designer Version
> 2.3.2.r232_20090202 Build <2.3.2.v20090218-0730></property>
> <property name="units">in</property>
> <property name="iconFile">/templates/blank_report.gif</property>
> <property name="bidiLayoutOrientation">ltr</property>
> <parameters>
> <scalar-parameter name="custNbr" id="9">
> <property name="valueType">static</property>
> <property name="dataType">integer</property>
> <property name="paramType">simple</property>
> <text-property name="promptText">Enter the Customer Number:</text-property>
> <property name="controlType">text-box</property>
> <property name="defaultValue">157</property>
> <property name="distinct">true</property>
> <structure name="format">
> <property name="category">Unformatted</property>
> </structure>
> </scalar-parameter>
> <scalar-parameter name="state" id="10">
> <property name="dataType">string</property>
> <text-property name="promptText">Enter the State</text-property>
> <property name="defaultValue">PA</property>
> </structure>
> </scalar-parameter>
> </parameters>
> <data-sources>
> <oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc"
> name="Data Source" id="7">
> <text-property name="displayName"></text-property>
> <property
> name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver
> </property>
> <property name="odaURL">jdbc:classicmodels:sampledb</property>
> <property name="odaUser">ClassicModels</property>
> <property name="OdaConnProfileName"></property>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
> name="rptDs" id="8">
> <list-property name="columnHints">
> <structure>
> <property name="columnName">CUSTOMERNUMBER</property>
> <property name="displayName">CUSTOMERNUMBER</property>
> </structure>
> <structure>
> <property name="columnName">CUSTOMERNAME</property>
> <property name="displayName">CUSTOMERNAME</property>
> </structure>
> <structure>
> <property name="columnName">CONTACTLASTNAME</property>
> <property name="displayName">CONTACTLASTNAME</property>
> </structure>
> <structure>
> <property name="columnName">CONTACTFIRSTNAME</property>
> <property name="displayName">CONTACTFIRSTNAME</property>
> </structure>
> </list-property>
> <structure name="cachedMetaData">
> <list-property name="resultSet">
> <structure>
> <property name="position">1</property>
> <property name="name">CUSTOMERNUMBER</property>
> </structure>
> <structure>
> <property name="position">2</property>
> <property name="name">CUSTOMERNAME</property>
> </structure>
> <structure>
> <property name="position">3</property>
> <property name="name">CONTACTLASTNAME</property>
> </structure>
> <structure>
> <property name="position">4</property>
> <property name="name">CONTACTFIRSTNAME</property>
> </structure>
> </list-property>
> </structure>
> <property name="dataSource">Data Source</property>
> <list-property name="parameters">
> <structure>
> <property name="name">param_1</property>
> <property name="paramName">custNbr</property>
> <property name="nativeName"></property>
> <property name="nativeDataType">4</property>
> <property name="isOptional">true</property>
> <property name="allowNull">true</property>
> <property name="isInput">true</property>
> <property name="isOutput">false</property>
> </structure>
> <structure>
> <property name="name">param_2</property>
> <property name="paramName">state</property>
> <property name="nativeDataType">12</property>
> </structure>
> </list-property>
> <structure>
> <property name="nativeName">CUSTOMERNUMBER</property>
> </structure>
> <structure>
> <property name="nativeName">CUSTOMERNAME</property>
> </structure>
> <structure>
> <property name="nativeName">CONTACTLASTNAME</property>
> </structure>
> <structure>
> <property name="nativeName">CONTACTFIRSTNAME</property>
> </structure>
> </list-property>
> <property name="queryText">select CLASSICMODELS.CUSTOMERS.CUSTOMERNUMBER,
> CLASSICMODELS.CUSTOMERS.CUSTOMERNAME,
> CLASSICMODELS.CUSTOMERS.CONTACTLASTNAME,
> CLASSICMODELS.CUSTOMERS.CONTACTFIRSTNAME
> from CLASSICMODELS.CUSTOMERS
> where CLASSICMODELS.CUSTOMERS.CUSTOMERNUMBER = ?
> and CLASSICMODELS.CUSTOMERS.STATE = ?</property>
> <xml-property name="designerValues"><![CDATA[<?xml version="1.0"
> encoding="UTF-8"?>
> <model:DesignValues
> xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
> xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
> <Version>1.0</Version>
> <design:DataSetParameters>
> <design:parameterDefinitions>
> <design:inOutMode>In</design:inOutMode>
> <design:attributes>
> <design:name></design:name>
> <design:position>1</design:position>
> <design:nativeDataTypeCode>4</design:nativeDataTypeCode>
> <design:precision>10</design:precision>
> <design:scale>0</design:scale>
> <design:nullability>Nullable</design:nullability>
> </design:attributes>
> <design:inputAttributes>
> <design:elementAttributes>
> <design:optional>true</design:optional>
> </design:elementAttributes>
> </design:inputAttributes>
> </design:parameterDefinitions>
> <design:attributes>
> <design:position>2</design:position>
> <design:nativeDataTypeCode>12</design:nativeDataTypeCode>
> <design:precision>50</design:precision>
> </design:DataSetParameters>
> </model:DesignValues>]]></xml-property>
> </oda-data-set>
> <oda-data-set
> name="Data Set" id="11">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <property name="columnName">PHONE</property>
> <property name="displayName">PHONE</property>
> </structure>
> <structure>
> <property name="columnName">ADDRESSLINE1</property>
> <property name="displayName">ADDRESSLINE1</property>
> </structure>
> <structure>
> <property name="columnName">ADDRESSLINE2</property>
> <property name="displayName">ADDRESSLINE2</property>
> </structure>
> <structure>
> <property name="columnName">CITY</property>
> <property name="displayName">CITY</property>
> </structure>
> <structure>
> <property name="columnName">STATE</property>
> <property name="displayName">STATE</property>
> </structure>
> <structure>
> <property name="columnName">POSTALCODE</property>
> <property name="displayName">POSTALCODE</property>
> </structure>
> <structure>
> <property name="columnName">COUNTRY</property>
> <property name="displayName">COUNTRY</property>
> </structure>
> <structure>
> <property name="columnName">SALESREPEMPLOYEENUMBER</property>
> <property name="displayName">SALESREPEMPLOYEENUMBER</property>
> </structure>
> <structure>
> <property name="columnName">CREDITLIMIT</property>
> <property name="displayName">CREDITLIMIT</property>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <property name="position">5</property>
> <property name="name">PHONE</property>
> </structure>
> <structure>
> <property name="position">6</property>
> <property name="name">ADDRESSLINE1</property>
> </structure>
> <structure>
> <property name="position">7</property>
> <property name="name">ADDRESSLINE2</property>
> </structure>
> <structure>
> <property name="position">8</property>
> <property name="name">CITY</property>
> </structure>
> <structure>
> <property name="position">9</property>
> <property name="name">STATE</property>
> </structure>
> <structure>
> <property name="position">10</property>
> <property name="name">POSTALCODE</property>
> </structure>
> <structure>
> <property name="position">11</property>
> <property name="name">COUNTRY</property>
> </structure>
> <structure>
> <property name="position">12</property>
> <property name="name">SALESREPEMPLOYEENUMBER</property>
> </structure>
> <structure>
> <property name="position">13</property>
> <property name="name">CREDITLIMIT</property>
> <property name="dataType">float</property>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <property name="nativeName">PHONE</property>
> </structure>
> <structure>
> <property name="nativeName">ADDRESSLINE1</property>
> </structure>
> <structure>
> <property name="nativeName">ADDRESSLINE2</property>
> </structure>
> <structure>
> <property name="nativeName">CITY</property>
> </structure>
> <structure>
> <property name="nativeName">STATE</property>
> </structure>
> <structure>
> <property name="nativeName">POSTALCODE</property>
> </structure>
> <structure>
> <property name="nativeName">COUNTRY</property>
> </structure>
> <structure>
> <property name="nativeName">SALESREPEMPLOYEENUMBER</property>
> </structure>
> <structure>
> <property name="nativeName">CREDITLIMIT</property>
> <property name="nativeDataType">8</property>
> </structure>
> </list-property>
> <property name="queryText">select *
> from CLASSICMODELS.CUSTOMERS</property>
> encoding="UTF-8"?>
> <model:DesignValues
> <design:ResultSets derivedMetaData="true">
> <design:resultSetDefinitions>
> <design:resultSetColumns>
> <design:resultColumnDefinitions>
> <design:attributes>
> <design:name>CUSTOMERNUMBER</design:name>
> <design:uiHints>
> <design:displayName>CUSTOMERNUMBER</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>CUSTOMERNUMBER</design:label>
> <design:formattingHints>
> <design:displaySize>11</design:displaySize>
> </design:formattingHints>
> </design:usageHints>
> </design:resultColumnDefinitions>
> <design:attributes>
> <design:name>CUSTOMERNAME</design:name>
> <design:uiHints>
> <design:displayName>CUSTOMERNAME</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>CUSTOMERNAME</design:label>
> <design:displaySize>50</design:displaySize>
> <design:attributes>
> <design:name>CONTACTLASTNAME</design:name>
> <design:position>3</design:position>
> <design:uiHints>
> <design:displayName>CONTACTLASTNAME</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>CONTACTLASTNAME</design:label>
> <design:attributes>
> <design:name>CONTACTFIRSTNAME</design:name>
> <design:position>4</design:position>
> <design:uiHints>
> <design:displayName>CONTACTFIRSTNAME</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>CONTACTFIRSTNAME</design:label>
> <design:attributes>
> <design:name>PHONE</design:name>
> <design:position>5</design:position>
> <design:uiHints>
> <design:displayName>PHONE</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>PHONE</design:label>
> <design:attributes>
> <design:name>ADDRESSLINE1</design:name>
> <design:position>6</design:position>
> <design:uiHints>
> <design:displayName>ADDRESSLINE1</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>ADDRESSLINE1</design:label>
> <design:attributes>
> <design:name>ADDRESSLINE2</design:name>
> <design:position>7</design:position>
> <design:uiHints>
> <design:displayName>ADDRESSLINE2</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>ADDRESSLINE2</design:label>
> <design:attributes>
> <design:name>CITY</design:name>
> <design:position>8</design:position>
> <design:uiHints>
> <design:displayName>CITY</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>CITY</design:label>
> <design:attributes>
> <design:name>STATE</design:name>
> <design:position>9</design:position>
> <design:uiHints>
> <design:displayName>STATE</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>STATE</design:label>
> <design:attributes>
> <design:name>POSTALCODE</design:name>
> <design:position>10</design:position>
> <design:precision>15</design:precision>
> <design:uiHints>
> <design:displayName>POSTALCODE</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>POSTALCODE</design:label>
> <design:displaySize>15</design:displaySize>
> <design:attributes>
> <design:name>COUNTRY</design:name>
> <design:position>11</design:position>
> <design:uiHints>
> <design:displayName>COUNTRY</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>COUNTRY</design:label>
> <design:attributes>
> <design:name>SALESREPEMPLOYEENUMBER</design:name>
> <design:position>12</design:position>
> <design:uiHints>
> <design:displayName>SALESREPEMPLOYEENUMBER</design:displayName >
> </design:uiHints>
> <design:usageHints>
> <design:label>SALESREPEMPLOYEENUMBER</design:label>
> <design:attributes>
> <design:name>CREDITLIMIT</design:name>
> <design:position>13</design:position>
> <design:nativeDataTypeCode>8</design:nativeDataTypeCode>
> <design:uiHints>
> <design:displayName>CREDITLIMIT</design:displayName>
> </design:uiHints>
> <design:usageHints>
> <design:label>CREDITLIMIT</design:label>
> <design:displaySize>22</design:displaySize>
> </design:resultSetColumns>
> </design:resultSetDefinitions>
> </design:ResultSets>
> ]]></xml-property>
> </oda-data-set>
> </data-sets>
> <styles>
> <style name="report" id="4">
> <property name="fontFamily">"Verdana"</property>
> <property name="fontSize">10pt</property>
> </style>
> <style name="crosstab" id="5">
> <property name="borderBottomColor">#CCCCCC</property>
> <property name="borderBottomStyle">solid</property>
> <property name="borderBottomWidth">1pt</property>
> <property name="borderLeftColor">#CCCCCC</property>
> <property name="borderLeftStyle">solid</property>
> <property name="borderLeftWidth">1pt</property>
> <property name="borderRightColor">#CCCCCC</property>
> <property name="borderRightStyle">solid</property>
> <property name="borderRightWidth">1pt</property>
> <property name="borderTopColor">#CCCCCC</property>
> <property name="borderTopStyle">solid</property>
> <property name="borderTopWidth">1pt</property>
> </style>
> <style name="crosstab-cell" id="6">
> </style>
> </styles>
> <page-setup>
> <simple-master-page name="Simple MasterPage" id="2">
> <property name="topMargin">0.25in</property>
> <property name="leftMargin">0.25in</property>
> <property name="bottomMargin">0.25in</property>
> <property name="rightMargin">0.25in</property>
> <page-footer>
> <text id="3">
> <property name="contentType">html</property>
> <text-property name="content"><![CDATA[<value-of>new
> Date()</value-of>]]></text-property>
> </text>
> </page-footer>
> </simple-master-page>
> </page-setup>
> <body>
> <table id="12">
> <property name="width">100%</property>
> <property name="dataSet">rptDs</property>
> <list-property name="boundDataColumns">
> <structure>
> <expression name="expression">dataSetRow["CUSTOMERNUMBER"]</expression >
> </structure>
> <structure>
> <expression name="expression">dataSetRow["CUSTOMERNAME"]</expression >
> </structure>
> <structure>
> <expression name="expression">dataSetRow["CONTACTLASTNAME"]</expression >
> </structure>
> <structure>
> <expression name="expression">dataSetRow["CONTACTFIRSTNAME"]</expression >
> </structure>
> </list-property>
> <column id="36"/>
> <column id="37"/>
> <column id="38"/>
> <column id="39"/>
> <header>
> <row id="13">
> <cell id="14">
> <label id="15">
> <text-property name="text">CUSTOMERNUMBER</text-property>
> </label>
> </cell>
> <cell id="16">
> <label id="17">
> <text-property name="text">CUSTOMERNAME</text-property>
> </label>
> </cell>
> <cell id="18">
> <label id="19">
> <text-property name="text">CONTACTLASTNAME</text-property>
> </label>
> </cell>
> <cell id="20">
> <label id="21">
> <text-property name="text">CONTACTFIRSTNAME</text-property>
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="22">
> <cell id="23">
> <data id="24">
> <property name="resultSetColumn">CUSTOMERNUMBER</property>
> </data>
> </cell>
> <cell id="25">
> <data id="26">
> <property name="resultSetColumn">CUSTOMERNAME</property>
> </data>
> </cell>
> <cell id="27">
> <data id="28">
> <property name="resultSetColumn">CONTACTLASTNAME</property>
> </data>
> </cell>
> <cell id="29">
> <data id="30">
> <property name="resultSetColumn">CONTACTFIRSTNAME</property>
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="31">
> <cell id="32"/>
> <cell id="33"/>
> <cell id="34"/>
> <cell id="35"/>
> </row>
> </footer>
> </table>
> </body>
> </report>
Re: Preview fails when parameters present [message #655989 is a reply to message #655986] |
Wed, 23 February 2011 16:28 |
Don,
In the navigator view do you see a reportname.rptconfig file? This
should get created when you run the report in the designer.
Jason
On 2/23/2011 11:17 AM, Don wrote:
> Jason,
> Our development is through IBM Rational Software Architect (RSA) so
> what's running is whatever got installed with that, as opposed to the
> All-in-one download. FYI - we are running RSA Version: 7.5.5.2 Build ID:
> 20100923_2051.
> Our OS is XP.
> Let me say this, that there are four developers on our team. Two of us
> can preview reports just fine. The other two are having issues. It seems
> that, even though we are supposed to have the same development software
> baseline, something is different between our installs. If you are
> familiar enough with the software to know what goes on when I click OK
> on the parameters page, that might give us an indication of what to
> compare between our separate installs of RSA.
> Thanks for your help.
> Don
Re: Preview fails when parameters present [message #656013 is a reply to message #655994] |
Wed, 23 February 2011 18:09 |
Don,
What directory is your workspace and eclipse install are in? Can you
compare this to the machines that are working?
Jason
On 2/23/2011 11:49 AM, Don wrote:
> Jason,
> No there is no .rptconfig file corresponding to my report. Should there
> be? I thought this was only created once a report was successfully
> previewed.
> Don
Re: Preview fails when parameters present [message #656219 is a reply to message #656021] |
Thu, 24 February 2011 15:32 |
Don,
I was wondering if this was a disk permission issue. Any change you can
download the 2.3.2 allinone download as a test?
Jason
On 2/23/2011 2:19 PM, Don wrote:
> Jason,
> All of us have our workspace on our C drives but we have multiple
> workspaces...most directly off of the C drive.
> The eclipse executable is in C:\Program Files\IBM\SDP. However, there is
> a multitude of folders under this in which pieces of the entire Rational
> software is installed. Is there something specifically that we could
> compare from one machine to another?
> Don
FUDForum. Page generated in 0.04357 seconds
