Home » Eclipse Projects » DSDP - Target Management » Remote Debuging without gdbserver(Remote Debuging without gdbserver)
Remote Debuging without gdbserver [message #655447] Mon, 21 February 2011 03:16 Go to next message
Hi Team,
I have a host windows machine and target Linux machine.
I want to debug an application in Target Linux machine from Eclipse ide in host machine.
I dont have gdb in my host machine but i have gdb as well as gdbserver in target machine
Is there a way i can debug app in target machine from Eclipse(in host machine) without using host gdb but using remote gdb.
Please let me know.
Thanks in advance,
ssk
Re: Remote Debuging without gdbserver [message #655460 is a reply to message #655447] Mon, 21 February 2011 04:33 Go to previous messageGo to next message
See the FAQ:
http://wiki.eclipse.org/TM_and_RSE_FAQ#How_can_I_do_Remote_D ebugging_with_CDT.3F
When you don't have a cross-gdb on your windows host, you'll need to remotely execute the remote gdb through ssh. This used to work in the past, I do not know if it still works - if not, please ask the question on the CDT forum.
Martin
Re: Remote Debuging without gdbserver [message #655702 is a reply to message #655460] Tue, 22 February 2011 06:22 Go to previous messageGo to next message
Hi Martin ,
Thanks for you reply,
I posted the same query in eclipse CDT forum but didnt get any response.
Could you please tell me how to "remotely execute the remote gdb through ssh" .
Under CDT debug configuration which one should i select ?
1.C/C++ remote application or
2.GDB Hardware Debugging
and where should i give " ssh remotehost gdb" command ?
Please help me out with this , i have seen few materials regarding this but not sure which one to select and how to do.
Thanks in Advance
ssk.
Re: Remote Debuging without gdbserver [message #655875 is a reply to message #655447] Tue, 22 February 2011 19:20 Go to previous messageGo to next message
Hi Martin ,
Thanks in Advance
ssk.
Re: Remote Debuging without gdbserver [message #656197 is a reply to message #655875] Thu, 24 February 2011 09:34 Go to previous messageGo to next message
Please read the FAQ mentioned above, it has references to some bugzilla's which have more details.
Also, please note that this forum is being shut down since the TM project moved to Tools. Please use the "Target Management" forum instead for future questions (news://eclipse.tools.tm, or http://www.eclipse.org/forums/index.php?t=thread&frm_id= 210 ).
Martin
Re: Remote Debuging without gdbserver [message #1703105 is a reply to message #656197] Tue, 28 July 2015 10:42 Go to previous message
Now there is a new plug-in http://marketplace.eclipse.org/content/direct-remote-c-debugging
It works with new versions of Eclipse . It does running gdb over ssh remotly and makes all the debugging features available in local Eclipse.
Previous Topic:Console TERM Emulation Support
Next Topic:Suddenly: Daemon failed to launch server using port 0
Current Time: Mon Nov 03 02:05:58 EST 2025
Powered by FUDForum. Page generated in 0.05106 seconds
