Re: Reverse Engineering Plugin based on MoDisco [message #655466 is a reply to message #655435] |
Mon, 21 February 2011 10:01 |
Hugo Bruneliere Messages: 674 Registered: July 2009 |
Hello George,
First, thanks for your interest in the project.
As you described it, your use case is a very good application for the MoDisco framework.
Of course, you can directly reuse the available Java and XML discoverers by combining them together in your solution (i.e. a plug-in). You can also integrate the refinement of the obtained models, according to your targeted needs, by using M2M transformations.
To have more details on the related MoDisco components, I invite you to take a look to the reference documentation of the latest version: http://wiki.eclipse.org/MoDisco/Components/v0.9
It explains how to use the discoverers you will need, and how to chain them with the also provided Discovery Workflow.
I hope this is going to help you starting more easily.
And don't hesitate if you have any other question.
Hugo
Hugo Bruneliere, PhD
NaoMod team (IMT Atlantique & LS2N-CNRS)
Nantes - France
FUDForum. Page generated in 0.03291 seconds
