Home » Newcomers » Newcomers » Howto change size of pop-up dialogs
Howto change size of pop-up dialogs [message #654934] Thu, 17 February 2011 11:39 Go to next message
Is it possible to change the size of the Eclipse popup dialogs, e.g. the Open Declaration dialog? I get several matches and the path is always too long, thus I need to resize the dialog manually each time to be able to choose the correct alternative.
Re: Howto change size of pop-up dialogs [message #654944 is a reply to message #654934] Thu, 17 February 2011 12:06 Go to previous messageGo to next message
On 17.02.2011 17:39, Andreas wrote:
The 'Open Type' dialog remembers the size. If that's not true for you
then please open a bug against JDT UI.
Dani
Re: Howto change size of pop-up dialogs [message #655049 is a reply to message #654944] Fri, 18 February 2011 02:28 Go to previous messageGo to next message
I'm not sure if I got it right. I'm using CDT on linux. I do not have any problems with tabs (they remember the size), but the popup dialogs do not e.g. "Open Declaration" (F3).
/Andreas
Re: Howto change size of pop-up dialogs [message #655055 is a reply to message #655049] Fri, 18 February 2011 02:49 Go to previous messageGo to next message
OK, so that' might be a bug in CDT. Does 'Open Resource' keep the size?
Dani
> /Andreas
Re: Howto change size of pop-up dialogs [message #655056 is a reply to message #655055] Fri, 18 February 2011 03:02 Go to previous message
Yes, the "Open Resource" dialog remember it's size. I guess I should file a bug then.
Previous Topic:Execute an applet in a jar from within eclipse
Next Topic:Can't see Error Boxes on Right hand side panel
Current Time: Fri Aug 08 12:38:56 EDT 2025
Powered by FUDForum. Page generated in 0.06084 seconds
